Secure Water Bottle Cage for Powerade/Gatorade bottle?
Quoted: 539 Post(s)
Liked 44 Times
Started biking to work this year. Tired and not watching closely enough, I plowed into the side of a curb that I had thought dipped down - but didn't. Somehow - miraculously, or through bike handling skills developed mountain biking - my bike actually made it over the curb without an accident. The only bad thing that happened is my Powerade bottle flew out of the water bottle holder and onto the ground.
However, I'd rather not even risk that again. Wondering if anyone has experience with a water bottle holder that would securely hold a Powerade or Gatorade bottle, or also a regular water bottle, even if the bike hits some pretty rough bumps.
The only thing that looks like it would do it that I've found so far is the Topeak Modula Cage II -
https://www.topeak.com/products/Bottle-Cages/modulacage2
Wondering if anyone has personal experience with Powerade or Gatorade bottles, in that cage or in another cage...
Hogosha Sekai
Bikes: Leader 725, Centurion Turbo, Scwhinn Peloton, Schwinn Premis, GT Tequesta, Bridgestone CB-2,72' Centurion Lemans, 72 Raleigh Competition
Quoted: 70 Post(s)
Liked 21 Times
I have one similar to this, never had a store bottle slip since it expands to grip them.
https://www.amazon.com/Origin-8-Fiber...ng+bottle+cage
Hogosha Sekai
Quoted: 70 Post(s)
Liked 21 Times
Quoted: 539 Post(s)
Liked 44 Times
Quoted: 539 Post(s)
Liked 44 Times
Yeah, the problem there is that I don't usually bring powerade/gatorade except for longer rides, and once you put something sugary in a water bottle you start to get mold issues growing in the bottle. I mean...maybe if I sat down and calculated it out, it would be worth it to buy the powder, mix it in a bottle, and throw out a bottle every year...but so far I've just been buying a 6 pack (or maybe 2 six packs) every year then I don't have to throw out a water bottle. Plus it's easy to grab going out the door, don't have to take extra time to mix it.
Quoted: 539 Post(s)
Liked 44 Times
Wanted to say thanks for the suggestion. While there's a little bit of a gap at the bottom of the cage, it looks like the Gatorade bottle has a far better "lip" for securing itself into the cage. I'm going to try that - thanks!
put a toe strap under the water bottle cage , as you install it,
then you can use the strap to hold the bottle secure .
Bikes: Lotus Odyssey - Shogun 400 - '75 Raleigh Tourist - Raleigh Grand Prix - Gitane Tour de France- Schwinn Le Tour - Univega Maxima Sport (winter bike) Trek 950
Quoted: 27 Post(s)
Liked 6 Times
I cut the top off an old (& cheap) regular water bottle right at the point where it would hold the bottle tight. Left a bit of a pik sticking up so it would press on the upper part of the cage.
Quoted: 539 Post(s)
Liked 44 Times
Just wanted to write back about what I found.
DX-MAN's suggestion was good - the Gatorade Twist top bottle fits a lot better into every cage I tried it with. It's a wider bottle which is closer to a normal water bottle cage in width and girth so most cages hold onto it about as well as a regular water bottle. It is a little short.
The Specialized Zee Cage -
https://www.specialized.com/us/en/ftb...zee-cage-right
Seems to hold onto **everything**, though. Water bottle, gatorage bottle, skinnier powerade bottle - I tried out several cages including the Tacx Tao, the Specialized Rib Cage, and several others at the shop, and the Zee was the only cage that actually gripped the Powerade bottle (the Topeak Modula cage also looked like it would probably do the job, as it's adjustable to grip skinnier bottles, but I wasn't able to try it as it was out of stock at my local REI).
Specialized also sells a water bottle, the Purist Mo'Flo Bottle (they also sell other purist bottles) that claims "Purist infusion shields the bottle from odor, stains and mold to keep your water pure and your bottle clean", so I'm going to try that as well.
https://www.specialized.com/us/en/ftb...t-moflo-bottle
You can also find other Purist bottles on Amazon like the "Purist Hydroflo for Bike Hugger" -
https://www.amazon.com/Purist-Hydrofl...eywords=purist
I don't know if it will really work or not yet though - the cap on the top looks like it's difficult to completely clean out, so we'll see. But supposedly it keeps mold from growing (my concern with using a water bottle for sports drinks).
They claim that -
Silicon dioxide is an inert compound made from two of the most abundant elements in the earth’s crust: silicon (not to be confused with the chemical “silicone”) and oxygen. When combined they form silicon dioxide (SIO2).
Occurring naturally in plant-based foods such as apples, oranges, cucumbers, and celery, silicon dioxide is an indispensible part of the food we eat. And along with calcium and vitamins, it is important for the natural development of bones and the maintenance of healthy skin.
Just wanted to write back in case someone else ran across the thread.
They claim that -
get a Clean Bottle , pour the stuff into it. advantage: the bottom unscrews to clean out the residual goo/.
https://cleanbottle.com/
Quoted: 539 Post(s)
Liked 44 Times
Bikes: Diamondback Copperhead (hardtail, winter bike), 2014 Giant Rapid 2, 2015 Kona Big Rove ST
Bikes: Bianchi circa late 1980s, Surly Cross Check, Kona Blast
um why not just buy a bike water bottle.
Also agree with powder..on a reallllly long ride you can carry a ziploc with more powder so when you refill the bottle along the way you can make a new bottle of gatorade with it.
Ditto on washing the bottle..
Hogosha Sekai
Quoted: 70 Post(s)
Liked 21 Times
Mold in the bottles eh? I have a thing called a bottle brush... I suppose if I left my bottles to fester for weeks or something I wouldn't be able to clean them properly, but F that.
1/2 C sugar (I heap the 1/2 C measuring spoon)
1/3 tsp sea salt (better but regular salt is fine)
1/3 tsp potassium-based salt substitute
2 L (Qt) water
A little off-topic but my MTB has room for only 1 bottle on the inside of the triangle, I'd like to consider a "under-frame" bottle cage or mount but I don't know of any. Any ideas?
two fish has a velcro and rubber block system to mount their waterbottle cage wherever you wish.
https://www.twofish.biz/bike.html
