Campy disc brakes are in, and I have questions
Bikes: Mikkelsen custom steel, Santa Cruz Chameleon SS, old trek trainer bike
Quoted: 70 Post(s)
Liked 6 Times
First: https://www.bikerumor.com/2017/05/09...omment-3202926
Stoked. Very stoked. But, I am pretty uninformed on the whole flat mount standard. I know there are some compatibility issues with IS and post mount, but I cannot recall if that is with an IS or post mount frame fitting flat mount calipers, or a flat mount frame fitting IS or post mount. Can anyone clear that up?
Also, I have also heard that my older (2011ish) Chorus derailleurs may not work with newer Ultrashift levers, is this the case? Just trying to figure out what I'll need to buy...
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
If you have 2011 Chorus...you'll need to buy everything sans cassette. Derailleur cable pull was changed in 2015.
I am a little surprised that Campy bothered to make front and rear calipers simply to do away with the typical mounting adapters for flat mount calipers. I like it, but I'm surprised. The levers...meh. I'm happier with my mechanical levers and hybrid disc calipers, for now.
cuda2k
22
12-24-18 09:41 PM
garciawork
Bicycle Mechanics
18
01-31-18 01:05 AM
