Rando bike build, what C&V frameset works?
Quoted: 18418 Post(s)
Liked 4,532 Times
Interesting collection of parts.
Are the Campy brakes levers just brake levers? Do you have separate shift levers to work with your Dura Ace/Ultegra derailleurs & Cassette?
Is that the era of long spline freehubs? So you're limited to a few 10-speed cassettes?
A few things that you might consider:
S&S Couplers? They can be pretty expensive, but used ones pop up from time to time.
https://www.ebay.com/itm/Fausto-Copp...L/264214690645
https://www.ebay.com/itm/Waterford-1...s/123689472197
If you're lucky, you can get a travel case with your bike or frame.
Another thing to consider... I've been intending to build up a bike with 853 tubing. Hopefully a little stiffer than other tubing choices.
That would give you some Lemonds. But, a few others will pop up too. Finding a good frame with all the rack or fender mounts could be a problem.
Quoted: 5891 Post(s)
Liked 3,475 Times
The two limiting factors in looking for an older steel frame are the rear hub (you will need to spread the frame to deal with that rear hub, which looks to be 130 mm) and the brakes. Measure the reach on the brakes and find a frame that works with them. That won't be hard as the reach on those brakes are likely 39-49 mm.
https://www.sheldonbrown.com/calipers.html
Spreading the frame is very doable.
TekMann
Bicycle Mechanics
8
07-27-13 10:59 PM
EjustE
Classic & Vintage
2
04-28-10 08:07 PM
