Need Your Tricks on cleaning Chainring nuts and bolts
Bikes: too many
Quoted: 411 Post(s)
Liked 234 Times
I'm exasperated with wearing my finger tips down to nubs trying to clean out rusty rust gunk from the hex holes of bolts and inner threads on nuts that hold chainrings on... it seems a forever C&V issue, and I haven't come up with any really nifty tricks to make things go smoother. My go-2 method is soaking in rust remover (namely white vinegar), but there always seems to be ample crud stuck in there, even if the rust remover has done it's job. And, the go-2 scrubber is a cotton swab (cheapy q-tip knockoffs), backed up with the occasional tooth pick for the corners. The cotton swabs seem slightly undersize for the job, whereas two of them are slightly oversized for the job. Please share your superior knowledge with this tired, numb-fingered, novice....
Quoted: 3514 Post(s)
Liked 2,927 Times
Quoted: 604 Post(s)
Liked 1,064 Times
For me, soak in WD40 first, then clean or soak with simple green, if rust after, then soak in Krudcutter, but only for an hour or 2, if left overnight in Krudcutter, it will start removing the chrome.
Tim
Tim
Likes For tkamd73:
Quoted: 566 Post(s)
Liked 1,053 Times
If i’m out of WD40 and not in a hurry, I throw the hardware in a jelly jar with Dawn and hot water and swirl around for a few minutes and re-swirl whenever I pass by over the next day or 2. (Small jar in kitchen works for me.) Evaporust if needed.
Likes For RustyJames:
Liked 2,927 Times
My suggestion was to swap out the steel bolts for aluminum (or titanium). Will save you a lot of elbow grease, they’re not that expensive and you could save a few grams. They’re such inauspicious parts you’ll never notice the different material used.
Likes For smd4:
Bikes: 2014 Trek Allant drop bar conversion, modified Schwinn MTN commuter, 2015 Trek 520, Soma ES, Salsa Journeyman, 1980 Trek 414
Quoted: 178 Post(s)
Liked 355 Times
Soak in Evaporust
Likes For SalsaShark:
Used to be Conspiratemus
Quoted: 297 Post(s)
Liked 245 Times
No bike of mine has ever had a toothpick taken to it for any form of maintenance. If it won't come off with a damp rag, it stays where it is.
I take it you are talking about gunk accumulating only in the hex holes of the bolts as a cosmetic issue, not on the threads which I prevent by always greasing before assembly.
I've never had bolts rust out, even on my winter commuter bikes from when I was working. Chains, yes.
Are chainring bolts not stainless steel? I assumed they were from the zero amount of trouble I've had with them.
seńor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3890 Post(s)
Liked 6,488 Times
5-10 min in naval jelly.
I use two small containers of it. Makes it easier to conserve as much as possible. I like to reuse it and avoid pouring it down the drain.
Likes For SurferRosa:
Likes For C9H13N:
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,406 Times
Small diameter brass brush on a Dremel tool. Insert completely into bolt hole and run at a couple thou RPM.
Cleans AND polishes, does not remove enough material to be an issue.
Likes For rccardr:
Bikes: too many
Quoted: 411 Post(s)
Liked 234 Times
I think I have an old gun cleaning kit around here somewhere, with tiny (like .177 caliber or maybe .22).... now where did that end up? Thanks everyone for the ideas.
Bikes: too many
Quoted: 411 Post(s)
Liked 234 Times
I take it you are talking about gunk accumulating only in the hex holes of the bolts as a cosmetic issue, not on the threads which I prevent by always greasing before assembly....
Quoted: 1088 Post(s)
Liked 1,205 Times
I usually start with a light oil, like 3-in-1 brand, with brass wool -- you can squish that into some tiny shapes whenever you need. The oil does a good job of softening up accumulated gunk, Then, a soak in Evaporust, rinse, and a drip of the light oil again, or a light coating of grease.
Likes For noobinsf:
Liked 2,927 Times
Top end ones are alloy. If you prefer stainless steel, they are available from eBay for between $5 - $10 per set of five bolts. This is the easiest/cheapest fix for the rust problem.
Quoted: 1303 Post(s)
Liked 1,912 Times
I use a cheap stainless steel straw cleaning brush from Bed Bath and Beyond that costs about $6. I cut the cleaning brush down and put it in a drill, and then use Quick Glo to clean the insides of the chainring bolts. The Quick Glo has a rust inhibitor built in so the rust is knocked down, use a cheap spray lacquer clear to recoat the steel to prevent further rust. HTH Smiles, MH
Bikes: 2010 Cannondale CAAD 5 Potenza 66cm, 1984 Basso Gap Nuovo Record 65cm, 1989 Cannondale ST Racing Triple 27", 1974 Schwinn Paramount Nuovo Record 26", 198? Scapin MKII 66cm Victory, 1994 Havnoonian Chorus 8sp 27"
Quoted: 45 Post(s)
Liked 101 Times
Here’s my winter invention to clean some Campy bolts…. It’s my fish tank aerator, a yogurt jar and PB Blaster. Left overnight, it worked miracles…. The empty iPad box was just to quiet things down.
