My E+ review
My E+ review
Old 05-08-20, 10:14 PM
  #601
wrandyr
Quoted: 9 Post(s)
Liked 5 Times in 5 Posts
ERR1=battery communication problem (battery disconnected)
wrandyr is offline
Old 05-09-20, 05:43 AM
  #602
powell
Bikes: E+ kit, BIONX
Quoted: 58 Post(s)
Liked 10 Times in 7 Posts
JLV
Before I answer...
are you there to read my answers?
I had at least 2 instances in this thread that person who asked for help just gave up and desnt bother to answer.
powell is offline
Old 05-11-20, 05:59 PM
  #603
JLV@
Bikes: (2) EMS E1+ 1000 watt 36 volt
do you still have e+ bike parts
JLV@ is offline
Old 05-11-20, 06:04 PM
  #604
JLV@
Originally Posted by powell
JLV
Before I answer...
Sorry, I am very interested in your answers and your help
JLV@ is offline
Old 05-12-20, 02:18 PM
  #605
powell
Quoted: 58 Post(s)
JVL
BTW it would be nice to know your name and location.
I understand you did conversion and connected non-EPLUS battery according to my schematics.
It had been said before but once again:
Display/contr. is a master and motor electronics and batt electronics are slaves.
whan you press POWER button you initiate communication protocol called RS-485 , simply disp/contr. sends enquiry to batt electronics and next to motor electronics.
ERROR1 means no successful attempt by disp/contr. to comm with battery electronics.
your problem is faulty processing board of batt electronics. batt electronics consists of upper and bottom boards: processing /also called control/ upper and power board below.
as it was said many times in this thread: disconnecting EPLUS battery from electronics is kind of tricky if done in a hurry and by not careful person.
it takes only miliseconds to damage upper board by causing short.
boards and terminals MUST be wrap with electrical tape and Allan key wraped before touching boards with tools.
main processor on upper board rarely gets damaged and such board can be repaired
Miroslaw
powell is offline
Old 05-12-20, 02:20 PM
  #606
powell
Quoted: 58 Post(s)
I repaired one control board by replacing tranceiver chip
powell is offline
Old 05-13-20, 05:19 PM
  #607
JLV@
Hi, This is Jack again. I was wondering if you received my email.
JLV@ is offline
Old 05-14-20, 04:37 PM
  #608
powell
Quoted: 58 Post(s)
Jack
you sent Yahoo email to me??
I mean how did you get my email?
Miroslaw
powell is offline
Old 05-14-20, 05:35 PM
  #609
JLV@
Jack
Miroslaw
I'm responding to you again because I'm not sure you get my messages. I'm not new to emails but, I am still trying to navigate around the forum and I really am not familiar with how it works. I apologize for the inconvenience I have caused. I din't mean to imply I have your personal email. Sorry for the miscommunication. Did you see my post regarding the battery board? Should you want my email or my phone number to discuss my problem I will be more than happy to give them to you. thank you in advance for communicating with me regarding my bike(s),
Jack
I have looked at many of your post regarding EMS E+ bikes and you sure do know them well. I hope you can help me and as I said I will be more than happy to compensate you for your help
JLV@ is offline
Old 05-14-20, 05:45 PM
  #610
JLV@
Jack
Miroslaw
Jack
JLV@ is offline
Old 05-14-20, 08:06 PM
  #611
powell
Quoted: 58 Post(s)
Jack
there are no emails at this forum , you mean personal message??
Ok I will try to send you personal message on this forum.
look up at the top of this page for notification.
I am sure members with few messages cannot send personal messages.
Miroslaw
powell is offline
Old 05-14-20, 09:18 PM
  #612
JLV@
of course we can message on this site. I hope you get this message. I'm really lost on how to message on this site.
Jack
JLV@ is offline
Old 05-15-20, 09:26 AM
  #613
JLV@
Originally Posted by Firedog91902
Sometime ago I got rid of the front wheel and NiMH battery. I moved the battery circuit boards to a protective enclosure and connected LiCoMn tool batteries to provide 36V21AH. Those batteries are charged off the bike on Makita rapid charger. When it worked, it was an amazing ride, but it was plagued by seemingly random #1(display/battery) and #2(display/motor) errors. In trying to track down possible cable or display problems, the display stopped turning on at all. I gave up.
I decided to take one more try. Fortunately, I had a 2nd top battery circuit board. That board fixed the display not turning on. I rebuilt the housing for the battery board so no connection could possibly loosen and nothing physically touching any part of the boards, except the mount screws. I replace the cables between the display, motor and battery boards with a better shielded cable.
I don't want to jinks it, but it seems to be fixed.
A couple of things unique to using batteries not charged through E+'s charge board circuit. The replacement upper charge board came from a bike that had the NiMH batteries charged normally. I showed 80% SOC and 4 bars, even though the batteries mounted were full at 41 volts. After about 8 miles, no bars even though the 21AH battery had discharged less than 25%. On subsequent rides, still no bars. Apparently, the E+ gets it's battery capacity data from the actually AH used to charge the battery. So if the battery is not charged through the battery boards the battery state of charge display doesn't work. Fortunately everything else works and a simple watt meter is a good substitute.
One other issue that may or may not prove to be a problem. In the original E+ design, the battery board always had voltage (battery connected). With my system, the battery is removed for charging and off the bike until it is next used. I seems to me the delay between the display lighting and power to the wheel is longer than I remember with the front hub battery. I have also had at least 1 start up error but unplugging and re-inserting the com cable on the display fixes that the first time.
Powell I haven't heard about that. Is it a delay after LVC or temp problem or something else?
Hi Firedog,
I'm JLV and I'm in southern Ca. I'm new to the forum and I have 2 EMS E+ 1000 watt bikes. I have been following you and Powell's post. You guy really know the E+ bikes. I need some help and advice. I rebuilt the NIMH battery in one of my bikes. Boy, let me tell you that was a challenge! Probably would never have done it if I knew what I was getting into beforehand. I had to drill out the post holding the battery packs together. The post were glued together so they could not be unscrewed. Finally got all the batteries installed properly and on one of last little screws hooking the cells in series I shorted the top board. Yup, when assembled to the bike got error 1 message. Powell told me the chip was bad. You guys seem to be the Gurus of this bike! Anyway I am looking for some guidance and help from the pros. Do you know of anyone who might have the top BMS board or anyone who would be willing to fix it? Powell in one of his post stated the BMS board could be repaired. Maybe, even though I bought over worth $500 worth of Tenergy 10000 ma batteries I should convert to Lithium (I don't know the first thing about how to do it) and chuck the hub batteries. What advice can you give me on this? ANYTHING will be greatly appreciated.
Thanks,
JLV
JLV@ is offline
Old 05-16-20, 09:37 AM
  #614
Firedog91902
Bikes: Univega Superstrada, Serrota, Santana tandem, E plus
Quoted: 18 Post(s)
Liked 8 Times in 8 Posts
Originally Posted by JLV@
Hi Firedog,
Thanks,
JLV
Do you have a good top charge board from the 2nd bike? I don't know if anyone has spare boards. The former employee, Rick, has some parts and knowledge but charges considerably for parts and services. Lots of E+ were sold in S.Cal so whole bikes with dead batteries are the best source.. Some on this forum have several. Some original owners, bought several hubs/batteries when they were available, since rebuilding with new NiMH is so expensive and difficult.
I converted mine to Lithium (with Powell's help) and it's my favorite ride, but it has some quirks. Charging a lithium battery using the charge boards in the front hub won't work as lithium charging is more complex and dangerous. Continuing to use NiMH is too heavy and limiting. I use Li batteries that must be mounted on an external charger (Makita), so the charge boards don't have the continuous voltage they expect. But, the consequences are manageable.....usually an error message when power is restored and the state of charge display doesn't work. Disconnect/reconnect the display ususally clears the error and a simple volt/watt meter gives SOC. Otherwise the bike performs all other functions perfectly. I'll ride and enjoy, but if a charge board, the display or the controller inside the hub breaks, I have to scrap the bike. No parts or documentation. Since I've never been able to open the hub motor I couldn't even use that: bypassing the internal controller replacing with an external one. I've opened and repaired dozens of hub motors, got all the tools but this one stumps me.
My recommendation for you. If you got a 2nd bike with a good top charge board, use it. If not, see if Rick has any. Powell understand circuit board components, maybe he'd look at your board. Have a good EE see if he can find the damage on the board. Please report any successes.
If you get a good board and all works with your new NiMH cells, use the bike. If you need more than 16-20 miles, you can connect a lithium battery in parallel. Before I got rid of the front hub, I connected 36v10.5ah lithium battery in parallel with the NiMH. The bike already has the wiring for a 2nd battery. It worked fine and more than double the range. See earlier post in this thread for details.
If you have a good board, you'd be welcome to drop in. I'm less that 2hrs south in San Diego. Good luck.
Firedog91902 is offline
Old 05-16-20, 10:03 AM
  #615
Firedog91902
Quoted: 18 Post(s)
Powell,
I find posting to this site very frustrating. I logged in, wrote a detailed summary of my successes and the limitations I found in converting the the E+ to a external lithium battery. When I actually "post" the site say I must log in. I log in and my work is gone, never to be found. I'll must remember to copy the post before re-logging on.
I'm riding the E+ considerably and learned to deal with the quirks of not charging Lithium batteries through the charge board. I discussed some in the post to JLV above. One I forgot to mention is regen braking issues. Since the charge boards think the SOC is always near zero, regen engages even if the batteries are full (40V). Not good. I've had the hub wheel jerk, almost lock, when regen engaged with a full battery and then I punched the throttle to go. I don't think the software can properly deal with conditions that were never anticipated. I put a switch on the brake sensor wires to prevent regen and that stops the problem. The truth is I get little benefit for regen on a single bike. Wind resistance slow me enough for my hills and my style. I've turn regen back on occasionally when the battery is down, but I'm still nervous a lock will occur. It was no fun.
Old 05-17-20, 09:31 AM
  #616
powell
Quoted: 58 Post(s)
Jack,
I would follow Firedog advice.
make sure your second Eplus works - powers up normally, throttle works,
next
take second Eplus battery apart , remove control/process board and use it for your project.
for repair opinion I would have to see many pictures of damaged board from many angles and close ups pictures,
it requires high quality camera /in expensive $500-plus cellphone for example/ , cheap, shoddy camera will not show details.
powell is offline
Old 05-17-20, 09:42 PM
  #617
wrandyr
Quoted: 9 Post(s)
Wow, I looked into rebuilding my hub battery, and concluded the tooling needed to pull it off was way too expensive. Gave up on that idea.
wrandyr is offline
Old 05-17-20, 09:46 PM
  #618
wrandyr
Quoted: 9 Post(s)
Goood observation. Regen braking was not supported on the E+ LiPo batteries. I'm looking into following your route with the tool batteries, and I'm glad you pointed this out.
wrandyr is offline
Old 05-18-20, 06:09 AM
  #619
powell
Quoted: 58 Post(s)
Wrandyr
what tooling do you mean? to take front hub apart?
powell is offline
Old 05-19-20, 09:21 PM
  #620
wrandyr
Quoted: 9 Post(s)
Wrandyr
No, putting it back together. If you wanted to duplicate the tabs welded between the batteries with material of the same thickness, a very specialized welder is required. The commonly available welders are not capable. Presumably E+ used thick material because each tab must be able to carry the full load amperage of the system. Calculating the conductivity of the nickel alloy used for the tabs pretty much bears this out. Knowing E+, there was probably some overkill, but it got to the point that the investment needed just to experiment was too much.
wrandyr is offline
Old 05-23-20, 12:26 PM
  #621
powell
Quoted: 58 Post(s)
Wrandyr
do you still plan on replacing NMH cells?
it would be difficult task, I must guess.
I admit I didnt think about it when I was sending you my NMH cells.
so standard round cell welder would not work on rebuilding Eplus NMH pack, not enough power to weld.
ANYWAY
rebuilding original NMH battery with used cells would make little sense to me.
do you still think about Lithium conversion?
powell is offline
Old 05-24-20, 08:19 PM
  #622
wrandyr
Quoted: 9 Post(s)
I was going to use your batteries to experiment with, but the whole thing seems impractical after further study. Yes, I am going to try a lithium conversion, probably with tool batteries. I was hoping to use my LiPo controller board, but it appears to be damaged. (The dreaded ERR01). I have two working hub batteries, albeit with end-of-life cells, so I have something to play with.
wrandyr is offline
Old 05-24-20, 10:08 PM
  #623
theavidrider
nice bike. yet to try an e-bike myself, one day
theavidrider is offline
Old 06-18-20, 06:48 PM
  #624
powell
Quoted: 58 Post(s)
[QUOTE=Firedog91902;21478402]Powell,
QUOTE
Firedog,
I am fully aware of this issue , really - upper processing board stores real SOC of battery , displayed SOC is based on Columb discharge count by main PIC processor PIC16.
since in my conversion charge is done OUTSIDE lower power board /outside EPLUS electronics/ of course PIC16 doesnt know battery is charged and still thinks and displays empty on display/contr.
As a result PIC 16 allows for regen right away.
the thing is
for my Chevy Volt cells EPLUS regen current activated by brake lever is very, very low, unless you use REGEN level 9 maybe, but who would do it right at the begining or ride?
anyway - Cycle Analyst on my EPLUS shows max. -500W returned to battery when I sqeeze break lever , so 500W divided by 43V is ONLY : 11.6 Amps. - really nothing for Chevy Volt cells.
but
I charge to max, max 90%SOC and as I said EPLUS regen current is like nothing for Chevy Volt cells.
If you use tool batteries that is completely different story.
I never noticed any jerk from EPLUS motor bigger than when battery is say 50% depleted.
jerk is exactely same at the beggining of the ride and when battery depleted.
powell is offline
Old 06-18-20, 10:58 PM
  #625
Firedog91902
Quoted: 18 Post(s)
Powell,
I knew choosing negative power level setting adjust regen strength for long descents or as the manual say "to use the E+ as and exercise machine". Give me a break, I get plenty exercise just riding.
Riding in a positive power setting, regen engages when the brakes switch triggers (unless disabled) . Is there also a way to adjust regen strength during normal braking? I can find any mention in the manuals.
