Let's Talk About Homemade Mudflaps
Bikes: 61 Bianchi Specialissima 71 Peugeot G50 7? P'geot PX10 74 Raleigh GranSport 75 P'geot UO8 78? Raleigh Team Pro 82 P'geot PSV 86 P'geot PX 91 Bridgestone MB0 92 B'stone XO1 97 Rans VRex 92 Cannondale R1000 94 B'stone MB5 97 Vitus 997
Quoted: 392 Post(s)
Liked 49 Times
I was fixing up bikes for my friend and his daughter yesterday. My friend rides his bike every day as his main transport, and the mud flaps have fallen off his fenders. I cut up a white plastic orange juice jug and made a long, wide mudflap for his front fender. Tested it by riding through some deep puddles, worked pretty well. He cares not at all about how his bike looks - for the annual fix-up last year I bought the period correct, color matched "UNIVEGA" downtube decal to replace the scarred one, and he told me he didn't see any reason to bother installing it - so I wasn't worried about the ghetto mod.
Now, let's turn to my commute bike. I do care how it looks, to a point - not enough to wash it too often, but enough that I've matched bar tape and water bottles to the primary decal color (orange). It, too, has lost one of its mudflaps. And I have just drained a white plastic gallon jug of milk . . .
My question is how awful it will look. This is my commute bike (below). Imagine it with wide, glaring white plastic milk jug mud flaps hanging nearly to the pavement. More "not" than "hot"?
What alternative material would you recommend to me - preferred: cheap-to-free, easily found, light, and functional.
Heck, let's show our home-made mud flaps and share design tips and fitment tricks!
aka Phil Jungels
I use a strip of rubber roofing material, cut the same width as the fender at the top, to about 3" wide at the bottom - your choice of length. Pop riveted to the fender or existing factory mud flap. Stiff enough to be functional, flexible enough to not be a bother in the wind.
Disco Infiltrator
Quoted: 3131 Post(s)
Liked 2,112 Times
Just tossing out ideas, I don't really live in fender country.
If you are looking for already-black flexible plastic the first thing that springs to my mind is motor oil bottles.
If you can find an appropriate shaped thing made out of Lexan, or even just a sheet, then you can use R/C car body paint and that opens up a world of airbrush tricks etc. It's tough, too.
Heck, let's [B]show our home-made mud flaps
My mudflap has me seeing stars when I look at it. From a 5qt Kemps ice cream pail. I could have chosen an ice cream cone theme as well. Field tested this week in -23 F temps.
Quoted: 392 Post(s)
Liked 49 Times
Hmm. This homemade flap stuff is more subtle than I realized. My milk jug flap doesn't look terrible, IMO, and has that seemingly-cool (but maybe not really) tight fit to the tire, but it also vibrates such that bumps have it jittering against the tire tread. Back to the drawing board.
That's a wear-in custom fit.
No........that makes way too much sense.
Bikes: 2014 Trek Crossrip LTD, 2013 Raleigh Misceo
Quoted: 13 Post(s)
Yard edging. The black plastic kind that comes in a roll. It's thin enough to cut easily. You have to cut the top edge off, then its easy to cut to any shape you want. I used a piece to go from the rear rack down to the chainstays. Worked pretty well. Black plastic matched other blak bits on the bike.
DancesWithSUVs
Quoted: 7 Post(s)
I use heavy-duty rubber tool box shelf liner. I cut about a 3-4" strip 2/3rds the inside width of the fender,then flair it out on either side to about 1/2" wider than the fender and make it as long as it needs to be to protect the front rings. Put heavy-duty 3M double-sided tape on the thin strip and just stick it up in the fender. Looks clean,lasts for years.
C'dale BBU('05 and '09)/Super Six/Hooligan8and 3,Kona Dew Deluxe,Novara Buzz/Safari,Surly Big Dummy,Marin Pt Reyes,Giant Defy 1,Schwinn DBX SuperSport,Dahon Speed Pro TT,Brompton S6L/S2E-X
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,571 Times
Quoted: 392 Post(s)
Liked 49 Times
On closer observation, my flap is vibrating due to wind, oscillating from right to left - I drilled a few holes in the lower corners to reduce the air pressure and we'll see if that helps. If not - need to drink another gallon of milk.
Quoted: 905 Post(s)
Liked 2,083 Times
Leather. If you can get ahold of a wide strip that works. Maybe some old dress shoes. Otherwise cut a belt (wider is better) into strips, pop rivet them to the milk jug flap, and trim to shape.
Quoted: 336 Post(s)
Liked 309 Times
This. Generic leather tool belt from WalMart or Home Depot is around 5 dollars. The western-style tooling goes away after it gets wet a few times and you just have a nice, heavy leather flap. Held in place with M4 bolts.
Quoted: 905 Post(s)
Liked 2,083 Times
I had a vintage German bike where the leather front mudflap was attached via two hooks around the sides of the fender. It could slide up the fender, then would fall back down until it caught on the fender stay. So if you rolled the bike off a curb, rather than smashing your flap it would just slide up, then fall back down. Simple and brilliant.
Edit: I recall it was a Puch. Too small for me, I gave it to my neice.
Bikes: Trek Allant
I did this following a link from a previous thread here:
https://www.phred.org/~alex/bikes/fendermudflap.html
Rubber stair tread, cut to the shape you want. I made my front one a bit wider than I sometimes see. Great in slush and snow.
Bikes: Fuji Cross Comp, BMC SR02, Surly Krampas
Quoted: 7 Post(s)
I use the curved side of a Tide detergent jug, since it will sort of continue the curvature of the fender.
I use heavy leather, cut to fit inside the fender for about two inches, and pop riveted to the fender. The flap than extends down to about 3/4 of an inch from ground and flails out to 4 1/2 inches. Excellent coverage, keeps me clean and dry.
Passista
Bikes: 1998 Pinarello Asolo, 1992 KHS Montaņa pro, 1980 Raleigh DL-1, IGH Hybrid, IGH Utility
Quoted: 876 Post(s)
Liked 728 Times
As a side note, my mudflaps are flat, and I noticed some water splashing from the sides. I'll try adding a strip of aluminum to curve them, so water is deflected more.
