Can I go tubeless?
Can I go tubeless?
I have 700c DT Swiss R460 rims with 25mm Gator Hardshell tires and I'm sick and tired of pinch flats! I am buying and replacing tubes weekly. At the moment, I believe that's because I was inflating the tires to 100 psi instead of 120 psi, thinking lower pressure would be more comfortable. Walking or changing tubes is far more uncomfortable! So I'm back to 120 - 125 psi. I'm also thinking of going tubeless, having seen and read how much better a tubeless setup is regarding reliability (far fewer flats). My Question is: can I go tubeless with the rims and tires I have now? Can I at least use my rims with tubeless rim tape? Maybe I just try tubeless on the front only with my rim and tire as an experiment? I have Slime tubes on the way, BTW lol 😆. SO sick of FLATS! AH!😡 Brand new rear tire and a second, backing up the front. Both Gator Hardshells ...
Should Be More Popular
Quoted: 22600 Post(s)
Liked 8,928 Times
The rims are “tubeless ready” I don’t think the tires are.
What type of flats are you getting?? Are you sure they are pinch flats? Goat heads? Glass??
I don’t think the PSI change is an issue and you probably are running it too high but that depends on your weight. What’s your weight??
Not enough info yet to give good advice.
Likes For datlas:
Bikes: SL8 Pro, TCR beater
Quoted: 989 Post(s)
Liked 586 Times
120PSI on 25mm tires? It's too much. How heavy are you?
Have you considered the possibility that your tire is the problem, and not the inner tubes? It happened to me - the tire had a defect inside that was causing the inner tubes to puncture after a few rides. It took me a few inner tubes to realize this.
Also, how old are your rims? All DT Swiss rims are either tubeless compatible or tubeless ready. Not sure since when though.
More information is needed in order to better help you!
Quoted: 3956 Post(s)
Liked 7,307 Times
I'm guessing "pinch flat" is being used incorrectly.
Likes For tomato coupe:
Expired Member
Quoted: 3674 Post(s)
Liked 5,441 Times
A quick look at the Silca chart indicates 100 psi should be plenty for 25s unless you are over 350#. If you are, you should move to a larger tire. FWIW, people are happier with tubeless on wider tires with lower pressures.
Quoted: 1461 Post(s)
Liked 1,486 Times
1. Are your rims tubeless ready?
2. Can you fit wider tires on your bike?
3. Assuming the answer to 1 and 2 is "yes" then I'd recommend buying some 28mm or 32mm tubeless ready tires, sealant and tape to give it a try.
I wouldn't bother with 25mm tubeless. At that size, the benefits are marginal. You might see a little more flat protection, but the sealant doesn't work as well at such high pressure, so even that might be iffy. 28mm is as narrow as I'd go on tubeless.
Likes For msu2001la:
Quoted: 1163 Post(s)
Liked 442 Times
#2) maybe the OP can speak to how much clearance he/she has on their bike.
#) 3 I disagree with you that 25mm tubeless are not worth the trouble. They not only offer more flat protection, they also ride better and can most definitely be ridden at lower pressures which makes them track poor pavement much better. I feel like 25mm tubeless are so good in fact that I have both my regular road bikes set up with road tubeless. Since these are older rim brake frames the one only has 25mm clearance front and rear, the other has 25mm front clearance and 28mm rear clearance. The durometer of the rubber for tubeless seems different to me in a way that I like. They are not the same as "supple" open tubulars that you run with latex tubes. Instead, you can kind of feel the thickness of the rubber gripping the road. I like to think of it like an idler drive on a turntable versus a belt drive. Very direct palpable feedback. I love it. The lack of love for road tubeless is a mystery to me. They do wear out sooner, I believe which is really not a huge deal breaker for me. I have had great results with both Panaracer and Hutchinson tubeless tires and highly recommend you take your Gator Hardshells and switch them out for some nice tubeless tires. You will need to double tape the rims and use some quality tubeless valves and perhaps use a pressure cannister mount them and then fill them with the sealant of your choice. You may be good to go for an entire year (flat free) after doing this. You do need to refresh the sealant every 3 months or so to make sure it will self seal small punctures.
Liked 1,486 Times
I can speak to #1) since I run DT Swiss R460 rims on my bike. Yes! these are tubeless ready.
If the OP is really getting pinch flats on 25mm tires at 100+ psi, the best course of action here would be to run wider tires.
what type of road causes pinch flats on 25mm tires at 100+ psi?
Advocatus Diaboli
Quoted: 4737 Post(s)
Liked 1,533 Times
If the flats are really pinch flats at 100 psi, and if bike can't take anything wider than 25mm, will TL be a good solution? I know it's more difficult to pinch flat a TL tire. But 100 psi is 100 psi. If tire is bottoming out (albeit with a tube) at these pressures, there's no magic to prevent the same running tubeless, though with TL could this mean more likelihood of burping problems if not pinch flats themselves?
Liked 1,486 Times
Heavy rider + pothole would definitely pinch flat a 25mm tire at 100psi if you hit it hard enough.
I think the issue here is that the OP is seeing this happen frequently, so presumably not a result of crashing into potholes. I suspect there's something else going on, but without more information we are only left to speculate.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Bikes: 2022 Moots RCS, 2014 BMC SLR01 DA Mech, 2020 Santa Cruz Stigmata, Ibis Ripmo, Trek Top Fuel, Specialized Levo SL, Norco Bigfoot VLT
Quoted: 464 Post(s)
Liked 182 Times
Get rid of the 25s if possible. At least go to 28s. Your PSI is fine. If you go tubeless and your bike can handle it, use 30s or 32s even. You will use lower PSI on those but calculate it according to all the factors- weight, tire width, rim internal width, casing, etc. Good luck.
Quoted: 1743 Post(s)
Liked 1,281 Times
FWIW I went to tubeless on 2 of my road bikes and my GF's road bike about 4 yrs ago. Not one flat in that time.
Quoted: 242 Post(s)
Liked 455 Times
Yikes that is high psi.
How much do you weigh?
Pinch flats are the result of hitting something with enough force to compress the tire against the rim so hard to bite into the tube causing two small holes the width of the rim. If this is what you are doing it is user error not psi or the tire size.
I'd be very concerned about the the wheel if you go tubeless and ride the same way...you are going to blow the tire which could end in catastrophe.
I weigh 142lbs and ride 23mm tires at 65psi with tubes. I've not had a pinch flat in years generally because I'm a 'light' rider...not weight wise but riding style. I watch the road and have learned not to slam into and snow plow. Perhaps this is something you need to work on but you give so little info it is hard to offer useful suggestions.
Expired Member
Liked 5,441 Times
OP seemed pretty distressed but apparently not enough to return.
Likes For shelbyfv:
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
120 isn't exactly "OMG THAT'S TOO HIGH/It'll Xplode" territory.
You can pinch flat on 25's at 120.....only a few caught it but anything is possible if you weigh enough.
Some of you are on to what's most likely happening so maybe I missed you already explaining it but - Pinch flats at 125 on 25's isn't common even with an extremely high rider weight that would make it more possible. To have repetitive flats at high intervals on what are generally considered tires designed to prevent flats would imply a different cause for a flat - such as something lodged in the tire casing.
Take the time to properly diagnose the actual cause of each flat. I did a video on it -
To the reference above that "Everything " DT makes is tubeless I would like to point out they were around for a lot of years before tubeless was created so that isn't a true statement. Thank you to the person who was familiar with the specific model and reported back that specific model was tubeless.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Likes For Psimet2001:
Liked 442 Times
Take the time to properly diagnose the actual cause of each flat. I did a video on it - https://youtu.be/obZoxw3U2uQ
Calling threadstarter TimeVirus - has any of this proved helpful to you? Could you share more details about the nature of your flats and what you believe are causing them?
Bikes: 2002 Eddy Merckx Team SC Resto-Mod; 2019 Ibis Hakka MX; 2017 Spot Brand Ajax Belt Drive
Quoted: 169 Post(s)
Liked 192 Times
You should not be getting pinch flats that often -- esp. at 100psi. I wonder if you are either installing the tube so that it is getting caught between the tire and rim, or have some other defect or debris on the rim or inside the tire. Carefully check the rim and inside (and outside) of tire with your finger to see if there are any pointy or rough spots. But anyway, if your rims are TL ready, I would consider switching. I've been running tubeless for a few years now and am not going back. If you have enough clearance to go up to 28mm or higher, do it. My bike is older and only allows for 28mm, but it's a big improvement. When I started riding in the 80s, I was rocking 19mm tires at over 140 psi! I can't even imagine what we were all thinking back then.
Edit -- I should add that I ride 44mm semi-slicks and 47mm knobbies on my gravel bike. Wider tires are super plush.
