Just got this off of Craigslist
Grouchy Old man
I just got this mountain bike off of Craigslist. It needs work, but I am up for some wrenching. I am thinking about taking everything off, rust treating, and checking everything out, then packing and lubricating the components. Thoughts?
Quoted: 1088 Post(s)
Liked 1,022 Times
Hard to tell from the pics but the welds make it look like aluminum, in which case nothing much to rust proof. No harm with stripping most of the parts off, cleaning them, repacking bearings, and reinstalling if you know what you're doing. Looks like a fine bike.
Inquiring minds want to know about the Cannondale in the background. I'd know that brake hanger anywhere
cheers -mathias
cheers -mathias
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
I believe that is a Bikes Direct offering. If so, check the wheel bearings. All three I have looked at were cup and cone and were either a) over-tightened, or b) shot from being over-tightened.
I think you need a stem riser for that stem riser.
Grouchy Old man
Re: Cannondale
Here's the Cannondale frame.
I managed to get one of the cups off of it, already, but the other one is being a bear (pardon the pun.) I spray some liquid wrench in there and see if that helps getting it off. I need to get a wrench or use a mallet and screwdriver to get the bottom bracket on the left side off. I want to strip the frame and repaint it, once I find a viable solution to the missing DT shifters.
>> I'm an old fart (50,)
Ha. I'm six years older.
Forgive me for bringing it up -- I'm sure you know -- and I forget the particulars myself -- these bearings arent all lefty-loosey...it's been too long but I think™ that one side has a left-hand thread. Just thought I'd mention it, because of the aluminum frame the and the 'mallet' and all...
EDIT: Ohhh now I see what this is -- it's an ST400 -- early 90s I'm guessing -- the 'brake bridge' is actually the attachment for the rack. These are nice; I have a '96 T400 w/ cantilevers, same red, ordered new from LBS in '95. My favorite bike ever. You'll love it -- especially if you need the 25" size, them frames is stiff!
Grouchy Old man
Risers and risers, oh my!
I got my work cut out for me!
Grouchy Old man
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
The fork came apart? That is pretty strange. Did you or the prior owner undo the foot screws? Suntour forks usually require no service because there's usually nothing in them to service, just a greased coil spring. But you can clean it and grease it and replace the wipers if you want.
Genesis 49:16-17
Genesis 49:16-17
Grouchy Old man
I unscrewed it and snipped the old cables
Grouchy Old man
The left one came off with no problem
I left one was a piece of cake to get off...the right one, on the other hand is on their good.
