Packing the Tent
Packing the Tent
OK, I have always been one to roll my tents. My reasons follow:
So then I got a new tent (MSR Hubba Hubba) and find that it doesn't roll up into a tight small roll very easily. I am not sure if it is the material or something else about the design. Any way it got me to thinking about possibly using a compression sack. My concerns with that are:
I am one to leave camp early, sometimes well before daylight, so letting everything dry in the mornings is not an option. Drying out during the day seem like an extra hassle that I'd like to avoid as much as possible. Drying out in the evening isn't always an option.
So my question is, how do those of you who use a compression sack or even just a stuff sack for the tent deal with those issues?
These days I typically just use my bivy when solo, but do sometimes use the tent when touring or backpacking with someone else.
- The wet bottom stays on the outside and the tent doesn't get any wetter (or drier) even in an all day rain
- The dirt on the bottom doesn't contaminate the tent
- My previous tents easily rolled up pretty small
- It winds up being one compact package that carries nicely on the rack
- Moisture on the bottom seems like it would get distributed to the whole tent
- Dirt would seem likely to do likewise.
- It would wind up being two bundles (poles and tent)
Bikes: s-1
Quoted: 221 Post(s)
I don't usually bike tour, but with that said, when hiking and camping I pack a small tarp to put down under my tent, keeps the bottom clean. as for wet, I haven't found a good solution.
Quoted: 18424 Post(s)
Liked 15,582 Times
Can you maybe find a compression sacks that allows you to roll and pack the tent and then compress it so at least the diameter is not so large?
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1350 Post(s)
Liked 1,245 Times
Stuff it in a pannier.
One reason I don't want Waterproof panniers.
Let it dry out when you get some Sun.
Fred "The Real Fred"
Probably not helpful for your situation, but I use a hammock. Pack up the hammock, clean and dry, into a compression, dry sack, then take down the tarp separately and pack it into a non-waterproof bag. I was using a nylon bag that came with the tarp, but I just ordered a mesh bag for this job that will hopefully allow the tarp to dry a bit on road (weather permitting).
When I was using a tent, if the tent got wet, it packed up wet. The solution to make sure at the end of the trip, the tent got set up, dried out, and all the dirt was shaken/brushed out of it.
One thing that might be helpful in my set up, is that the compression sack I had been using is the Summit To Sea eVent dry sack: eVent Compression Dry Sack | Sea to Summit
It lets out air, and, theoretically, moisture even after it's all sealed up. That might have an advantage over a standard dry sack that will prevent air and water from passing in either direction, making sure anything you pull out of the sack is just as moist as it went in. But, to be fair, my compression sack has often been stored in my Ortleib, so its waterproofness has not been really tested, and neither can it really "vent" any water vapor when it's just stuck inside a larger dry bag.
They probably would have given you a new tent. My MSR Fling was peeling pretty bad, a number of years old, and I didn't have a receipt. I contacted them and asked if they could repair it, replace it, or give me a partial credit on a new tent. The sent me a new Hubba Hubba at no charge.
Quoted: 663 Post(s)
Liked 496 Times
I always roll up tents because they take up the least amount of space that way. If the tent is wet from dew or rain , the moisture can add several pounds of weight. If it is wet, I stop at the first opportunity and lay it out to dry. This takes 10 minutes during which I have a bike to eat or make tea. I would rather stop than carry the extra weight.
On the ground sheet suggestions... I typically don't use one and prefer not to start again. I really don't want to carry the extra weight and I have generally always had something other than the floor fail first. I always figured that I would re-treat and/or patch the bottom as needed until eventually I'd start using a ground sheet when the bottom was really trashed. The thing is that, other than a very rare patch, the floors on my tents held up fine.
Bikes: Surly LHT 26in 52cm 2008
Canadian Jam knot
google Canadian Jam Knot
Liked 15,582 Times
Quoted: 1182 Post(s)
Liked 833 Times
I stuff a wet tent, and don't worry about it as long as it is clean. If the fly is really wet I'll store it in a plastic grocery bag, separating it from the tent in the stuff sack, or store the wet fly separately. It depends how much space I have. I've never had mildew or mold problems, but we usually dry everything in a reasonable time, no more than a day or two, weather permitting. I have had it in the compression sack longer, but have been lucky.
This is our Sierra Designs Lightning 2 tent (old model), fly, and ground cloth in the blue compression sack.
aka: Mike J.
Back in my backpacking days, and later motorcycle camping, I used a ground cloth for the dirt/leaf/pine-needle protection, then would use a towel of some sort to dry it off as I rolled it up. Fold, wipe, flop, wipe, roll half a turn, wipe it off, roll half a turn, wipe it off, repeat until done. This would take care of the bulk of the dirt and water or moisture issues. Then as noted above, later in the day roll it out to let it air out some while having a bite to eat or looking at maps or whatnot. If it is raining day and night then just let the moisture freshen up when you set it up each night to hopefully avoid the rot and mildew issues.
That's what worked for me in the past, adapt and adjust to suit your own preferences and needs.
Life happens, don't be a spectator.
Quoted: 3462 Post(s)
Liked 1,468 Times
I do not think you are going to be able to reduce the volume of the tent enough to make a compression sack worth it.
I generally do not bother with compression sacks for anything that is not insulated, since only insulated stuff reduces volume so much with pressure.
I did something similar, front right Ortlieb Frontroller has the tent body, fly, footprint if I carry one (usually don't), small stuff sack with stakes - the stake sack keeps the dirt from the stakes off the tent. Also in the same pannier, rolled up air mattress and flip flops. Tent poles in the tent stuff sack are strapped onto rear rack with velcro. Note that I do not even bring the stuff sack that the tent came with since I just shove it in a pannier.
Staehpj1, I suspect you are not using four panniers, since you are an ultra light camper not sure if you even use two. But in your case instead of the Ortlieb Frontroller that I use, I think a lightweight drybag of about 8 or 10 or 12 liters would make more sense. Then just strap that on top of the rear rack - or maybe hang it from the front bars in bikepacker fashion.
Instead of a tent footprint, sometimes I bring one of those one-time-use disposable emergency space blankets. I only would use it if I was camping on gravel or rock and was afraid it would chafe my tent. But if there is soft ground or green grass or loose sand, I just put the tent on the ground. Since I started carrying that instead of a footprint, I have never camped where I thought I would actually need it, so the emergency space blanket is still brand new.
In the photo, the tent poles are in the blue bag under the pita bread.
Hubba hubba tent, I know several people that really like it. I suspect you will too.
Lentement mais sûrement
Quoted: 78 Post(s)
I stuff my tent and don't worry about it. I try to stuff it so the bottom stays "on the outside" to keep rain out of the upper body.
Quoted: 659 Post(s)
Liked 7 Times
Agreed. Most of my tents I have rolled up since that made it easier to get them in the supplied bag but I've always stuffed my Eureka Solitaire and haven't noticed any issues with moisture or dirt. If it's wet when I pack in the morning I try to get it set up as early as feasible in the evening so it can dry out. I don't use a ground cloth either and also figured that if the tent floor ever wore out that I could tape on a 'footprint' then - but so far I've never had an issue with a tent floor.
Cheap Plastic vapor barrier a little smaller than the floor of the tent.
when It gets a Hole . I just replace it.. as a Moisture barrier even dry cleaner bag weight plastic will do.
I rolled it up to the width of the pole sections, with the poles in the middle .
rolled tent goes in a Bag, width not compressed but strapping the tent to the Top of the Rack
& tightening The Buckles. it certainly gets made smaller
Quoted: 138 Post(s)
Liked 17 Times
Stuff it in the kitty liter buckets. One of the things you don't really want to do is to always fold the tent the same way everytime unless you want to have it form creases and the ability to crack/slice quicker than it would otherwise. I always stick the tent on the bottom of the kitty liter bucket and put something on top of it that is in a plastic ziplock bag and that keeps everything else high and dry and clean. It doesn't get stuff the same way everytime which helps to avoid the creasing problem. Granted this past summer, on a 75 day long trip, I probably only used the tent 10-12 nights...most of the time it stayed in the kitty liter buckets day and night.
Clark W. Griswold
Quoted: 4360 Post(s)
Liked 4,001 Times
Quoted: 141 Post(s)
Liked 9 Times
I roll my tents and put them into a stuff sack just because for some reason on a tour I am super compulsive about neatness. I also tend to leave before the sun. Ground sheets might help keep the bottom dry but do nothing for the sodden top. Usually I have the best of intentions about stopping to let it dry, particularly because I use my hammock about 50% of the time, so it will stay packed for an extra night unless I try to dry it in the evening. Its a hassle, but if the day is dry, it only takes a few minutes. If its raining, then it stays wet!
I also use non water proof panniers, but dont notice that anything really drys in them over the day. I try to mop up as much water as I can from the interior and exterior with a towel, but the last trip it was so wet all the time that my super absorbent towel was mildewing, as it never dried during the day.
Guess I just wanted to let you know that your not alone. Usually I just take my hammock and a tarp, but on trips over two weeks prefer the options of both.
Rod & Judy
Bikes: Specialized S-works E-5, Davinci joint venture , CoMotion Pangea
Quoted: 21 Post(s)
Liked 7 Times
I used to roll, now I stuff, also do love TYVEK, much lighter than a traditional groundcloth or footprint and the moisture stays in it. which I roll BTW
R&J
R&J
Quoted: 760 Post(s)
If you get a piece of Tyvek wash it a time or 2 to wash out the stiffness. A few backpacking places sell it by the foot. Zpacks maybe, but it is out there.
Real Men Ride Ordinaries
Quoted: 17 Post(s)
I'm an unabashed stuffer. I don't roll for a number of reasons, primarily if I'm being honest, it's just easier. Also, I worry (Slightly) about rolling creating areas with more wear and tear, perhaps leading to premature failure. As far as moisture goes, I don't worry about it too much for short trips or mild condensation. If it's really bad, I'll set up the tent during lunch to let it dry out a little. Sometimes it just stays wet.
Quoted: 696 Post(s)
Liked 910 Times
