fork designed for loose ball bearing headsets?
commu*ist spy
I bought a new headset to replace the pos loose ball bearing headsets I've had on. they came with new race cups that are compatible with the cartridge bearing type. however, my bike's fork is shaped to take the loose ball bearing assembly, so there's a change in the stack height on my stem spacers because there's a 1 cm gap between where the fork ends and the steer tube where the headset sits. Is there an adapter out there to take care of this? right now, my headset is clicking under load...
certified vegetarian
Bikes: 1973 Schwinn Paramount P10-9, 1988 Cannondale SR2000, 1994 Bridgestone XO-4, 1998 Bianchi Sam Remo, 1998 Ibis Spanky, 2009 Soma Rush, 2012 Surly Crosscheck
Quoted: 5 Post(s)
I'm having trouble picturing that in my head, could you take a picture?
Randomhead
Liked 3,713 Times
did you take the crown race from the old headset off?
Quoted: 454 Post(s)
Liked 104 Times
Did your not come with bearing? thinking that if your having issues following the manufactures instructions (also supplied with a new headset) it's time to take to to a LBS and get them to sort.
Bikes: 61 Bianchi Specialissima 71 Peugeot G50 7? P'geot PX10 74 Raleigh GranSport 75 P'geot UO8 78? Raleigh Team Pro 82 P'geot PSV 86 P'geot PX 91 Bridgestone MB0 92 B'stone XO1 97 Rans VRex 92 Cannondale R1000 94 B'stone MB5 97 Vitus 997
Quoted: 392 Post(s)
Liked 49 Times
Well, it would be nice if you rolled the bike into some brightly lit place to take your picture. But it looks like you failed to remove the crown race of the old headset from your fork.
commu*ist spy
