Does anyone use a single-speed as their main cruiser?
#52
I don’t know either. Can you send me links?
#55
Bikes: There is always room for one more.
Quoted: 188 Post(s)
Liked 396 Times
I've done this for a couple of cruisers and it is a worthwhile upgrade. Here is a video that shows you what you need and how to do it yourself if you are so inclined:
BTW: If you change the size of your chainring you will have to adjust the length of your chain accordingly.
Don
Don
Last edited by GeezyRider; 07-03-23 at 01:30 PM. Reason: Make an additional point.
Likes For GeezyRider:
#56
Greezy did you install that exact type of conversion?
before I did mine I was looking reading figuring out if I would use the square taper type in the video of the bmx type that I decided on.
the common opinion was that square tapers are more likely to come loose than the bmx style. Also from what I can see all designs for the integrated stuff is pretty much the same concept. Of having the crank arm wrapped around the shaft instead of attached to the end of it.
I also never had to use a hammer to install them
i put the adapter cups on the stove on low heat. Waited until a drop of my spit would sizzle on the cup and then pulled the bearings out from the freezer and dropped it right in the adapter cups.
then took a torch to the bb she’ll for a bit. Ran inside to pull the adapter cups with bearings installed out from the freezer and dropped them right in the bb she’ll. No hammering for the install.
Likes For AtNjineer:
#58
Quoted: 188 Post(s)
Liked 396 Times
Don
Don
#59
like i said though the bmx style would be less likely to come loose. As it’s design veers more toward the new designs that you see on the higher end stuff.
#60
Live not by lies.
Bikes: BigBox bikes.
Quoted: 860 Post(s)
Liked 784 Times
#61
Yes correct that one
it’s center/inner diameter is 19mm
and the Sunday cranks are 19mm to match. If you don’t use Sunday cranks it’s fine you just have to match that ring size with whatever shaft size you get.
its purpose is to center your current sprocket with 23.8 center/inner bore to sit plum on the 19mm shaft
#63
https://www.youtube.com/watch?v=7xTJ4ZmWmU8
@AtNjineer, I think get your point about the BMX type bottom brackets. My spare crankset with the oval rings is now on a square taper BB. But I don’t mind changing over if it’s more robust. I hope my guy can help, if not I’ll have to look around. I may ask Mark Stonich (Bikesmith) for tips - he’s been making my cranksets and installing the oval rings for me.
#64
#65
The list of products I shared with you. Is specifically for you to reuse your current steel front sprocket.
if your dead set on using your oval chainring you will skip the adapter ring and use the parts mentioned in the video geezy shared.
but* if your oval chainring is 5 bolt 110bcd then skip the adapter ring and get the spider adapter also made by profile racing
I’ll soon have one myself because I want to put a larger aluminum chainring instead of my current steel 46 tooth
#66
For short cranks, my LBS guy said he could get 6" one-piece (152.4mm) cranks. To keep the gain ratio approx. the same, I'd have to change the Sun's 42T chainring to a 38T or 36T with the one-piece crank. I say this because the short cranks are very important for my knee health. They make more of a difference than the oval ring. I'll talk to my LBS mechanic, show him the video Geezer posted.
ALSO, if I really like this bike's setup -- if I can ride comfortably -- then what I want to do is find a fabricator and get a custom done. Then I'd invest to make sure it has the best BB and chainring options I can find. I've seen some very cool custroms that have just the overall lines, geometry and ergonomics I want. I'm too old and too stiff to fit on a wide variety of seat heights, pedal angles, bar-reach distances, bar heights, etc. Even though I stretch and warm up every day for at least one hour. Luckily for me, there are some pretty cool-ass builds that fit my body's ergo needs....
Thanks for the great info @AtNjineer and @GeezyRider !
#68
One piece cranks are so slow and inefficient but I’ve learned not to suggest that people preferences are wrong.
Most cranks for 24” cruisers are “6
if it’s true what you said that your chainring assuming you were referring to your oval one is 5 bolt 110bcd
then your good to go just get the spider adapter instead of the adapter ring. Then you can still do the three piece conversion. With the oval ring*
you have your lbs with their ideas
and you have me with the experience
lol
lol
#69
IMO any adjustments to the ratio because of the difference in crank length can be made at the rear cog.
#70
Lol, maybe you can meet me at my LBS next weekend! :-)
Likes For NYLowLife:
#71
Not your fault weirdly enough it’s not on the profile racing site
https://www.danscomp.com/profile-rac...xoC_HUQAvD_BwE
bike shops don’t like me and I don’t like them. Their always telling me I can’t/shouldn’t or its not worth me doing what I want to do. Then I still figure it out.
all these products I’m sharing with you are totally new to me as well. I just learned about the spider a few days ago. Happy to have found it too bc it’s perfect for what I plan to do and perfect for what you want to do
#72
Bikes: a couple
Quoted: 563 Post(s)
Liked 868 Times
A bb adapter is deriguour for cruiser conversion applications like yours.
#75
I was having aches and pains from the Sun cruiser's original setup. Amazing that a cruiser-style setup could ever be uncomfortable, but that's these old bones. Just had my 70th birthday this week. The comfort issue was putting my plans for investing in a 3-pc crankset on a back burner. My butt and wrists and knees were hurting - so much so, I was wondering whether I'd have to end up selling this bike. I needed a more "aft" position, a better saddle and higher bars.
So I put on a laid-back seat-post, a Brooks B33 saddle and some ape-hangers. Now, I gotta tell you - it's got the ergos these old bones need. It's a joy to ride! Next will be better looking grips and pedals, and a front brake. I do love simplicity, not crazy about cables. But I ride in a fair amount of NYC traffic before I get to relatively car-free places... After that, I'll return to the crank question.....
