Bike Weight limits
Bikes: Exercise bike lol
Bike Weight limits
Hi there!
So I'm still learning the whole 'how do bikes work?" thing, having never had one in my 37 years on this earth. A stumbling block I've only just learned of is weight, as in, the bikes I'm looking into have listed weight limits, which I admit I didn't know was a thing. I'm 270 pounds, 6'3, and a lot of the bikes I'm looking at have listed weight limits of 200-240, or 'not for you.' Do I need a specialty bike for my weight? Where would I find such a thing? I'm a little perplexed by this turn of events, and could use some clarification, if possible. Thank you for your time.
Bikes: 1979 Raleigh Team 753
Quoted: 3375 Post(s)
Liked 371 Times
That is a consideration. Most parts for the mass public will take 270#. That is too heavy for the exotic light stuff, but many bikes will take that. My Cannondale will.
A lot depends how you ride. I am very easy on wheels and north of 220#, my son at 130# broke more stuff as he just road over everything, where I would steer around.
I'm using a stock ENVE fork on my tandem - 350#-400# with 24 spoke rear and 20 spoke front wheels. They are heavier.
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
Avoid lightweight, low spoke count wheels. Solid 32 or 36 spoke wheels can handle more.
You may find useful info in this subforum for bigger riders.
https://www.bikeforums.net/clydesdal...-200-lb-91-kg/
Callipygian Connoisseur
Quoted: 564 Post(s)
Liked 350 Times
Hi there!
Also, do check out the Clydesdale sub forum.
-Kedosto
Quoted: 7652 Post(s)
Liked 3,478 Times
I am around an eighth of a ton and I regularly ride low-spoke-count wheels ... but i try hard not to smack stuff ... unweight a bit when I can. I still don't break many spokes.
As for frames ... I have CF, Al, and steel ... no problems.
Most new bikes are rated at somewhere around 270 pounds max load, which means they are good for a good bit more ... no bike manufacturer is going to rate a bike for 270 pounds in 273 is going to break it---the person could show up in court weighing 265 and win a lawsuit.
If I were you (and save for a few inches height, i pretty much am) i wouldn't buy anything designed for racing, but most endurance-frame bikes, particularly with disc brakes, seem to have 28-32-spoke wheels which ought to be fine unless you like hucking off three-foot drops. Whatever your size, it is good to get into the practice of getting up on the pedals and out of the seat when you are about to hit an obstacle ... that lets the knees, hips, arms and back all act as shock absorbers which helps both bike and rider.
Not that I would discount what everyone else is saying ... but what i do works for me. Your mileage is guaranteed to vary.
Quoted: 95 Post(s)
As a Clydesdale I can weigh anywhere from 230-260. I have snapped 2 frames on steep climbs and had both frames replaced no questions asked and upgraded both times. I did go with Trek and they were marvelous honoring their ORIGINAL OWNER warranty. NO QUESTIONS ASKED ABOUT WEIGHT. They look at the damage and decide whether or not it was a mfg failure or crash. As long as you don't crash the bike, you're good.
I did go with the big mfg'ers for that reason, lifetime warranty as I have always torn up bikes as a child as well and yes, I ride light.
Bikes: K2 (Marzocchi/Fox), Trek 6000 (red) MARS Elite up front, Specialized Hardrock Sport -> eBike (R7 Elite up front), lastly TREK 820 loaner. Recently sold Peugeot du Monde Record and 1956 Schwinn (owned since new).
Quoted: 75 Post(s)
I'm just under 6 ft and 240. I picked up an older aluminum framed Specialized Hardrock Sport for an eBike project. What impressed me was how beefy the frame is in all respects. The rear triangle is reinforced near the drop-outs and the tubes are large hydroformed units. Lots of area where it's welded, well executed wide weld beads, etc. Mine is a large frame and it's plenty roomy. The area where the seat stays come up to the seat tube is wide enough for at least 2.50 rear tire.
There are tough wheels out there for cargo bikes, so that should not be an issue ... I agree with Kodosto in 36 spokes as a minimum for the rear wheel and a double walled rim is a good idea. Neither is out of the ordinary, but may not be a "stock" item on most bike models ... I'd just plan on having a wheel built and wrapping a 2.50 cross-section tire around it. The larger air volume will hold all off the ground better and give you "room" to run over stuff w/o getting a pinch flat.
I dumped the cheezy oem RST fork and replaced it with a Manitou R7 Elite air fork. That took 2 1/2 lbs off the bike and made it much livelier up front. For more rider weight, just add more air
Should be able to find a used bike like this for less than $150, and modify as needed
I'm prolly into it about $600, before the ebike kit ... So that ought to be doable on your end.
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,836 Times
If you are really concerned about it, contact a company that makes singles and tandems.
www.co-motion.com
would be a good choice.
My comment would be that bigger tires and tough wheels matched with a strong metal frame should carry your weight - for normal road riding.
edit: above comment not a slam on carbon fibre, it should be OK as well, just not my first choice.
www.co-motion.com
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
Unless you're going for a super-light carbon-fiber racing bike, the frame is usually not the weakest link. Most 'entry level' bikes (the $500-$1000 range) with metal frames (whether it's steel or aluminum) will be sufficiently strong for your needs.
I ride with some 'Big Dogs' and they're hardest on the wheels. Stock wheels on a $1000 bike are, generally, adequate, but not Great. I'd ride them until they start giving you trouble, then upgrade to a heavier-duty wheel. There are several online vendors and individual craftsmen, who deal in specialty wheels. Replacing wheels, is also not a very difficult thing to do.
I would suggest, though, when you're looking for a 'better' bike to move up to, is to go to a bike shop (or two, or three, depends on your town) 6'31'
Bikes in department stores and sporting goods shops are 'one-size-fits-all' and at 6'-3" 270# you're sort of outside the window of people that kind of bike is intended for. A bike shop will be able to better fit a bike to your needs.
Liked 3,478 Times
I'm just under 6 ft and 240. I picked up an older aluminum framed Specialized Hardrock Sport for an eBike project. I dumped the cheezy oem RST fork and replaced it with a Manitou R7 Elite air fork. That took 2 1/2 lbs off the bike and made it much livelier up front. For more rider weight, just add more air Should be able to find a used bike like this for less than $150, and modify as needed I'm prolly into it about $600, before the ebike kit ... So that ought to be doable on your end.
But be like @BrocLuno and get a real fork.
Quoted: 2604 Post(s)
Liked 1,933 Times
I ride a bike built for loaded touring on the theory that I am a load. Many of the hybrids are rather overbuilt for straight road riding, so one of those might do well for you. Go to your Local Bike Shop (LBS) and ride some.
As noted, many wheels aren't built to last for heavier riders. Three of the last four bikes/wheelsets I bought needed to be properly tensioned and stress-relieved. While you're there, ask at the LBS if they can do this. If they tell you it's not necessary, on a bike under $2,000, they don't know how or can't do it, and you may need to look elsewhere.
Wood Licker
Bikes: Trek Fuel EX 8 27.5 +, 2002 Transition Dirtbag, Kona Roast 2002
Quoted: 23 Post(s)
Hi there!
I had to move to a bigger bike with stronger parts. I ended up buying a Norco Range A1 which suited my size, and my riding style.
So short answer is yes, you will need to adapt. But yes there are lots of options. You just need to decide what and how you want to ride.
There is even a hard tail company out of colorado building very very large bikes for the exceedingly tall. Titanium so quite pricey but meant for riders up to 400 pounds. They have offered to send me a demo to review on my youtube channel. Might be an option depending on price range and type of riding. Clydesdale Bike | Big and tall bicycle | XXL Bicycle | Clydesdale Bicycles
The Clyde sector seems to have a lot if heavy riders wanting to ride light carbon frame bikes... replacing the low spoke count stock wheels is always an option,
As is frequenting the shop and checking the spokes are all tensioned and so acting as a whole..
Quoted: 12 Post(s)
This does come up a lot in the Clydes/Athenas forum from time to time. I started a thread a while back where I asked what people were riding. I was surprised that most riders over there are just riding "normal" bikes.
https://www.bikeforums.net/clydesdal...u-pulling.html
I'll second the advice about the wheels. I broke spokes on the stock wheels that came with my bike, but after I upgraded to sturdier wheels, I haven't had a problem.
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
Of course a used bike is the best value, but if you want a new bike, the cheapest way to get an overbuilt bike is to get an inexpensive touring bike like this:
https://www.performancebike.com/shop...e-2018-31-8654
It's all set to carry extra weight right out of the box.
Bikes: 2018 Diamondback Podium Equipe Dura Ace Disc, 2013 Felt z85 (now a frankenbike,) 1994 Serotta Colorado TG, 1999 Lemond Buenos Aires, 2017 State Undefeated II Track Bike, 2005 Litespeed Tuscany project
Quoted: 29 Post(s)
As mentioned before, wheels are the weak point. I've ridden at weights between 230 and 275, and raced at most of those weights. I have a classic steel roadie, started on AL, have a TI endurance bike, but the bike that sees the most miles is my super nice high end high mod full carbon dura ace race geometry wonderbike. The key to all of them? Good wheels. I destroyed 4 sets in my first 2 years road riding. Since then, I have invested in a good set of handmade AL clinchers from ROL wheels (they have options SPECIFIC to big dudes, and the owner, Sean, will do any kind of custom work you want, and the AL wheels wont break the bank) and a nice set of deep carbons from HED (the deeper the rim, the shorter the spokes, less chance of breakage. Not cheap though.) The frames and componentry, from low end to high has all been just fine with no more work needed than my skinny ass friends gear
