Interesting finds around the web
#526
aka mattio
that's very cool.
for anybody who doesn't know, Stack and Reach are the two measurements that remove other geometry variables so that you can actually compare the sizes of two different bike models.
Consider this: a bike with a black frame and a lower seat-tube angle and a red frame with a steeper seat-tube angle are next to each other. because of the seat-tube angle, they have very different top-tube measurements - but regardless of that, you still need to put the saddle in the same place to get your saddle:bb relationship correct!
the Reach measurement measures from a vertical line coming out of the bottom bracket, to the middle of the headtube - so it removes the effect of a variable seat-tube angle.
Stack and Reach are the ONLY way to compare the sizes of bikes.
#527
Thanks for publishing this chart, it's a great tool to have available.
I'm interested to know how you came to these values. I've been using "reach = top tube - (cos(seat tube angle) * length of seat tube)" and it gets me pretty close most of the time to published reach numbers but yours are a bit different for the bike I own (Fuji track elite) so I'm thinking you have a different equation.
#528
Quoted: 24 Post(s)
No. But looking at it, maybe I should have. It's custom javascript on top of Chart.js. Next up is figuring out how to get more frames in the legend, then maybe adding options for plotting top tube and head tube length.
That is the equation I'm using if the manufacturer doesn't publish stack and reach. It's accurate if the top tube is horizontal, but if the seat tube is significantly higher or lower than the top of the head tube, it's not great. Take a look at the Dolan TC1 or the Giant Omnium in the graph. They both shorten the reach when going up a size. Now that's probably due to the calculation being inaccurate, but it would be great to know for sure.
Fuji does provide stack and reach for the track elite in their geometry chart, and I'm using the 2015 one here. Is yours possibly an older model year? I can add it assuming I fix the legend size issue.
#529
aka mattio
it should work if you use "effective top tube" measurements, which assume a horizontal TT in situations where there is not one.
#530
Quoted: 24 Post(s)
Glad you found it useful. I've been trying to decide if I'm flexible enough to get a Hoy, based on riding a Langster pro 54 and 56 rentals at Hellyer.
#532
Bikes: T1, S2, P3
Quoted: 5 Post(s)
Looking at that chart explains why I had to use a -35 stem and still wasn't as low as I wanted on my T1 lol. Although I guess the 'slammed' stem is stiffer than having 4 inches of steerer tube sticking out, which I believe why cervelo was notorious for having such large stack heights on all of their bikes.. But I did just buy a new frame yesterday, which puts me 45mm longer reach and nearly 50mm less stack, so it will take some getting used to Im sure.
#534
Bikes: T1, S2, P3
Quoted: 5 Post(s)
ha well Im still waiting for it to arrive, hopefully get to build it up this weekend and will add pics. Kind of feel dumb as I already sold my current bike so have nothing to ride but the rental bikes at the track right now lol
Not sure its public yet but its the same bike our national team is moving to!
#535
Looking forward to the photos.
Discussion - "Hard evidence for weight training for track sprints?" in the Google group cycling-physiology
https://groups.google.com/forum/#!to...gy/6DiYuZevYT4
#536
that's very cool.
#537
Quoted: 24 Post(s)
Bobby sent me stack and reach numbers for the Dixie Flyer!
I updated the graph... https://googledrive.com/host/0BzwSdU...GdKVk0/2d.html
#538
Elitist
Quoted: 1386 Post(s)
Liked 92 Times
(Most of you know about this)
Tissot Timing is the official timer for most (if not all) UCI events. They post results and sometimes live data on their site:
Tissot Timing - Results -
The data goes back for several years for several events (mostly World Cups and World Championships, but other stuff like European Championships will be there, too. Events date back to 2000.
Tissot Timing - Results - CYCLING TRACK
Pay close attention. If you ever see "Analysis" next to an event, that will list the "audit" split times every 125m for an event. For example:
Also, look up top and see general info like schedule, registered teams and racers, communiques (official docs and statements)
This data is "straight from the horse's mouth" when it comes to results.
#540
Wow, I just found a video of how I spent a good part of my summer. It kind of gives you an idea of the extra things Ttown does to attract larger crowds. Too bad there weren't any clips of old guy racing on Saturdays.
https://youtu.be/O35WZi7lSt4 Okay, there's one old guy(50+) in the Sr4 field . Unfortunately, he didn't win.
https://youtu.be/pFjtkCVx_AM
#542
aka mattio
So there's this gif.
https://pbs.twimg.com/tweet_video/CS0t5pnUcAA7Qci.mp4 The announcers said that since Hoogland went backwards so that he could take the lead, rather than to give up the lead, that the going-backwards wasn't labeled a violation.
I scanned the rulebook but couldn't find the rule about how you can only go forwards. Anybody what that rule states?
#543
Bikes: T1, S2, P3
Quoted: 5 Post(s)
Is there not a rule for how long you can track stand? Or how many times? I thought in there it said something about rolling backwards. Or maybe thats one of the silly longest lap rules
*I quote UCI rules that I make up all the time*
#544
aka mattio
the trackstand rule is:
3.2.039 The rider on the inside of the track, unless overtaken, shall lead at least at walking
pace and make no manoeuvre to force his opponent through until reaching the
pursuit line on the opposite side of the track. A maximum of two standstills shall be
permitted for each race. The maximum period for a standstill shall be 30 seconds
following which, the leading rider shall be directed by the starter to continue. If he
fails to do so, the starter shall stop the race and declare the other rider the winner of
the heat. In a three or four-up race, the race shall be immediately rerun as a two or
three-up race, without the relegated rider.
#545
#547
Lapped 3x
It was 8 inches, or 20 cm. It was rule 3.2.040 which got eliminated January 1st, 2002. It stated that a rider was not allowed to pedal backwards to get behind an opponent. It also stated hopping of the bicycle to accomplish the same thing was illegal as well.
#548
aka mattio
i found this pic from Revolution featuring a Giro helmet I hadn't seen before... like a new version of the air attack, with some of the styling of giro's new snub-tailed TT helmet that i had seen on world tour teams this year - but this one is roundbacked.
#549
some places are racing thru the winter.. Six-day racing: Madisons, mayhem and the Ministry of Sound - BBC Sport
but they had to invest in a building and a Track in it. to have it inside.
#550
Tickets for Rio Olympic Track Events are on sale.
To purchase tickets for all the sessions would cost 2,550 to 3,000 Euros.
https//www.tickets4summergames.com
