Forged in Fire episode last night
Quoted: 622 Post(s)
Quoted: 18319 Post(s)
Liked 4,487 Times
They all looked like steel frames to me. Fine tig welded, thin dropouts when visible.
GOOD RIDDANCE of those bikes Fixies?
I'm wondering if the issue with using bike tubes for canisters is that they would risk blowing out when one started mashing on them with the hammers and presses. Also, their presses seem optimized for square canisters.
Oddly, the one thing I didn't see them use was the U-Lock and cable locks. They should donate good steel.
In fact, the U-Lock would have been enough steel for use without the canisters.
For that matter,also the brake/shift cables, and cable housings.
However, one issue might be zinc.
Could one flash off the zinc before sealing the canister?
Ok, I've managed to find the show.
The walls of the bike tubes are probably way too thin at less than a mm thick at the ends for the sort of brutal wielding those guys generally do. It would be ideal for the "leave the can on" as the tubes have so much less material to grind away to find the hard steel.
The paint might be another problem, that stuff is pretty toxic when it burns.
Liked 4,487 Times
If you watch the show much, you know that one of the major failure modes comes from having to wield many small pieces into a larger billet. A lot of small parts means lots of chances for failure. The cables are probably the worst, with built in voids everywhere. One show they made blades from 1 to 2 inch thick cables, and it was a horrible mess.
The bicycle brake and derailleur cables are likely small enough that they wouldn't introduce huge voids, although cheap cables are galvanized, and even the quality ones should be cleaned.
Cable Housing should be able to be flattened easily enough, then like other things, it may come down to cleanliness.
For the cable locks, one might be able to chop the cable into say 1/2" chunks, and if a twisted cable, it should unravel enough to fill most of the voids with the filler metal. For a braided cable, it could be harder to separate.
Bikes: 1976 Raleigh,2015 Bianchi Intenso, 2012 Specialized Secteur.
Quoted: 48 Post(s)
I didn't see the episode but I am a knife maker. Most common bike frame steel doesn't have as much carbon in it as we would want for hardening. For example, Reynolds 531 is said to contain .35% carbon. Most knife steels will have .70% or more.
On edit, you could probably make a knife out of the axles and bearings if you wanted to as they would likely be higher carbon.
Quoted: 7628 Post(s)
Liked 3,448 Times
Processing time also. The tubes would need to be sawn into short lengths, stripped of paint, and oil and rust inside, then pounded flat and stacked and forged to make a Damascus billet. Huge time-intensive effort since the tube walls are so thin .... the entire frame might not yield enough steel to make a single blade.
Wattsup
General Cycling Discussion
228
11-17-18 09:00 PM
Cyclist0108
6
05-17-18 07:42 AM
