Building a Gitane Tandem
Bad example
Quoted: 825 Post(s)
Liked 212 Times
Last summer I bought a Gitane Sports Tandem from a man who was retiring and moving to Corsica. He had collected most of the parts (plus a few extras) but had not put it all together yet. This is what the bike looked like when I brought it home:
I stripped it of parts and paint and had it powder coated. It then sat in my shed awaiting the right time to put it all back together. Today a friend and I started cleaning it up and bolting on the stuff the previous owner and I had collected along the way. Here it is on the bike stand when we started.
Firs off, I put on the foil decals. The originals were not available, and I can’t say I care much for originality, so I put on some decals from an Interclub. They went very nicely with the apple green paint. I have a head tube decal for it as well, but it needs to be trimmed a bit to miss the mixte downtubes.
Meanwhile we cleaned up the four Stronglight crankarms. The front BB, which was mounted in an oversized, movable shell, was in decent shape so I simply put the original back in place. For the rear, though, I had a French Velo Orange BB that was just the right length for the triple. I like the way old Nuovo Record front derailleurs work so I added one from my box of parts.
Besides the two Mafac Racer brakes, this bike also has a drum brake. I have no idea yet how well it works! But it is a cool old thing.
Likes For Aubergine:
I never finish anyth
Bikes: 2008 Merckx LXM, 2003 Giant XTC mtb, 2001 Lemond Alpe d'Huez, 1997 Lemond Zurich, 1989 Cannondale ST, 1988 Masi Nuovo Strada, 1983 Pinarello Turismo
Quoted: 294 Post(s)
Liked 137 Times
That looks to be a great project. I've been looking around (not too seriously) for a tandem and something like this would be an enjoyable project. It's great that it will have a second lease on life when you're done.
Dale, NL4T
Dale, NL4T
Bikes: Road, mountain and track bikes and tandems.
Quoted: 282 Post(s)
Liked 18 Times
Hi, I was admiring your tandem. Do you mind sharing what that green is called or and number code? I have used an old Campy double front derailleur for triples before. They do not work very well for triples. I would recommend a front derailleur designed for triples.
Bad example
Quoted: 825 Post(s)
Liked 212 Times
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
Bad example
Quoted: 825 Post(s)
Liked 212 Times
Shifting is fun!
Bikes: Yes, please.
Quoted: 2198 Post(s)
Liked 4,601 Times
One of those exceptional cases in which the repaint is actually a major improvement. Well done!
Looking forward to the rest of the build.
Bad example
Quoted: 825 Post(s)
Liked 212 Times
I parked the Tandem in the shed for a few months but got it back out again to finish it off. After working on it a bit the last three days it is close to done. As should be obvious, the timing chain still needs some adjustment, and I think I need a half link to make it all fit. And the crank needs to be spaced a mm or so to the drive side. As it is, the front derailleur can’t pull the chain onto the granny. Otherwise it works pretty well for an old Tandem!
Oh, and the rear drum brake. I set it up as a drag brake. The two Mafac brakes are operated by the normal levers, but I mounted an old Huret stem shift lever and ran a cable from that to the drum. So going downhill, I can put on the drum brake and then modulate speed further with the regular caliper brakes.
A last fun touch is the Campagnolo 980 rear derailleur, to which I added a Soma long cage. It works pretty well!
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 984 Post(s)
Liked 634 Times
Lovely, including the paint and I'm not even a fan of green.
Alas, I think the only Gitane tandem I've ever seen was in the brochure I picked up when I ordered my Grand Sport in 1971.
Every line looks just right.
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
We had one for a while but didn't ride it much. Fun to play with but it also took up more than its share of space in a crowded basement so we let it go.
Bad example
Quoted: 825 Post(s)
Liked 212 Times
I was not quite able to connect the chain when it was at its slackest position, and as you see in the pic it is still slack at the tightest position. Of course I might just be a lousy tandem mechanic.
Your timing rings look pretty small. (Or is that an illusion?) With bigger rings I believe you could take up more slack.
Bad example
Quoted: 825 Post(s)
Liked 212 Times
My recollection is that they are 30 teeth. Larger rings would not help take up slack; every one tooth increase in size (times two chainrings) would mean I would have to add two links to the chain, leaving me in exactly the same position I am now.
verktyg
Quoted: 1036 Post(s)
Liked 1,238 Times
Gitane Bike Book Tandem
Nice paint job. The green is close to the color Gitane came out with in 1974 when they switched from foil decals to the yellow or green clear plastic sheet style.
Yours is the "TANDEM SPORT" model.
We kept at least one of those Gitane tandems at the shop until about 1976 when they became unavailable. Most of them had Mafac Cantilever brakes but I've seen them with Mafac Caliper brakes like yours.
Only rode double on one of them for a few short rides but lots of single test rides on new bikes and customer's bike we were working on.
Most of those tandems we worked on were set up with a brake lever for the Atom drum brake on the rear bars. Some folks thought that it gave the stoker something to do or at least the sense of some control.
They used an odd 1 1/8" headset. We tried to grab all we could get when we found them. They may have been British thread??? Also there may have been some Stronglight 1 1/8" headsets used on those tandems.
1969 Flyer, List Price $199.50
1970's Catalog. This picture was probably filmed in Maryland not France.
In 1976 we started bringing in a few Andre Bertin tandems from France.
verktyg
verktyg
Chas. ;-)
Chas. ;-)
Shifting is fun!
Bikes: Yes, please.
Liked 4,601 Times
Oh, and you might want to synchronize the cranks a bit more for peace of mind.
Love this green color.
But with a larger ring, wouldn’t each degree of turn of the eccentric move the teeth farther?
Bad example
Quoted: 825 Post(s)
Liked 212 Times
To me it looks as if it is not yet in its furthest forward position. Try getting it further out. If that doesn't remove the slack, then winding it fully back and removing a link should do it.
There's so much slack it looks like you may need to remove 1 or 2 links. In fact, you'd best check to see that the timing chain isn't stretched. Who knows how many miles are on it.
Bad example
Quoted: 825 Post(s)
Liked 212 Times
I know how many miles are on it! Zero. The chain is brand new. Any flaws in assembly at this stage are entirely down to the incompetence of the mechanic, namely, me.
Old Bike Craphound
After you get the timing chain worked out, you can try whether you like in phase, out-of-phase, or something in between. I prefer the back cranks 3 teeth behind the front cranks on my tandems as this helps smooth the weak spot in my stroke (as the stronger pedalling pilot, with one of my children as stoker) but it is close enough that I can put pedal at the top on the inside of a turn and know that the rear pedal will not strike. All of this you can try and see what you like best,but first lets get that chain on correctly.
First thing I would do is rotate the ecentric so that it is as close to the rear as possible, then make the chain as short as you can get over the chainrings. My guess is that this will mean that you need to remove a link. Then, rotate the ecentric until the chain tension only allows about a 6-10mm deflection in middle of the chain. Tighten the ecentric and rotate the cranks to see if there is another spot in the chain where it is much tighter or much looser. If so, you need to see if you can get the timing chainrings more centered on their cranks (I think sheldonbrown.com has a good section on some ways to do this). If the chain is much tighter at some point and you cannot centre the chainrings, you need to adjust the ecentric so the chain tension is correct at the tightest point.
Last note: often the bolts that hold the ecentric get really stuck and are hard to loosen after they have been left alone for a few years of riding in mixed weather. I recommend coating them in anti-sieze paste before you install them, and if there are through bolt holes use longer bolts that stick all the way through that you can put acorn nuts on to drive them out from the threaded end, rather than just relying on the hex socket in the head. I have had to drill out these bolts after the heads have rounded out and that is a very delicate job that involves a modicum of stress.
It looks beautiful and I am sure you will soon be enjoying the graceful power of a two-motored vintage ride.
-Will
-Will
Quoted: 3464 Post(s)
Liked 2,829 Times
No, remember you are dealing with arc length and circumferences. Setting up the timing chain taughtness required the aft chainring has to be held stable, I get the chain the correct length on top with the eccentric bottom bracket somewhere near high noon, then adjust the chain from there, if you have some slack, but cannot take a link out, hook it up and move the eccentric forward. I worry about crank angle timing last, after the tension is good. Everyonce in a while it goes well all at once, do not depend on it. There are schools of thought on how to set up the timing between the two cyclors. I would look at old pictures of the Herses on a tandem and go with that.
Bad example
Quoted: 825 Post(s)
Liked 212 Times
I have a half link and (more) knowledge now, so I bet I can get it set up properly tomorrow.
