Looking for brake lever, help?
Hey there, I'm currently trying to finish off my single speed bike with a front brake mounted on my flats of my drop bars. I've looked everywhere but it seems that my bars are unusually thin, measuring at 20mm. Am I overlooking something or just not looking for the right levers? They all seem to be 24mm+!
Any help would be great!
Quoted: 1572 Post(s)
Liked 644 Times
So are you in love with the 20 mm handlebar?
How would you suggest shimming it? Something solid, or something like tape?
And I'm not in love with my bars, but they do the job and I want to work with what I have; its just a fun bike to ride around on and do errands, hardly needs expensive components!
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12855 Post(s)
Liked 7,772 Times
Beer can. Cut strips. Gonna take a few layers. 23.8 is typical road bar grip area diameter but many clamps can go a little lower than that.
HOWEVER, I'd look into getting a short pull BMX or olde cantilever-compatible MTB lever. They're made for 22.2 bar diameter.
These are nice, cheap and hinged, so easy to put on.
https://www.universalcycles.com/shop...&category=3304
Quoted: 1074 Post(s)
Liked 295 Times
Measured or listed?
Never heard of a bar with a +24mm grip diameter.
OTOH clamp diameters tend to start at 25.4 mm
Bikes: Bianchi Volpe, ANT 3-speed roadster, New Albion Privateer singlespeed, Raleigh One Way singlespeed, Raleigh Professional "retro roadie" rebuild, 198? Fuji(?) franken-5-speed, 1937 Raleigh Tourist, 1952 Raleigh Sports, 1966 Raleigh Sports step-through
Quoted: 248 Post(s)
Liked 27 Times
The OP is most likely looking for an in-line/cross/interrupter lever. I've seen them in 22.2mm, 23.8mm, 26mm, and 31.8mm, so that they can be mounted on either the "grip" area, or on the clamping area closer to the stem. Sometimes they include shims for fitting smaller diameters...the Origin8 ones, for example, can be shimmed down from 31.8 to 26, and from 23.8 to 22.2.
Quoted: 1627 Post(s)
Liked 630 Times
Cutting a shim from a beer can should work pretty well. Or if you're a Mormon, a [strike]Pepsi[/strike] 7up can will do.
