giant trekking / suspension fork / lo-rider mounts
someone had axed about the giant trekking bike. saw one downtown
today. it's a 700c with a suspension fork and disk brakes. comes with
a front platform rack mounted to the canti brake bosses.
the giant branded fork also has dual eyelets at the dropout for racks
and fenders. AND it has a 2/3-of-the-way down eyelet for fenders.
AND it has a mid-fork low-rider mount.
saddlesores, While some may poo-poo the idea of using a suspension fork, I think it's a good move by Giant. Any idea if it's able to be locked out?
Brad
Brad
i also would poopoo a suspension fork for touring.
i just thought it was a neato peachy-keen fork
with so many braze-on attachments. lotta threads
asking about mounting lo-riders to suspension forks.
anyway....i think this here is the giant "trooper"
comes in various models....3300, 5300, drop bar
or trekking bar, etc. around $500
it's a giant branded fork, i'd guess it's prolly
a relabeled suntour. they come in different
levels. some with lockout, some without.
i'd have to check more carefullyer next time
i'm near the shop.
here's a taobao listing with photos:
GIANT½Ý°²ÌØTrooperµÛ°Ø5500ÂÁºÏ½ðºûµû°ÑÂÃÐгµËͳµÊ×µÆÂë±í-ÌÔ±¦Íø
wow! just noticed the 5500 trooper frame has internal cables.....
i'm near the shop.
Quoted: 3453 Post(s)
Liked 1,453 Times
I generally have not looked at suspension forks on lower end bikes, but I do not recall seeing one before that was raked with a lower bend in the fork blades instead of or in addition to an offset crown. Is a front suspension fork with curved fork blades as unusual as I think it is?
This summer I plan to do an off road tour and will be using a suspension fork. Food and camping gear for 8 or 9 days is going to be a bit tricky to collapse down to the volume I will have available.
I bought a frame bag and some extra large rear panniers, plan to use my big handlebar bag too. I would like to transfer more weight from the rear to the front wheel, but I want the weight to be sprung, not unsprung weight. Thus, I do not want to use a rack mounted on the front axle/skewer or lower part of the fork. If Tubus still made the swing rack, I would buy it.
I bought some very similar front racks to the ones pictured, picked them up at a clearance table. It never occurred to me to put one on a suspension fork. I might do that as a back up location for overflow capacity of lightweight stuff.
saddlesores, The fork looks to have a lock out, thanks for the link.
Brad
Brad
Question remains Who is the vendor Giant buys their forks from. the supplier obviously can paint & Logo the lower section for them before assembling it.
My Koga Miyata 04 wtr has a short Travel Spinner made fork, painted to color match the frame ,
and they used a raised boss on the Casting offering a place to bolt on a block machined for the purpose of the top low rider rail mount,Tubus Ergo rack. *
without having the bolt stop the sliding motion.. a custom batch made for the production run of these bikes .
* itself a custom OEM batch made for Koga, with a front kickstand.
bob: i saw some giant msds's with suntour as the fork supplier. canna say for
sure if this one is as well, but assume so.
tourist: the pictured racks are unsprung, but you know that, right?
brad: the link is to the 5500 (with internal cables). higher pricepoint. i think the
one i found is the 3300. doesn't appear from my photos to have lockout.
here's a link to the 3300 model ($400) for comparison:
Ô*×°ÕýÆ·Ðлõ2014½Ý°²Ìص۰Ø3300TROOPER 3300ÂÃÐгµ×ÔÐгµ-ÌÔ±¦Íø
Liked 1,453 Times
But, I might use a small rack like that for a convenient spot to strap on small lightweight items when I go on my off road tour this summer. The bike I will be using can use a 100mm travel suspension fork or the solid fork that came with the frame, for this trip I will switch to the suspension fork.
Tubus tried to produce a rack, the Swing, that fit on the fork crown to let the suspension work with minimal unsprung weight,
but too many different forks are made to have 1 product play well with all those forks , so they ceased producing it.
https://www.tubus.com/documents/1322734401_MASwing.pdf
So now a custom fabricator (with good liability coverage) will be needed to make something, similar, for a specific fork.
Imperton
Bicycle Mechanics
1
04-11-13 06:45 PM
3speed
Mountain Biking
5
05-08-11 02:08 AM
