2nd Wheel-set has 10 spd, vs primary wheel-set with 9spd
Old 02-21-19, 06:25 PM
loubikes
loubikes's Avatar
Bikes: Bianchi Volpe 2001, Bianchi Brava, Bianchi Mondiale
Quoted: 29 Post(s)
I have a Bianchi Volpe with a Shimano, 9 speed drive train and indexed trigger shifters. I use it for commuting and have slick tires on it.
I've wanted a 2nd wheel-set that I could keep gravel tires on and swap the wheels out depending on what I'm doing.
A wheel-set, with the correct internal width (19mm) and axle spacing (130mm) came up on craigslist for $50 and they were in good shape. They came with a Shimano, 10 speed cassette.
What are my options?
  1. Can I just put it on and expect that the shifter won't be able to access one of the cogs but otherwise work ok?
  2. Will my 9 speed chain work with a 10 speed cassette?
  3. Can i get a 10 speed chain for both the 9spd and 10spd?
  4. Can i switch the 10spd cassette for a 9spd cassette?
  5. Can I switch my 9spd to a 10spd (least desirable because I'd have to change my shifters).
What is my easiest/best option?
THANKS!
loubikes is offline
Old 02-21-19, 06:42 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
make them the same..? share 1 9 speed cassette with both wheels, remove the lock ring and put it on the other driver,
or get a 2nd chain and swap it with the wheel , so they stay together....
fietsbob is offline
Old 02-21-19, 06:48 PM
rhenning
Quoted: 380 Post(s)
Liked 106 Times in 80 Posts
If the hubs/wheels are slightly different you also need to re index the system each time you change the wheels. I hope you are lucky and you do not have to do that. Roger
rhenning is offline
Old 02-21-19, 06:55 PM
caloso
caloso's Avatar
Quoted: 2952 Post(s)
Liked 3,106 Times in 1,417 Posts
The answer is 4. Buy a new 9-speed cassette for the new set of wheels.
caloso is offline
Old 02-21-19, 07:03 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1795 Post(s)
Liked 1,269 Times in 876 Posts
+1
With larger "gravel tires", you may want to change your gearing slightly.9 speed cassettes come in a wide variety of combinations.
Just make sure your chain is long enough for the largest cog.
Bill Kapaun is offline
Old 02-21-19, 07:07 PM
caloso
caloso's Avatar
Originally Posted by Bill Kapaun
+1
With larger "gravel tires", you may want to change your gearing slightly.( speed cassettes come in a wide variety of combinations.
Good point. I have two sets of wheels for my CX bike: Lower low gear on the knobby set than on the commuting set.
caloso is offline
Old 02-21-19, 07:11 PM
tyrion
tyrion's Avatar
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times in 972 Posts
You can get a 11-36 9 speed Microshift cassette for $17.
tyrion is offline
Old 02-21-19, 07:14 PM
loubikes
loubikes's Avatar
Quoted: 29 Post(s)
Thanks, this makes the most sense to me. I thought I had read at some point while googling that while you can normally upgrade from 9 to 10, you can't always go from a 10 to 9. Know if there are any occasions for which this might be true? It is a Shimano 105.
loubikes is offline
Old 02-21-19, 07:24 PM
caloso
caloso's Avatar
For indexed systems, the number of indexes of the shifter has to match the number of cogs on the cassette. Otherwise, they won't line up properly. You might get lucky with a few gears, but not all. So in order to convert to 10-speed, you would have to buy new 10-speed shifters. (You might get away with with your current derraileurs).
But there's nothing wrong with 9-speeds. Best shifting group I ever had was 9-spd DA 7700. So I don't think you'd be gaining much.
caloso is offline
Old 02-23-19, 11:05 AM
zacster
Bikes: Kuota Kredo/Chorus, Trek 7000 commuter, Trek 8000 MTB and a few others
Quoted: 22 Post(s)
Liked 464 Times in 365 Posts
The spline pattern on the hub is the same for all Shimano cassettes (with one exception with DA). You can put a 9 speed on a 10. The only issue may be that you need a spacer behind the cassette, but I'm not sure about that and what size it would be. You want the cassettes on both wheels to line up for the small cog so that your derailleur is always set right. As you go to the larger cogs the spacing will be the same from that point.
zacster is offline
Old 02-23-19, 11:21 AM
sch
Quoted: 303 Post(s)
Liked 136 Times in 104 Posts
IME 9spd chains do not like 10spd cassettes that have single tooth spacing which occurs in the smaller cogs. I tried this once on
my recumbent, chain worked fine where there was 2-3 or more tooth differences one cog to the next but not in the single tooth
area where the next cog up tried to pick up the chain. OTOH 10spd chains work fine with 11spd cassette single tooth spacing
again IME (trying to work off a collection of cheap KMC 10spd chains) and 10spd chains work fine with 9spd cassettes.
Otherwise agree with posters suggesting 9spd cassette.
sch is offline
North Coast Joe
Bicycle Mechanics
9
03-12-18 10:17 PM
bbbean
Mountain Biking
3
10-15-13 06:49 PM
samlochner
Bicycle Mechanics
10
05-09-13 06:51 PM
xfimpg
Mountain Biking
23
11-24-11 07:22 AM
aaronmichael
Road Cycling
23
01-18-11 06:11 PM
