Easy Chain Lube
Easy Chain Lube
Today I came up with an easy way to oil the chain. Previously I'd been using an oil can putting one drop per roller of Bar & Chain lube, there was plenty of waste and a mess of spatter even after wiping the chin with a rag.
I came up with the idea of using a disposable 3" paint roller, and found out it works very well to put just a film on the chain. Just like in painting the roller is absorbent and will not over oil the chain.
First I clean the chain, then I just pour a small amount of bar oil into the included tray, and roll the roller into the oil, then holding it against the chain I pedal backwards several times on the bottom and top of the chain. You don't have to wipe it off either as the roller just leaves a light film.
Quoted: 839 Post(s)
Liked 1,061 Times
I'd be concerned that doing it this way only leaves a light film on the outside of the chain and not where you want the lube which is inside all the moving surfaces.
Likes For Crankycrank:
Quoted: 7348 Post(s)
Liked 2,474 Times
That's an innovation! I might just try it.
Maybe my method is wasteful or dirty, but I squeeze the oil bottle to make a constant stream, and I turn the cranks backward to roll the chain under the stream. Then I wipe off the excess with a rag using the same backward motion. To make this work, it's important to prop the bike up such that the pedal doesn't knock into anything.
Likes For noglider:
Quoted: 569 Post(s)
Liked 584 Times
I am with Cranky, I'd probably pull the master link and see if it got lubed, if so give it a try. Also not all together sure dealing with a 3" oily roller is a major step toward less waste and mess.
Likes For easyupbug:
Quoted: 1062 Post(s)
Liked 665 Times
Bar and chain lube is chainsaw oil. I've used it myself in the past for winter riding, because I had it for my chainsaw and decided to try it on the bike. I doubt that it comes in a bottle with a tip, and it might be too viscous and sticky to apply in a graceful fashion. Usually, you just pour it into the reservoir in the chainsaw. So the roller might be a cleaner way of doing it.
Aside from the usual tradeoff between rust protection and picking up dust & grit, the oil worked just fine, but my chain was still rusty by spring.
Likes For Gresp15C:
Liked 2,474 Times
I wonder why that doesn’t happen to me. Maybe I drip more sparingly. But I use very viscous oil.
Quoted: 839 Post(s)
Liked 1,061 Times
Just give the chain a good wipe with a rag after a few miles of riding after lubing. This usually gets rid of the excess lube that flings off onto your spokes.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
I prefer to apply thick lubes off the bike, then wipe it down really good before re-installing the chain on the bike. That keeps it from splattering everywhere. If you want to apply it on the bike, a thinner lube is probably a better idea.
Liked 2,474 Times
Upon thinking further, I think using the oil bottle directly on the chain is easy enough. Jeez, maybe I should make a video. It doesn't seem that hard.
Likes For noglider:
Quoted: 663 Post(s)
Liked 496 Times
I pour about a table spoon of oil in a small plastic cup and apply the oil liberally with a Q-tip and spin the pedals. I do this in the evening and let it sit overnight before wiping the crud and excess oil off the following day. Periodically, I go back and spin the pedals some more. I also use a piece of plastic of tyvek house wrap under the bike to catch drips.
For those using bar & chain oil, what I recall people doing with that is to thin it slightly with mineral spirits. (I used this mix for a few months before going to Rock n Roll Gold & been doing that since)
And you could even use an old Rock 'n Roll bottle (or anybody with a tip that's removable so you could fill easily) or what I used to do was put some BC oil & Spirits mix in a container & siphon into a child medicine dropper (like pharmacy gives you for baby medicine...essentially an oversized eye-dropper) and use that to apply. Once container gets low, refill with more mix. (I think I did 1 part mineral spirits to 3 parts BC oil)
Lately I'm getting super tempted to try parafin wax/parafin oil setup. I'd love to have such a clean drivetrain, but the frequency of redressing may drive me batty.
