Zefal Frame Pump Question
Bikes: Trek Domane SLR 2019, Trek Trek Madone 5.1 (2011), Trek 1400 (1991)
Quoted: 47 Post(s)
Liked 74 Times
I got a '91 Trek 1400 and I would like to get a full size frame pump for it. I like the Silca pump, but man oh man $165 for a pump. Not going to do it. The alternative is the Zefal HPX, which I'm considering. My question is; does the Zefal pump handle have a nest for the head tube pump peg?
If anybody has a alternate recommendation for a full size frame pump, I'm open to suggestions.
Quoted: 174 Post(s)
Liked 177 Times
Likes For Ross520:
Expired Member
Quoted: 3674 Post(s)
Liked 5,431 Times
Yes, at least they did in the past. I have several but none newer than 15 years or so. FWIW, even properly sized, mine would not reliably stay attached below the top tube. I had to add a velcro strap which gave the thing a kluge look.
Likes For shelbyfv:
Quoted: 47 Post(s)
Liked 74 Times
I looked Lezyne pumps but I didn't see a full size pump, only mini pumps.
Quoted: 47 Post(s)
Liked 74 Times
Yeah in the same boat, haven't bought a frame pump in years. I remember when Silcas were made of plastic and you could easily paint them to color match the bike.
Quoted: 1819 Post(s)
Liked 1,693 Times
I own 4 Zefal HPX frame pumps. Yes they have an indent for a pump peg. 2 of my bikes have pump pegs on the head tube and the correct length Zefal HPX fits nicely under the top tube of those bikes
Mine fit well enough that no strap is needed to keep them in place, you just have to have the correct length
Likes For alcjphil:
Quoted: 47 Post(s)
Liked 74 Times
Likes For Buzzkill53120:
Quoted: 1324 Post(s)
Liked 927 Times
Mine has two nylon guides on the pump head, that fit the seatube/toptube junction and then the handle of the pump fits into the umbrella clip/cup.
Cheers
Cheers
I think I know nothing.
Quoted: 233 Post(s)
Liked 290 Times
Likes For Thomas15:
Bikes: Current: 2016 Bianchi Volpe; 1973 Peugeot UO-8. Past: 1974 Fuji S-10-S with custom black Imron paint by Stinsman Racing of PA.
Quoted: 215 Post(s)
Liked 204 Times
I am a full size frame pump fan. They pump up higher with less strokes. I use both Silcas and a Zefel HPX. The SIlcas are old (35+ years), but still work, but are now hard to find, unless you buy the new improved version. The old ones are plastic bodies and the new once are are aluminum. They work very, very well.
The Zefal also works very well. I use it on my new Bianchi, as the Silca from my older bike mounted against the seat tube and is a bit too long (new sloping Top Tubes shorten the seat tube). The Silcas do not have the lever on the chuck which I prefer, but the Zefal's is not a problem. I only use Presta valves, although the Zefal can be used for Schraeder valves also if that is an issue. THey are alleged to come in silver or blacx, but I have not seena silver one in years. Mine is black. The Zefal handle is contoured to the frame tubes if you want to mount on the seat tube. On the seat tube, it does not need a peg, and is easier to carry the bike, but you loose a water battle mount..
Measure carefully as the Zefal comes in 4 sizes.
My recommendation - Zefal, but if price is not an issue go Silca. I always take my pump with me if I park the bike, no matter which one it is.
Quoted: 4806 Post(s)
Liked 3,928 Times
... THey are alleged to come in silver or blacx, but I have not seena silver one in years. Mine is black. The Zefal handle is contoured to the frame tubes if you want to mount on the seat tube. On the seat tube, it does not need a peg, and is easier to carry the bike, but you loose a water battle mount..
Quoted: 215 Post(s)
Liked 204 Times
I would go for the new black model. I know Rivendell has them.
This website may have older versions and possibly even some old Silcas, but not cheap. Call or email them first as they get stuff from many sources.. https://www.yellowjersey.org/hpx.html.
Zefals come in 4 sixes. If you get a size, get the largest one that will fit so it is compressed more and under more spring pressure and therefore more secure over bumps and road vibrations.
#1 - I could not find info on this one.
#2 - 40cm - 46cm (15.75" - 18.1")
#3 - 46cm - 51cm (18.1" - 20"
#4 - 51cm - 56cm (20" - 22")
Remember this is from the surface of the frame tubes (seat/head tubes or top/down tubes) where the pump contacts.
Bikes: Gitane Course, Paris Sport, Peugeot AO8, Peugeot Bretagne, Peugeot Premiere 85, Peugeot Premiere 86, Peugeot ANC Halfords Team Replica, Peugeot Festina Team Replica, Motobecane Grand Sport, Motobecane Super 15, Raleigh Pro Race, Raleigh Stratos, BSA
Quoted: 117 Post(s)
Liked 427 Times
I've got a Zefal REV88 on my Peugeot AO-8. It's got holes for pump pegs at both ends and is completely secure on the bike.
Quoted: 874 Post(s)
Liked 2,288 Times
I have both Silca and Zefal pumps on my vintage racers. They are both good pumps but the Zefal is slightly better for getting tires to full pressure.
Half way there
Quoted: 986 Post(s)
Liked 880 Times
You won't go wrong with a Zefal. I'm not sure why Silca Impero pumps cost so much. I have 3 of them bought in the 1980s and every one of them has self destructed within five years. It was either the pump head that cracked or, on one pump, the body that the head attaches to cracked. Perhaps they've improved since then, but they would have to pump themselves for me to spend that much money. Some folks equate price with quality and the market exploits this.
Expired Member
Liked 5,431 Times
Zefal HPs
Somehow I've accumulated a few. They seem to be the two smaller sizes. The two smaller ones pump well, the larger ones not so much. Maybe cannibalize? Anyway, I'm happy to pass them along for cost of shipping. Apparently the umbrella clips, etc have been lost.
Quoted: 215 Post(s)
Liked 204 Times
Correct, you will not go wrong with a Zefal.
Liked 927 Times
How many bicycle pumps do you know of that can be run over by a car and still work or repaired to work for many years more?
I had a Zefal HP pump that had been run over and and partially flattened by a car. That was at a bike shop where the customer bought a new Zefal HP pump and told the shop to trash the damaged one. They gave it to me when I asked them for it. I took it home, got an appropriate diameter wood dowel and chamfered the end of. Then I lubricated the inside of the pump barrel and the outside of the dowel. I then tapped the dowel down into the barrel of the pump twisting and removing the dowel at intervals so it'd not get stuck. The next day I took that repaired Zefal pump back to the shop and showed it to them. They were absolutely amazed to see it brought back to life and working again. they even tested it to make sure it was functioning. I had that pump for years afterwards.
Cheers
Cheers
Likes For Miele Man:
Quoted: 215 Post(s)
Liked 204 Times
Cheers
Cheers
Liked 927 Times
I have a Zefal HP and a Zerfal HPX but I need the insides for the pump heads. I think Zefal still makes and sells those bits. I should really order them.
Cheers
Liked 3,928 Times
Cheers
Cheers
Ben
