Bianchi Campione D'Italia info
Bikes: 1983 Univega Super Strada, 1986 Panasonic DX5000, 1984 Fuji Team 85 Univega Gran Turismo, 1984 Lotus Unique, 1987 Centurion Expert, 1987 Centurion Ironman Master,
Quoted: 677 Post(s)
Liked 459 Times
Not having any luck on the vintage forum so I thought I'd try here. It's a 1997 so not exactly vintage. The owner doesn't know much about it except everything is original and in excellent shape.
I guess the bike sold for $1,100 when new and he's asking $400 for it. Is this a lightweight bike? Good deal? Thanks
Quoted: 276 Post(s)
Liked 6 Times
I'm definitely not an expert on that bike but from what I can tell it's chromoly steel frame and fork. Nothing special as far as steel goes but not a cheap frame either. It has entry level Campy parts. I'd imagine it's around 20 lbs depending on size. Price would depend on your local market. Where I live it would definitely sell for $350-400 with no problem. Things to note are the gearing is 53/39 and 12-23 cassette assuming it's stock. Fine if you are riding in a flat area or are a very strong rider. If you have a lot of hills or mountains you may want lower gearing. It also has a 1" threaded headset which will limit your options to replace stem and handlebars because they are not the popular standard sizes these days. If the bike is well maintained you might be able to ride it as is but with any used bike (especially a 20 year old one) I would assume I need to replace cables, housings, tires and tubes. If you can do all the work yourself then that's maybe $40-50 but if you need to have a shop do it then it might be $120. So just things to consider when you are thinking about total expense of that vs another bike
SuperGimp
I have a 1992 Bianchi Campione (so probably not quite the same thing) that came with shimano RX100 (I think that's what it was... 7 speed down tube shifters). Probably paid about $600 for it in 92. Put ultegra 6500 on it in '98 and recently put 5800 on it. Mine is made of the lower end Tange double butted tubing. I never bothered weighing it but i'm guessing 22 lb or so. If it were one of the Reparto Corse Bianchi models, I'd snatch it up in a second, otherwise $400 might be a little over priced. Mine's a trainer slave but it's a perfectly good bike even 25 years later. Your call as to whether it's worth it.
SuperGimp
As for bars / steams, you can get an adapter to use in place of an old quill stem and then you can use whatever "modern" stem and bars you like. That's actually pretty easy to do.
Quoted: 276 Post(s)
Liked 6 Times
Also I have used quill to threadless adapters for stem on other older bikes and they work but those options are limited and I didn't like the look of them. But yes, there are options
SuperGimp
Location is definitely critical... people want $400 for a rusted out beater in LA.
Quoted: 130 Post(s)
Liked 24 Times
I Had a '94 or campione that I road and raced for many many years. I upgraded the wheels but that's it. Really fantastic bike that I miss riding. 400 seems like a good price to me.
cpstwoart
12
02-09-17 10:18 AM
chiyama
22
12-13-16 06:39 AM
Austinjb
2
08-01-14 05:57 PM
ab441693
Road Cycling
15
07-28-10 01:36 PM
