What unlikely tools or products do you keep in your bike repair/restoration toolbox?
We all use things off-label when we discover they work really well for an unintended use. What do you all keep in your bike repair toolkit that wasn't intended for the way you use it?
I'll give an example:
Nail polish - I keep clear UV-resistant nail polish base coat as an all-purpose sealant for protecting decals and for coating rusty hardware after oxalic acid treatment and cleanup. It does a great job at preventing rust from re-forming on flaking chromed parts.
Likes For southpawboston:
Quoted: 3015 Post(s)
Liked 3,792 Times
I don't know if it is unusual, but I have several X-Acto knives throughout the house and work. Downstairs toolbox. Garage toolbox. Work-at-home desk. Pen cup next to this computer. Desk at work. Several in the toolbox at the lab at work.
Cutting, cleaning, positions things. Can't imagine doing a job without them.
Likes For iab:
Quoted: 1106 Post(s)
Liked 1,326 Times
I asked my dentist and she said "Sure" and shoved a box full of old picks at me - lifetime supply. They're awesome for cleaning crevices like fine threads and bearing-seat corners and stamped/engraved details, and you can grind their tips for special purposes.
Often used with loupes - get one if you don't have one, they're great for checking bearing races and looking for cracks. A cheapie will do fine.
Supermagnet - stick it on the screwdriver shank somewhere near the tip; reduces swearing.
Likes For oneclick:
Quoted: 3806 Post(s)
Liked 6,674 Times
Something I learned here: feeler gauges to use as metal shims. Cheap and effective.
Likes For nlerner:
Quoted: 873 Post(s)
Liked 2,279 Times
I am a tool grinder by trade so I always have my “Optivisor” handy. I also use dental picks and very small bottle brushes.
Likes For Kabuki12:
Ha, that's a great idea for when you need to dial in just the right thickness. I keep a few small aluminum and brass sheet stocks of different thicknesses as shims, I get them at Blick Art Supply, but it's not always possible to dial in the right thickness!
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3877 Post(s)
Liked 6,466 Times
Rubber nipples in assorted sizes. You just never know.
Quoted: 4510 Post(s)
Liked 6,377 Times
Because every fixed cup always comes out, period.
Likes For merziac:
Hoards Thumbshifters
Bikes: '23 Black Mtn MC, '87 Bruce Gordon Chinook, '08 Jamis Aurora, '86 Trek 560, '97 Mongoose Rockadile, & '91 Trek 750
Quoted: 246 Post(s)
Liked 334 Times
Dental picks! Also I have an older couple of thin walled sockets in 14mm, 15mm that can remove old crank bolts. Most sockets these days are too thick for it.
Edumacator
Quoted: 2436 Post(s)
Liked 3,118 Times
Medicine dropper and dawn...
Mad bike riding scientist
Quoted: 6212 Post(s)
Liked 4,210 Times
I keep a bearing cup, a large fender washer (or 2), an crank bolt, or crank nut (depending on the spindle) on hand. They all hold the fixed cup wrench in place and is a bit more refined than merziac’s method. I also remove the fixed cup first with this tool. I found that works better than doing the adjustable cup first.
Other items I use: A syringe and basting needle for injecting water under grips to slide them off. I also have a spoke with a sharpened tip as a pokey tool. As we say at my co-op, it’s for “poking stuff”. I also have empty Gatorade bottles that I use to clean chains. I put in mineral spirits, the chain, agitate for 30 seconds or so, and then fish out the chain. The chain comes out clean as a whistle.
Stuart Black
Stuart Black
Likes For cyccommute:
Liked 1,326 Times
WD40 aerosol works a treat; the trick is slide the little red tube in by itself, then attach and squirt.
A ball of butchers twine I stole from the kitchen and never returned (my wife is vegetarian, so I don't get to use it that often anyway!), I prefer it zip ties for lashing things together temporarily.
I've also have a basting needle from the kitchen (again, vegetarian wife) which I've used as pick/small drift pin.
SE Wis
Quoted: 2743 Post(s)
Liked 3,390 Times
Old toothbrushes.
Likes For dedhed:
Space Ghost
Bikes: Bridgestone, Fuji, Iro, Jamis, Gary Fisher, GT, Scott, Specialized and more
Quoted: 292 Post(s)
Liked 412 Times
Lineman’s pliers and pipe cutter, and instead of dental picks I use these cheap sculpting tools I upgraded from many years ago.
I use this syringe with luer-lock fitting from a lab HPLC for adding oil to a Sturmey Archer IGH.
Liked 4,210 Times
Stuart Black
Stuart Black
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 529 Post(s)
Liked 999 Times
Likes For Pompiere:
Quoted: 3241 Post(s)
Liked 2,512 Times
A couple of nickels for adjusting brake calipers/pads.
Likes For seypat:
Quoted: 887 Post(s)
Liked 335 Times
An awl, a larger version of the spoke "pokey tool" for rounding crushed ends of cable housing. Bits of left over inner cable to insert into housing when I cut it so I don't need to use the awl.
Likes For dweenk:
Yeah, a simple scratch awl is an oft-used tool in my shop. In a pinch it can also deburr drilled holes. I used to use it for cable ends too, until bought a Pedro's housing cutter with built in awl for that purpose.
Likes For billridesbikes:
Quoted: 1607 Post(s)
Liked 2,216 Times
OK well I have an air compressor that is very handy. Like removing grips or putting them on. Just stick the nozzle under the rubber and the grip floats off.
Likes For SJX426:
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,830 Times
Would 3.5mm hex for Campi Delta brake maintenance count as unlikely?
Or those tiny hex sizes for some vintage tt cable guide bolts.
My father's vintage screw clamp (with rag covering metal surfaces) makes a great '3rd Hand' brake holding/repairing tool. One clamp fits all brake sizes.
Liked 6,674 Times
I keep waiting for someone to say a condom. Hopefully, not a used one.
