disc brakes: 180 front, 140 rear?
Quoted: 5 Post(s)
I rarely see any configs where the front is more than 1 size bigger than the rear (e.g. 180/160, or 160/140), and just as - if not more common - they're the same (e.g. 160/160). Why not go 180 front and 140 rear? This config came to me for 2 reasons: 1. Want more stopping power from mechanical disc road brakes 2. Currently have 160/160, and noticed quite a bit of dings/scratches on the rear drop out, right around where the rotor comes closest to it. a 140 disc would have a good bit more clearance. (I can't believe it'd been able to torque over that far, but the scratches didn't make themselves.)
Non omnino gravis
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,426 Times
+1 check that the mounting brackets/hardware can put the caliper in a position to accommodate the rotors you want, if that's ok, then more (braking) power to you!
Quoted: 5 Post(s)
appreciate the feedback on sizing up, also; sounds like a good plan.
afraid of whales
Quoted: 347 Post(s)
Liked 5 Times
My Soma Saga's fork can't take a 180mm disc. It doesn't really matter, when I'm heating up my brakes it's from dragging them. If I have to drag a brake, I drag the rear brake, much safer if I have to turn (esp when it's wet or icy). If you look at some downhiller's bikes, the rear disc is bigger than the front because they almost never use the front brake.
On a related subject, I have 160 mm front/140 mm rear, and the rear brakes seem to give me more stopping power than the front. Does this sound right? I've never ridden another bike with disc brakes and have nothing to compare it to.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,426 Times
does not sound right to me. Front brakes generally provide more stopping power because of weight distribution especially as you are thrown forward while stopping, and a larger rotor should make that difference even bigger
Bikes: Gilmour road, Curtlo road; both steel (of course)
Quoted: 273 Post(s)
Liked 10 Times
Fronts do more of the work because of weight transfer and a larger rotor will accommodate that better.
That's why virtually all cars have larger front brakes...
Today, I believe my jurisdiction ends here...
meh
Quoted: 1110 Post(s)
Liked 1,013 Times
Not that we are talking about the same kind of bikes... the Surly Pugsley comes with 180/160 stock.
