recommendations for new gravel wheels - under $600?
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4393 Post(s)
Liked 3,016 Times
My 2016 Masi CXGR came with Weinman wheels that keep breaking spokes. The LBS people are telling me that the wheels are cheap and that the repaired and retensioned wheels are not perfectly true and will likely keep breaking spokes. Though I like the bike very much, it's hardly a lightweight performance rig, and so I don't envision spending a huge amount on wheels. I'm relatively new to gravel riding and more familiar with road wheels, so I'd like some advice.
Some considerations
1. Disc, of course
2. I run with 35 mm tires, but would like the option of going narrower (32) and wider (40).
3. Strong wheels with high spoke counts only (for obvious reasons).
4. I've never experimented with tuebless and I'm not really interested. I know most tubeless-ready wheels can be run with tubes, but at this point tubeless isn't a selling point.
I was sort of looking at Velocity A23s, but was wondering if mounting fatter tires on them can be tough? I have a pair on my road bike that i run with 25 mm tires, and tire mounting is a pain. Would it be the same with fatter tires?
Any other suggestions would be appreciated.
Some considerations
1. Disc, of course
To get the thread going.
What is your weight?I'm about 230 lbs and the only spoke I broke in the last three years was cause by a grocery bag.I did not search the Weinman wheels for reviews,But stock wheels are usually heavy and built for abuse.
For about $600 I would go custom,local if they have good reviews.I'm not happy with my custom wheels I bought last year and they are on the other side of the states.That is why I say try local first.
For about $350 or less some good pre-built sets out there when on sale.
Liked 3,016 Times
Anyway, there are several local wheel builders and a couple of shops that make wheels, so local custom built may be the way to go.
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Some considerations
1. Disc, of course
Some considerations
1. Disc, of course
Shimano XT M8000 hubs ($120USD total). H PLUS SON Hydra or Archetype rims ($160ish total). DT spokes ($70USD total). Lace 32 cross-3.
How hard tires are to mount depends on the tires. I run 40mm GravelKing SK, tubeless, and can very nearly bare hand the tires on and off.
Here are a few semi-custom builds I was looking at...
VENTUS STANDARD DISC PWB SIGNATURE WHEEL SET CUSTOM HANDBUILT BY - prowheelbuilder.com
AX150D - Cyclocross Clincher Disc Brake Wheels - PSIMET Custom Wheels
System 25 Alloy Clincher DISC Wheelset
Liked 3,016 Times
Quoted: 2432 Post(s)
Liked 641 Times
Does anyone have the DT Swiss R23's? They're a little over $600 but I like those polished hubs.
https://www.coloradocyclist.com/dt-s...-disc-wheelset
I'm 160# and on my road bike I seldom break spokes even on light low-spoke count wheels. The wheels are Weinmann Hydra Disc which as far as I can tell, are sold only as OEM. I think there is something defective with how they were built. Spokes have broken both time at the nipple in ways that make it look like the nipple ripped out of the rim.
I would also check out Riding gravel wheel forum and see what they suggest.
I have two sets of gravel/adventure wheels I still need to try out.Just not enough time.
Working on my kids and wife's bike first.
Have CXD4-12 700c Tubeless from Ebay.Seller has nothing listed now.
And Fulcrum Red Power HP 29" 6-Bolt Wheelset from CRC in UK.I need to buy one more center-lock disc.
Do not really like my PWB wheel set.Only time I had A wheel come out when riding.But they get mostly good reviews.I'm going to put them on one of my slower bikes.
And Nashbar is 25% off this weekend.Not sure what they got in gravel type wheels.
I have no experience with them, but they look good spec wise, all axle options, centerlock disc with 6bolt adaptors included and wide rims for under $500
huntbikewheels.com
https://www.huntbikewheels.com/colle...-24deep-24wide
huntbikewheels.com
