Light Bicycle Wheels
Likes For Doge:
#528
Bikes: 2019 CAAD12, 2015 Specialized Sirrus Comp
Quoted: 562 Post(s)
Liked 64 Times
I have read almost all (but not quite) of this entire thread from start to finish. I'm looking at LB for my first set of carbon wheels and would appreciate recomendations on configuration. I have a CAAD12/non-disc and ride in So Cal with a combination of steep climbs and flat roads with occassional headwinds. So I need an all around wheel. Tires will be 25c or 28c clincher or tubeless. I'm a light rider (142 pounds/64 Kg).
My decision points:
1. Rim Width - 25mm or 28mm? LB recommended 25mm, but folks here seem to prefer 28mm.
2. Depth - probably 36mm or 46mm. How to decide?
3. Hubs - DT Swiss 240S or Industry Nine? I hear a lot of good things about both.
One overall consideration is that I'd like a wheel/tire setup that feels a little more stable in downhill, no-wind conditions. My current setup with 28c tires on narrow, aluminum wheels (15mm inside) feels a little twitchy at speeds >25mph.
Thanks, guys.
-Robert
My decision points:
Thanks, guys.
-Robert
#529
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4389 Post(s)
Liked 3,016 Times
My decision points:
1. Width - 25mm or 28mm? LB recommended 25mm, but folks here seem to prefer 28mm.
Thanks, guys.
-Robert
My decision points:
Thanks, guys.
-Robert
2. Deeper section, more aero. Shallower section, fewer issues with cross winds. Personally, if I'm going to get carbon wheels for the purpose of optimizing aerodynamics, then deeper sections are better - hence I went with 55mm. YMMV.
3. Your call.
#530
Quoted: 562 Post(s)
Liked 64 Times
I updated item 1 to clarify that I'm asking about rim width, not tire width.
1. Some do, some don't. It depends on how wide a tire and contact patch you want and what kind of riding you do. I chose the 25 mm.
3. Your call.
3. Your call.
#531
Bikes: 1979 Raleigh Team 753
Quoted: 3375 Post(s)
Liked 371 Times
My decision points:
Thanks, guys.
-Robert
My decision points:
Thanks, guys.
-Robert
Both HED and Mercury used a lot around SoCal. Mercury Cycling on sale. They often do 50% + off. Watch competitive cycling.
Both the above have excellent support and support cycling. Mercury has salaried on-staff builders.
https://www.facebook.com/commerce/pr...1068095910089/
#532
Quoted: 562 Post(s)
Liked 64 Times
Probably a topic for a different thread, but I considered alloy and even called HED tech support to inquire about the advantages. The main take away (as they explained it) is the price advantage. Otherwise, aluminum will tend to flex more. I was surprised, but that was what they said.
I think alloy is a better clincher rim material than carbon.
#533
Liked 3,016 Times
Yes, but the two are not unrelated. Many of the people here who are enthused by wide rims are also running wider tires. And for a given standard tire width, a wider rim will produce an effective tire width that is greater. The advantages of a wider tire profile in terms of ride comfort and rolling resistance favor a wider rim. To take best advantage of aerodynamic effects, one might prefer a narrower tire profile.
#534
Quoted: 562 Post(s)
Liked 64 Times
Okay, but isn't a 28mm rim a little wide for a 25c tire? I realize it'll widen the contact patch, but is this an optimal config?
#535
Liked 3,016 Times
Let's turn this around - what width tires do you want to run? That should influence your choice of rim width.
#537
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
I run 23mm GP4Ks on my 28mm LB rims (they're 21mm internal, which is the important part for tire fitment), they measure out to 27mm, perfect aero configuration. 25 or 28mm tires would work too, if you want a lil more comfort. You really only give up a few watts. I'm learning with my gravel bike on 28mm GP5Ks (that measure at 30mm on 20c wheels), that comfort can actually equal speed if your roads are rough.
#538
Quoted: 562 Post(s)
Liked 64 Times
#540
Quoted: 562 Post(s)
Liked 64 Times
For a given tire width, does having a wider rim affect downhill stability? One issue I'm trying to solve is that my CAAD12 doesn't feel so stable >25mph on stock rims, even in no-wind conditions.
#541
Quoted: 4717 Post(s)
Liked 1,882 Times
https://www.lightbicycle.com/Road-bi...available.html
https://www.lightbicycle.com/45mm-de...g-surface.html
#542
Quoted: 562 Post(s)
Liked 64 Times
The 28mm wide hoops are actually a little lighter than the 25mm ones. I read somewhere that tire clearance isn't great on the Caad12, so I'd make some measurements before ordering.
Likes For Robert A:
#543
Quoted: 733 Post(s)
Liked 815 Times
#547
Liked 3,016 Times
The width of the brake track itself can be an issue - I found the stock LB brake pads to be somewhat snug around the 25 mm rims with my DA7900 brakes. It wasn't a big deal, it just required using the brakes with the lever in the open position. The Swissstop Black Prince Flash EVO pads are good for tighter brake track fits.
#548
Quoted: 562 Post(s)
Liked 64 Times
Aaron Rahim at LB says that carbon will ride harsher than standard alloy rims. He suggests getting a 35mm deep wheels, stating that they are far less harsh than their 45mm and 55mm rims and strike a good balance between aero and hill climbing. Does his advice make sense? I have a CAAD12, so ride quality is a consideration.
He also said that bladed spokes offer no real aero benefit over standard spokes, though there is a small weight savings. Any thoughts on this?
#550
Quoted: 152 Post(s)
Liked 173 Times
Don't know about the blade spokes aero but according to Sapim's data they are more fatigue resistant and stronger than DB spokes while being lighter.
