Trek 5200 crank question
Its Freakin HammerTime!!!
Ultegra 6500 Double 53/39
There is no option for the 6500 in 50/34 that I can find. I need the compact for sure. My knees don't like the 53/39. I do have an 11/28 on the back though. Suggestions? I don't mind moving down to a 105 crank in 50/34 if I had to.
Thanks in advance
Thanks in advance
aka: Dr. Cannondale
Quoted: 2152 Post(s)
Liked 3,401 Times
At the time of 6500/5500, Shimano did not make a compact crankset in that series.
You can go newer 10/11 speed, which will work just fine with your other components, or older MTB cranksets, which can accept compact rings, or something like an FSA compact crank with a square taper BB.
Whichever way you decide, a new BB will also be required.
Likes For rccardr:
Quoted: 2952 Post(s)
Liked 3,106 Times
FWIW: I had a '00 5200 with a 52-42-30 triple crank. Made no sense to have a triple in pancake flat Sacramento, so I changed it to a DA 7800, which was the first Hollowtech II crank/BB. Lighter, stiffer, a game-changer.
Anyway, a newer compact 105 crankset will be an upgrade over a Ultegra 6500 for sure.
Quoted: 789 Post(s)
Liked 1,739 Times
I would agree if your struggling with the 53/39 a triple may work better for you than a compact. Most 8 or 9 speed Shimano triples should work with a matching BB you will also want to get a new chain.
Likes For zukahn1:
