Canyon Endorsce Di2 - Does it have the wireless module?
Canyon Endurace Di2 - Does it have the wireless module?
I’m looking at an Endurace CF SL Disc 8.0 Di2. I’m curious if it includes the Di2 wireless module. Anyone know? Thanks!
I really doubt it, but you can call Canyon to confirm. I've contacted them before with questions and they were pretty helpful.
As a data point, I just bought a new Cervelo with Di2, and it didn't come with the wireless unit. It's very easy to install though. One short cable and the unit, and it's plug and play. It's pretty sweet and highly recommended. My Garmin will beep at me before a front chainring change, if using synchroshift; you can change screens using buttons on the hoods; the phone app is a lot easier to use compared to the wired interface with the PC program.
Likes For drewtk:
Likes For jadocs:
Quoted: 1250 Post(s)
Liked 1,329 Times
Why would a manufacturer include an optional product that maybe only 50% of purchasers' use and yet require all purchasers to pay for it? I liken the BT Adapter to a dealer-installed option if you want one purchase it with the bicycle and have it installed or do it yourself. At the end of the day, you would be paying for it regardless.
Because Sram does it without an adapter. It’s a $100 part, after-market, so I imagine it would be quite a bit cheaper for the manufacturer. And, really, it’s crazy that in 2020 a $5000+ bike with electronic shifting requires a USB cable and Windows computer or trip to the LBS if you wish to adjust it.
Likes For shaun3000:
Liked 1,329 Times
Quoted: 7019 Post(s)
Liked 11,041 Times
With that said, the BT dongle is worth getting for the integration with your cycling computer...And I agree with others that it should be optional, as it's not essential for riding the bike and some people may not want it.
Quoted: 18883 Post(s)
Liked 10,646 Times
Most people don't want it. I'd guess 1 in 10 Di2 users sees value in the wireless unit. It isn't necessary to use your groupset, like the battery charger. It's extra weight and complexity, which freaks some people out. And it's not free, so people who don't want it don't want to pay for it.
Likes For Seattle Forrest:
Likes For jwalther:
Liked 11,041 Times
Quoted: 942 Post(s)
Liked 527 Times
I have found the module useful in the following way:
- Software updates: There have been several to the components since I've had my bike past two years.
- Connectivity to my head unit (bike computer). I can switch pages without taking my hands off the shifters.
- I was able to go in and make sure I had the proper gears assigned. Believe it or not it came with the default assigned which was different. It still worked fine, but if you use synchro you should make sure you have the correct data assigned.
Cool but not useful:
- Being able to visually see what gear you are in on your computer.
They (Shimano) recently updated the iPhone app. I haven't dug into it yet so do not know if there are any new functionality. Maybe someone who has dug into it can confirm.
Quoted: 528 Post(s)
Liked 230 Times
Quoted: 942 Post(s)
Liked 527 Times
Without it you cannot update the software
(and is this actually needed for electronic shifting?)?
And what is the gear assignment?
Likes For jadocs:
Liked 10,646 Times
So this Shimano thing let's you swap pages in your bike computer by pressing the shifters instead of actually having to touch the bike computer? Without it you cannot update the software (and is this actually needed for electronic shifting?)? And what is the gear assignment?
You don't need to update the wireless communications software to ride your bike. Everything comes with working software installed. You can use that and you won't know the difference, especially while you're riding.
I mean, if you can, you should always be on v.latest, but in this case, unless there's something you need in the change log, it isn't worth losing sleep over.
Liked 10,646 Times
Extra weight? Maybe 10 grams. Not even the weight weenies care about that. Complexity? It's a plug in electrical transmitter, no moving parts and 100% bomb proof. I have it on two bikes and find the information provided very useful. Not all will of course, but no one should be making the decision based on weight or complexity.
Liked 10,646 Times
That's a little too far. Unlike the D Fly, not including a charger would make the groupset useless. Shimano is smart enough to realize many first time buyers would not purchase Di2 if it didn't come with a charger. But we've already had that thread.
Liked 11,041 Times
perhaps a reasonable compromise would be to make the charger optional. As Di2 becomes more popular, more and more people are going to end up with multiple chargers – and I don’t see myself ever needing to charge two bikes at the same time. I also don’t see myself wearing out a charger, since it just sits on my workbench.
Look at any good brand of cordless power tools: you can buy multiple tools that take interchangeable battery packs, and only have to purchase one charger.
Another benefit of the wireless module: if you have synchro shift turned on, your bike computer will beep at you if the next shift is going to change the front chain ring.
For those who don't know what synchro shift is, it's a feature that will automatically change the front chain ring when the rear cassette gets to certain points. It minimizes cross chaining. You as the rider just have to decide if you want a harder or easier gear, and then hit the shift button. You don't have to think about the chain ring.
When this happens, Di2 will also shift the rear cassette a gear or two so that the gear ratio jump is consistent. If the system only changed the front chain ring (without changing the cassette), it would result in a pretty big jump.
Likes For drewtk:
You will need to purchase an additional wire to connect the wireless unit to your system. There are many options as to where to install it (it can be installed anywhere in the system...mine's near the A-junction under the stem.
Check out the BetterShifting website (Google it...I can't post links yet as I have a new account). Browse around the site...he's got a bunch of YouTube videos as well.
I didn't do much research prior as the opportunity to get a Di2 bike came quickly and I had to move fast, but learned a lot quickly.
Good luck and let me know if you have any questions. Sorry if I'm being redundant, but I didn't closely read all the other responses.
Likes For jorell:
What am I missing?
Ok, I'll bite.....I have a 4 year old Parlee Altum w/ Di2 and an old (more than 7 years) Garmin 520. I don't have a d-Fly but since day one I have been able to see my gears, battery level and set the correct cassette. Everyone's description of the d-Fly seem to imply that it is required for these basic functions. Yes, if I need to update the system I need to plug it into my computer, I don't find this to be a bid deal and I am not interested in synchro shifting.
What am I missing that is worth $100?
Bikes: 2020 Fuji Bighorn 1.3, 2005 LeMond Buenos Aires, 2013 Jamis Coda Elite
