I cut up a gravel fork, here's what I found
Bikes: '23 Poseidon Redwood, '07 Specialized Roubaix Comp Triple, '12 Gravity Fixie, '21 Liv Rove 4, '06? Giant EB Spirit
Quoted: 345 Post(s)
Liked 237 Times
This is a full aluminum, robust fork from a Redwood Poseidon. Pretty interesting stuff
Sunshine
Quoted: 10965 Post(s)
Liked 7,492 Times
They sent you a brand new fork for an issue that was your own doing(or prior owner)?
The stem being too high on the steerer isn't a fork malfunction or design issue.
Surprising they would ship out a new fork. Lucky result!
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1948 Post(s)
Liked 1,471 Times
Expired Member
Quoted: 3674 Post(s)
Liked 5,437 Times
Would be nice to have some pics and a written commentary.
Randomhead
Liked 3,699 Times
Since Poseidon is DTC, they should be willing to warranty some things that a bike shop would have caught. But I just watched their assembly video, and it didn't say that you should check the stem to make sure the spacers are right. It's already on the bike when the consumer gets it, and they just tell you to loosen it and turn it around the right way and tighten it up again. So having the spacers wrong really is Poseidon's responsibility. That's asking for liability. It's really common for this to be wrong on new bikes. Having an 18mm gap is unusual though, I would say.
It's not too surprising that the fork was really heavy. Aluminum isn't a great material for forks, and they are usually overbuilt. A friend had a suspension fork on a bike and decided to get a rigid fork to save weight. When he finally weighed the two forks, the suspension fork was a little lighter.
Another issue that causes clicking on aluminum forks is they only weld them at the bottom of the steerer. So the steerer is pressed in and welded at the bottom. Lots of them start clicking at the crown race. It's a problem.
The thing about the Poseidon is that it’s a very cheap bike in a performance-oriented market segment. Of course it has a very heavy fork. It would be heavy and dead in steel, too. I had an aluminum fork Kona Jake at one point - still a bike aimed at a price point, but not anything like as cheap as Poseidon. The fork was fine. Looked fine, worked fine, rode fine, weighed fine. Aluminum forks are very common on affordable hybrids. They work fine. I have an aluminum fork on my 75 lb electric cargo bike - it’s fine. Is it overbuilt? I sure hope so. I would hope a steel fork would be overbuilt, too. I’ve had a lot of forks, from steel to aluminum to carbon fiber. So far, I’ve only managed to break steel ones - not that it was the steel’s fault. Steel is also a fine material for a fork.
Likes For grolby:
Quoted: 1400 Post(s)
Liked 1,885 Times
aluminumumumum aluminumumumum aluminumumumum
carbon forks were just coming on the scene when we installed the Kinesis alloy fork on the Schwinn Peloton - if it would have been a year or two later probably would have gone with a carbon fork
Randomhead
Liked 3,699 Times
I am surprised the people who like aluminum forks came into this thread and posted pictures of vintage forks. Are there any lightweight rigid aluminum road forks still sold? I would take a picture of the aluminum forks I have owned, but they have all been recalled. Even the higher-end aluminum forks I have seen are very heavy.
Liked 1,885 Times
as I‘m sure you are well aware - aluminum forks were pushed out by carbon forks
