Do gravel tires feel a lot slower to you than road tires?
Old 10-13-18, 02:25 PM
  #101
radroad
Quoted: 284 Post(s)
Liked 8 Times in 6 Posts
Originally Posted by johngwheeler View Post
I've just put on some Clement X'PLOR MSO 40mm clinchers on to my Giant TCX, for my first gravel ride. Previously the bike was in "commuter mode" with 28mm GP4000S2 tires.
But, boy, the 40mm treaded tires certainly feel a lot slower to me than the slick road tires on paved surfaces! I haven't done any timed tests, but it feels like a lot more work pushing these tires on the flat or up-hill. Sure, they have some tread, and weigh a bit more, but they feel a *much* slower. Actually, even slower than the very knobbly 33mm Schwalbe X-One cyclocross tires that came with the bike.
They are. GCN did timed testing and found road tire are around 5-7% faster.
radroad is offline
Old 10-13-18, 07:55 PM
  #102
Kapusta
Cyclochondriac
Quoted: 879 Post(s)
Liked 33 Times in 27 Posts
Originally Posted by Spoonrobot View Post
Drum rolling tests are a reasonable metric to compare tires in a controlled environment. Real world use is similar enough that a tire that performs well on the drum will often perform well on the road or gravel. This also applies to tires that do not perform well on the drum.
I often see it stated as established that drum roller tests are reliable approximation of real world results on real world surfaces, but Iíve yet to see where this is actually demonstrated.
And I will say up front that the results the Rolling Resistance guy gets for the Bon Jon Pass tires is a big red flag for me for that methodology.. Another test by Tour (a german mag) had them coming in as one of the fastest they tested on rougher surfaces.
And just riding them, I know first hand they are ridiculously fast rolling.
Kapusta is offline
Old 10-13-18, 10:16 PM
  #103
Spoonrobot
Spoonrobot's Avatar
Quoted: 954 Post(s)
Liked 10 Times in 9 Posts
Are you able to see the link and graph in post 100? I mean that's it, that's the demonstration, on smooth and moderate asphalt the rolling resistance goes down as pressure increases to the breakpoint. It falls apart on gravel but there is no "good" testing protocol for loose surface riding, yet IMO. Everyone is extrapolating rough surface riding from what is essentially data from pavement. I suspect the major mountain bike XC tire companies have some very eye opening data but they're not sharing anything other than accidentally or very obliquely.
The biggest thing is that there is no breakpoint for the roller so it requires judgement and supposition to determine how relative higher pressures stack up compared to the suppleness of the tires. I wish BRR would have recorded sag values for all tires as it would make comparisons for off-road much easier. A supple tire is going to have a much higher real world breakpoint that a less supple/stiffer casing tire.
That is one of the many demonstrations, I recommend reading the Silca blog links as it goes into a lot more detail.
This paints a slightly different picture but it still very interesting: https://www.bikeradar.com/road/gear/...-tested-49101/
What methodology are you using? I have a smooth flat section of pavement and another section of consistent gravel that I perform "rundown" tests on. I ride to 16 miles per hour and then coast to a stop in the same position, record where I stop relative to a known marker and extrapolate from there. I make sure to only do the testing for tires on the same day and about the same time, it doesn't necessarily control for temp/wind but I can usually get it pretty good and then practical experience seems to be consistent with what my testing shows. It's coarse but it seems to work ok.
For example, I wasn't able to determine any difference between Grand Bois Hetres and Compass Baby Shoe Pass tires despite being different weight, size and construction. But it was shockingly obvious that Panaracer Gravel King slicks were much much slower despite having extremely similar characteristics as the BSPs.
I didn't like the Tour test because they ran the 35mm tire at 87 psi and the 25s/26 at 101 psi. That's way too high for the 35, the tire max is only 90 psi! They should have ran it closer to 45 psi. I think the pressure they used significantly overstates the resistance on the rough asphalt and understates the resistance on smooth asphalt.
Another interesting wrinkle is Tom Anhalt's testing. He's mainly focused on gravel with a triathlon bent but he seems to be finding a lot of interesting data on some of the Compass tires. You can see some of his comments here, they help add another well educated and robust voice to the discussion: https://janheine.wordpress.com/2018/...-in-the-world/
This is another good thread with Tom A. input - start at post 100: https://forum.slowtwitch.com/forum/S...63727/?page=-1
Personally I've also found Panaracer tires to vary widely in fit/finish which can have a profound effect on rolling resistance. I would really not be surprised if this ended up being the case for the BRR test, a bad tire, relatively. What's interesting is that Mr. Heine is probably well aware of this as he had a run of contract Grand Bois tires that ended up showing up and testing terrible despite close work with the factory to produce what he wanted. They were cleared out for a pittance and apparently forgotten.
Anyway, this is a very interesting topic for me as more than 1/3 of my yearly riding mileage is either timed events/races or rides 100 miles and longer. Having good fast rolling tires is one of the most important factors in my enjoyment of the sport. I have opinions formed by experience but generally try to keep an open mind and learn without too much ego.
Spoonrobot is online now
Old 10-14-18, 09:55 PM
  #104
Kapusta
Cyclochondriac
Quoted: 879 Post(s)
I have read the links you posted to (in the past), except for the Slowtwitch discussion.
But I keep coming back to the same point I made before regarding using drum roller tests to rate rolling resistance in real world conditions.
In regards to the roller drum tests, the chart you link to as well as the study it comes from does indeed show that (up to a point) higher pressure gives lower rolling resistance for a given tire. But that is really it.
However, that is not really what people are most interested in here, or at least not what I was commenting on. What is of interest is comparing different tires and ranking them against each other, so people know which tires are faster than others in real world conditions. Some quantifiable metric would be more helpful, but ultimately we are interested in comparisons.
And with this in mind, that study is NOT demonstrating that a roller drum test will predict how tires will behave on real world surfaces, in a way that can be used for comparisons. The graph shows that even for pressures below the breaking point, real world RR values are different than roller drums, and the rougher the road, the bigger the difference. That in and of itself might not be a problem IF it could be established that the differential in RR between the roller drum tests and real world conditions were consistent for all tires, but I have yet to see such evidence. Until that is established, I do not think that claim that roller drum tests can be used for comparisons between tires can be defended very well. Perhaps I have missed such a study. If so I would be interested in seeing it.
I have read Tom A's ideas on why the roller drum test SHOULD be translatable to real world conditions, but again, not seen it tested.
I feel that conclusions around the roller drum experiments fall into a common trap that many areas of research do... that is, deciding data is useful based on the fact that it is accurate, precise, reproducible, and easy to work with. Nobody can deny it is wonderful data to work with. You can fairly quickly get wattage numbers that not only lets you compare tires, but you can quantify the differences, and even use the data for calculations..... However, that does not mean that the results answer the question you are interested in..
There is a saying I read once that goes along the lines of "too often we value what we can measure, rather than measuring what we value". Roller drum measurements are very accurate, precise, and reproducible, so we assign great value to them... however, what we SHOULD value is real world conditions, and give more weight to experience and experiments that measure that directly, even if the results are messy and often inconsistent. In other words, messy and inconsistent data measuring exactly what you want to know is better than clean and tidy data measuring something that may or may not be relevant.
So when you ask me what my methodology is, I don't mind saying that it is simple subjective feel..... but it is subjective feel of the exact thing I am interested in (how fast I roll on the tires). And i will take that over high quality results from an experiment testing something else for which the relationship to what i want to know is unclear.
For all the drawbacks, Roll down tests like you describe are IMO far, far more useful than roller drum tests for determining a rank order for tires RR in various real world conditions.... because it IS real world conditions. And if properly designed roll down tests on various surface conditions confirm the ranking that roller drum tests indicate (including Bon Jons) I would accept that.
Kapusta is offline
Old 10-15-18, 05:49 AM
  #105
tablatom
Bikes: Boardman Team Hybrid, Boardman Team CX, Voodoo Bizango, Pinnacle Lithium 4
Quoted: 27 Post(s)
I don't race, not really interested in time while riding, but more out of curiosity I timed several routes where I live up to 5 times with the same and different tyres, from shopping trips with lots of cargo, to single track, and taking the average times,
my conclusion is very simple.
The rougher the conditions fatter tyres will always be faster.
I have tried many Tyers with the same routes.
In dry conditions, Schwalbe Big Ones are mega fast, and incredibly comfortable.
The Big Ones were faster than 2 gravel tyres (conti Cyclocross speeds and WTB Nano's 40c) no matter the terrain in the dry. Wet grass and mud, obviously the gravel tyres would win. But on gravel, unless you need to ride like a nutcase, the Big Ones do just fine in the wet.
I was using one as a rear tyre before it got real wet and muddy in here in the UK, for shopping/school trips. The 2.35 size and semi slick is a very fast comfy rear tyre.
But now its October, mud everywhere, thats not tarmac, a G one Allround 29 x 2.2 is going on the back, and Maxxis Ardent 2.4 or 2.35 Ikon on the front.
This combo is fast, secure and very comfortable for most riding.
tablatom is offline
Old 10-15-18, 12:04 PM
  #106
Spoonrobot
Spoonrobot's Avatar
Quoted: 954 Post(s)
Your post was helped clarify what I wasn't understanding and also raised some interesting points. Have you seen the more recent Bicycle Quarterly testing? I have my own issues with their testing but it does help provide a rounder, more real world viewpoint. I also found this test extremely interesting from a few months ago: https://www.velonews.com/2018/06/fro...-gravel_468329
It uses purely PSI which is less than ideal, but as far as real world dirt roll down testing it's one of the few I've seen. Without reporting sag numbers as a reasonable facsimile to suppleness there's still a massive blind spot.
I work on subjective feel myself from time to time. I have a mountain bike tire I rode recently, it's a tubeless version of non-tubeless tire I rode and really like previously. The tubeless version requires 40% less pressure to reach the same level of sag and even then rides so stiff and harsh it is causing issues with my hands. However it tests about the same as the non-tubeless version when I did my run down tests. I'm still processing this but it's added another wrinkle to think about, for me.
Anyway I think this ends up being I was making additional extrapolations whereas you'd like to see the data/testing. Makes sense.
Old 10-15-18, 01:25 PM
  #107
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6724 Post(s)
Liked 140 Times in 118 Posts
heat is energy lost
for the ones not OCD & in computer software writing..
Generically
the slick tires roll better on paved roads ,
the tread blocks there for dirt traction lose energy squirming as they roll ..
Friction creates heat.
fietsbob is offline
Old 10-22-18, 11:22 AM
  #108
chas58
chas58's Avatar
Bikes: too many of all kinds
Quoted: 676 Post(s)
Liked 29 Times in 23 Posts
Wow, this is an OLD post. Still good for starting an argument though!!!
I anecdotally find that matching the depth of my tread to the roughness of the surface works out well. (roughly analogous to shoota's graph above).
I ride short knobs on shallow gravel and hard pack
I'll ride deeper knobs on softer and rougher terrain
Riding slicks in ideal conditions is amazing (i.e. velodrome), but deteriorates rapidly as the surface deteriorates)
Big Ones are easy to ride at 15mph. Above 20mph the weight (on rolling hills) and aero make them difficult to spin up in near race conditions.
Generically
chas58 is offline
Old 10-22-18, 12:15 PM
  #109
Kapusta
Cyclochondriac
Quoted: 879 Post(s)
Shoot, I want to see that, but the page it brings me to has one short 39 second video with an explanation of the roller test design, but no indication of how to access the rest of the article.
Kapusta is offline
