1973 Paramount: Stuck Bottom Bracket Cup
Bikes: I hate bikes!
Quoted: 431 Post(s)
Liked 710 Times
I got this frame from Cudak888 a couple of weeks back, in the great purge of 2012. The frame had been repainted and the bb re-threaded Italian from English. I gave the frame a preliminary strip to make sure some of the surface rust was not a big deal. It is not.
[IMG][/IMG]
I let this cup soak in PB Blaster for a week, before going at it with the standard fixed cup removal tool. No dice. So I held the tool in place and hit the end with a hammer. No luck and the tool was destroyed in the process. I then tried the Sheldon brown home brew method and that did not work. Then I put the cup flats in a a bench vise and tried to use the frame as leverage. Nope. I took it to the LBS and they had the pro level Park tool and even with a 3ft cheater bar, the cup would not budge. Is this thing hopelessly stuck? Can I use a torch to heat it and break the bond? Any other ideas?
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Vello Kombi, baby
Bikes: 1973 Eisentraut; 1970s Richard Sachs; 1978 Alfio Bonnano; 1967 Peugeot PX10
Quoted: 80 Post(s)
Liked 14 Times
GO with heat, the sheldon tool, and a cheater bar. The fixed cup may have been loctitied in (it is Italian, and this is a common poor mechanic fix). I helped a local shop with a Holdsworth that had been retapped in the same manner. Whoever had done the job had red loctited the drive side cup on (I say drive side because the prior 'mechanic' had not only resorted to red loctite, but had reversed the cups, so the fixed cup was on the non drive side. Go figure). And get someone to help, it's a two person job.
"It's always darkest right before it goes completely black"
Waste your money! Buy my comic book!
incazzare.
Since you're not worried about the paint, heat seems to be the next thing to try.
1964 JRJ (Bob Jackson), 1973 Wes Mason, 1974 Raleigh Gran Sport, 1986 Schwinn High Sierra, 2000ish Colian (Colin Laing), 2011 Dick Chafe, 2013 Velo Orange Pass Hunter
Quoted: 413 Post(s)
Liked 109 Times
Why does your British threaded frame have an Italian cup in it?
Try this thread: https://www.bikeforums.net/showthread...ht=fixed%20cup
Add heat as needed.
Add heat as needed.
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,398 Times
This is what I use to ensure that a Park HCW fixed cup remover doesn't slip off and get rounded out when pounding on it. It's guaranteed to work:
Alternately, you can simply run a bolt through the cup and use a washer larger than the cup to keep the tool in place. Tighten it down, and hammer the tool as hard as possible.
-Kurt
-Kurt
Liked 4,398 Times
Stausty told me that it was like that ever since the previous owner had it. Someone had it tapped to Italian very early in the game.
Fender, mind if I use that headlug photo? I'd like to put that on The Headbadge to show that chrome-lug Paramounts are not all-chrome underneath the paint.
-Kurt
-Kurt
incazzare.
Possibly original English threads got destroyed, so it was tapped out to the larger Italian size? Someone suggested that earlier, sounded likely.
Quoted: 5 Post(s)
Would have been nice if you told him it was stuck before you sold it to him. We all get that stuff is used and somtimes things don't work out to our advantage, but you knew that cup was stuck. Don't worry about flipper karma, worry about real karma.
Bikes: '73 falcon sr, '76 grand record, '84 davidson
Quoted: 59 Post(s)
Liked 22 Times
are you preparing the frame for paint? why remove the fixed cup? does the shell need to be faced for some reason?
Cat 6
Quoted: 500 Post(s)
Liked 183 Times
Uh, are you turning it the right way? This is Italian now.
But, as stated earlier, they may have locktighted it in, in which case it may be the heat-removal variety.
72 Frejus (for sale), Holdsworth Record (for sale), special CNC & Gitane Interclub / 74 Italvega NR (for sale) / c80 French / 82 Raleigh Intl MkII f&f (for sale)/ 83 Trek 620 (for sale)/ 84 Bruce Gordon Chinook (for sale)/ 85 Ron Cooper / 87 Centurion IM MV (for sale) / 03 Casati Dardo / 08 BF IRO / 09 Dogma FPX / 09 Giant TCX0 / 10 Vassago Fisticuff
Friendship is Magic
Bikes: old ones
Quoted: 26431 Post(s)
Liked 10,391 Times
for photos, see
https://www.bikeforums.net/showthread...l#post11769729
If you can get one, a mechanic's dead blow hammer is the one to use.
Edit:
The Sheldon tool, as well as the commercial fixed cup tools, all
work by friction, thus some of your impact advantage is lost in
the hammering......If this is Italian, thus RH threaded, a
regular fixed cup removal tool is a poor choice anyway.
-Kurt
-Kurt
Good to know the rust is just a surface problem. I have a 50th Anniversary frame from the same source as this one that had very similar rust and paint chip issues.
Is it too early to just cut the cup out?
Liked 4,398 Times
I want to see you to provide irrefutable proof that I deliberately tried to fraud Fender1 if you so see it fit to publicly accuse me of it.
FYI - If Fender1 wants to return that Paramount for a full refund of purchase + shipping price, I'm ready to do so. Where are you going to find a fairer deal than that?
-Kurt
Friendship is Magic
Bikes: old ones
Liked 10,391 Times
Old fart
Quoted: 3593 Post(s)
Liked 3,401 Times
Campagnolo cup deserves the proper Campagnolo tool:
Quoted: 5 Post(s)
Way to totally sell out stausty and take no personal responsibility, but we have come to expect that from you. Stausty didn't sell the frame to Fender, you did.
It would have been nice had you asked me if I had even attempted to take the cup off in the reasonably short time frame that I bought the bike (answer = no). Perhaps you can do your premature finger pointing at stausty and see how he likes it, seeing that he sold me the frame with the fixed cup still installed in it (for the record, I'm not blaming him either).
For the record, I had planned to install an Italian Campy BB cup on the other side, so it never occurred to me to pull the cup off in the first place.
-Kurt
P.S.: Seeing how you're so cocksure that I deliberately attempted to fraud Fender1, the only person who should be worried about bad karma is you.
-Kurt
Liked 4,398 Times
Read my revision - I'm willing to take back that frame for a full refund if Fender1 isn't satisfied with it.
Provide concrete examples for this claim. If you feel obligated to attack me in public, I want to see provable facts that stick.
-Kurt
Quoted: 5 Post(s)
I just don't have the time to search through 23,000 plus posts .
Myself, I'd be inclined to take a torch to it instead, it's really the only thing that'll get red loctite to let go. There is a loctite remover or something but I think it only works on the blue stuff.
Quoted: 2340 Post(s)
Liked 2,833 Times
+1 .................This is what I do, and have not met one yet that will not come out.
for photos, see
Edit:
for photos, see
Edit:
Vello Kombi, baby
Quoted: 80 Post(s)
Liked 14 Times
Silly me. I thought this thread was about a stuck BB cup, which I maintain is probably loctited, quite likely with too strong a loctite. Heat and a cheater bar, plus a gorilla on loan from the Philly zoo, should remove it no problem.
In the interest of thread drift, I will say I would gladly deal with Kurt, but he must substantially lower the price of the PY should he wish to achieve this serendipity.
Also, I would like to say the Campy tool pictured above looks wimpy next to the proper Var tool.
Flame away, gentlemen, Just on the bottom bracket shell of the above Paramount.
incazzare.
This provides me with another chance to use my favorite image:
Friendship is Magic
Bikes: old ones
Liked 10,391 Times
Auto mechanics use impact wrenches for a reason. The sudden
sharp impacts have a positively magical effect on stuck and
corroded threaded joints. When you set this up with either
Kurt, or my setups, you have the advantage of a poor man's
impact wrench........
I have only used one commercial fixed cup tool, and it really
did not work well in either direction, so perhaps i spoke prematurely.
I have tried the sheldon tool, also, and for my case, it didn't
work worth a **** (apologies to the memory of Mr. Browne, from
whom I have received much good advice in the past.)
I think I'm gonna go now, because I see a storm brewing
on the horizon, and I intend to seek shelter........
Bikes: '53/'54 Bianchi CDM, '62ish Altenburger Cinelli Mod B, '69 Rene Herse Competition, '72 Motobecane Grand Record, '73-74 Colnago Super,, '73-74 Cinelli SC, '78ish counterfeit Confente, '82 Medici Gran Turismo, '67ish Mondia Speciale, Eddy Merckx Pro
Quoted: 90 Post(s)
Liked 257 Times
