lower gearing for touring
I got a 520 about a little over a year ago and want to replace the standard 50/39/30 tiagra crankset. I've looked at the shimano lx and other cranksets that have 44/32/22, but I want a inner chainring of 20. Are there any cranksets out there or can I buy a 64mm 20 tooth chainring and switch out the 22 tooth?
Location: I live in a rural canyon in unincorporated Los Angeles County
Bikes: Giant Mountain Bike
I'm not sure, but I don't think there are any 20T arms to fit your BB.
I run a 20 year old 24-34-46 Shimano LX...
...with an ultraclose ratio 14-23 7sp cassette in very hilly country, and it works great even on a cheap, relatively heavy MTB.
Greg
Greg
cycles per second
Bikes: Early 1980's Ishiwata 022 steel sport/touring, 1986 Vitus 979, 1988 DiamondBack Apex, 1997 Softride PowerWing 700, 2001 Trek OCLV 110
Quoted: 44 Post(s)
Liked 71 Times
I know you can get 20T rings for 5-arm 94/58mm BCD cranks but I don't know about 4-arm 104/64mm
This one says it's for 4-arm but lists the BCD as 58mm which is very unusual (as it also states). https://www.biketoolsetc.com/index.cg..._id=SG-CSS5820
Soma Lover
Bikes: one bike for every day of the week
I've changed the rings on my tourer to Salsa 24/38/48. They won't shift quite as slick without the ramps and pins but they really don't need to with the bar-con shifters. I'm never going to do any racing with it anyway. The best part about doing so was I didn't need to change to a mountain bike front derailleur.
Year-round cyclist
"24" is indeed the smallest chainring you are able to install on your crankset. It is relatively inexpensive and will give you about 2-3 gears that are lower than what you have. Otherwise:
– Replace the inner gear with an adaptor from Mountain Quad Tamer; it will allow you to install an 18 or 20 teeth granny. Fine, except that jumping from 20 to 39 will be a major break in cadence.
– Replace everything with a mountain crankset. A Shimano mountain crankset will give you something like 44-34-22. The 44 is large enough for your needs (unless you like fast-paced pack racking). A warning : you'll need another bottom bracket too.
my tiagra crankset is hollowtech. Can I not get a moutain crank (shimano deore lx or something similiar) with that is hollowtech?
Palmer
Quoted: 1662 Post(s)
Liked 1,815 Times
HTH,
tcs
afraid of whales
Quoted: 347 Post(s)
Liked 5 Times
How low do you need to go? My wife and I road all over the Rockies, I had 50lbs of gear, she had 30lbs. Our low gear was 30x30 with 700C wheels (27 inch gear).
Bikes: Surly Crosscheck, Surly Pacer
Harris Cyclery sells the Sugino XD600 in 26/36/46. That is what I would get, personally. You will need a new BB, but so what?
This is an interesting thread. I have a Dawes Galaxy with two chainrings: 42T and 52T. At the rear I have 5 sprockets and I can't remember how many teeth they have, but I'm fairly sure the smallest has 13, and the largest is... 28T maybe?
In any case - I find the two chainrings to be far too large, and I spend most of my time in one of my lowest gears. My town is quite hilly and it's really starting to wear me down, and get to my knees. The chainrings strike me as quite large for a touring bike.
cycles per second
Quoted: 44 Post(s)
Liked 71 Times
My brother and I recently finished an Alpine/Pyranean tour (Munich to Barcelona) with ~27-inch low gears (I had 44x34 with 11-34 and 700C wheels and he had 44x29 with 11-30 and 700C wheels). We both had about 15kg of gear and we made all the major mountain passes just fine because they generaly didn't get much above 10% grade but we had to walk a couple of steep hills (20-25% grade) to get to some of the hostels we stayed at.
I can see needing lower than 27-inches for someone carrying more gear and/or traveling the smaller mountain roads with steeper grades.
Soma Lover
The bottom bracket will get swapped along with the crank.
The front derailleur will need to be lowered and potentially swapped out altogether. It will depend upon how well you really want the front to shift and how much chain rub you're willing to tolerate.
However, as was stated before, 22-32 is a really low gear for touring at 18.6 inches. Some people like it although I'd be using it to pull stumps. Until I'm carrying more than my bike is capable of, I get by just fine with 24-28 and 23.1 gear inches. In fact, I can't recall having used the lowest gear although the original 30-32 was used once carrying 50 lbs. in pouring rain. I would've drowned in my own sweat if I hadn't because my heavy duty rain gear doesn't breathe all that well.
Have bike, will travel
Quoted: 910 Post(s)
Liked 288 Times
Your bike must be 25 years old or more. Upgrading the gearing is possible, but may not be cost effective. Are you looking to upgrade this bike?
Michael
