650b capable Cyclocross/Gravel Frameset?
Bikes: Kona Kahuna DL Drop Bar - Sensah SRX Pro 1x11 (2012 Frame), Giant Toughroad GX 1 - Shimano Road Hydro + SLX 1x10 (2018), Diamondback Sync'r - SRAM NX 1x12 (2020)
Quoted: 160 Post(s)
Liked 97 Times
I'm probably shooting in the dark here but I've been looking around trying to find a frameset that has clearance for 650b tires around the 40-50mm size. I know that 3T and Open Cycles have frames that can run 700c/650b but to be completely honest it's way too expensive.
What I want to do is look for frames, mainly Cyclocross frames, that can take a 650bx42 tire at the very least. I also wanted to build a list of frames/bikes (mostly frames) that can handle this conversion.
Quoted: 1217 Post(s)
Liked 187 Times
WTB's "road plus" is based around a 650bx47 tire so this list should work as a starting point for what you're looking for: Road Plus Compatible Frames | WTB
Although the vast majority of spec disc cross bikes will take a 650bx42 no problem. Usually the concern is bb drop and not tire width acceptance. You want to keep bb drop it on the lower end of 70mm.
Bikes: Waterford RST-22, Bob Jackson World Tour, Ritchey Breakaway Cross, Soma Saga, De Bernardi SL, Specialized Sequoia
Quoted: 196 Post(s)
Liked 6 Times
What size frame? All City just introduced a new disc brake version of the Space Horse frame and it's available for 650b wheels in smaller sizes. Tecnhically it's not a CX bike but that's academic.
Space Horse Disc | All-City Cycles
Quoted: 196 Post(s)
Liked 6 Times
Also check out the Soma Grand Randonneur, which is designed for 650b wheels. Their spec sheet says it will handle tires up to 38-42 mm wide.
Grand Randonneur Frame Set (v.2) | SOMA Fabrications
The Soma San Marcos also is designed for 650b wheels in sizes up to 57, but the maximum tire size in specs in 38 mm.
San Marcos Frame Set | SOMA Fabrications
Quoted: 160 Post(s)
Liked 97 Times
Quoted: 196 Post(s)
Liked 6 Times
Does it have to be 650b? There are a lot of gravel bikes with 700c wheels that can handle wider tires -- eg, Raleigh Tamland, Black Mountain Monster Cross, Soma Saga, Wolverine and DC, etc.
Sunshine
Quoted: 10970 Post(s)
Liked 7,496 Times
VO Piolet Frameset - Frames
Velo Orange <---- geometry page
Can fit a fat ol 650. More 'adventure' of a frame for sure.
Quoted: 160 Post(s)
Liked 97 Times
The converse to that are the 700x32c tires that I had as backups which felt more nimble and responsive, but due to my weight their pressure was high and led to a very uncomfortable ride on uneven surfaces.
Quoted: 821 Post(s)
Liked 255 Times
The reason I'm looking for 650b is because I want the smaller overall diameter with the wider volume that it comes with. I was running 700x42c tires for the past few months and while I like the traction that it offered, the larger tires felt awkward to handle and hard to accelerate at stops.
Have you tried a really nice tire like a Soma Vitesse SL in the 700x42 size?
Really a great ride and that's what I use on my Black Mountain Cycle Monstercross.
They roll up to speed quickly, I can run lower pressure and they corner well at speed.
FWIW I don't ride them in mud or sand, but they do perform well on hard pack gravel.
Surly Straggler (650b or 700c), All City Space Horse (already mentioned - smaller sizes are designed around 650B)
Quoted: 160 Post(s)
Liked 97 Times
Again I liked the volume of my 42c's, I just felt like they got in the way too much if that makes sense.
just keep riding
Quoted: 173 Post(s)
Liked 33 Times
There are probably very many bikes around with 700c wheels that could work with 650B and 45-50ish wide tires. While it is not a new idea, people were converting bikes like this several years ago, it has only recently been revived with WTB's road plus tires and rims. Specialized has specifically designed the upcoming Sequoia to work with such tires and rims and will have a 650Bx47 version of the Sawtooth tire.
With few manufacturers on board at this time, we are at the stage where individuals experimenting are the main source of fit information. It's like where 27.5+/650B+ was with MTBs a year or two ago. There are threads on MTBR forums where people report frames and forks they have converted and how it worked out. They even came up with ways to measure clearance at the appropriate places to predict how well a frame would work. I am not aware of such a resource for road or CX frames.
Quoted: 160 Post(s)
Liked 97 Times
Quoted: 160 Post(s)
Liked 97 Times
Well, it seems that I may have found something that might be a godsend: Van Dessel Unveils A.D.D., Updates Steel WTF Do-it-All Bikes
And another one: https://www.carbonda.com/road/gravel/cfr505.html
Bikes: Cervelo Prodigy
Quoted: 478 Post(s)
Liked 87 Times
Six-Month Review: Open Unbeaten Path | Outside Online
Quoted: 160 Post(s)
Liked 97 Times
The UP review, ok, expensive. But this review is one of the latest ones:
Flounce
31
11-30-17 01:29 AM
bcpriess
4
05-12-17 12:00 AM
zanq
13
04-04-17 09:57 AM
trail_monkey
6
07-03-16 09:00 AM
