Upgrading 27s to 700s
Some basic information you may need to consider:
70's Nishiki International 10-speed
Right now I have:
Rims - Sunrims CR-18
Wheels - Vittoria Zaffiro 27 - 1 1/4
I've put a little over 1000 miles on them both, and want to get some better tires, and have been leaning towards Schwalbe Marathons. which they do have in 27s, online.
Would it just make more sense to upgrade to 700s so I'd have more tire options and wouldn't have to order them online again in the future?
My thoughts are, that the rims are still just fine, and should have many more miles to go on them, so spending money on new ones just seems excessive right now. but, it might be for the best.
Right now, I'm mostly just commuting around campus and around town, putting in roughly 5-10 miles a day, but I want to tour more as well.
Thanks for your help
Right now I have:
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
Excessive. The only way to do it cheap is find a donor bike and make a quick swap. But financially, it does not make sense. I buy all of my tires on line anyway, as I get a lot lower price. I have several bikes with 27 inch rims, and several with 700c rims. But I would not spend money to make a swap.
If I am building up a frame, I will use 700c wheels (off a donor of course).
+1 To the comments below, you can end up having problems with your brakes, which will cost more money to address.
You can't put 700c tires on 27" rims. Some say a few unusually large 700c tires will fit on the smallest 27" rims because everything has tolerances, but normally it doesn't work.
27" Zaffiros are a 27tpi tire. Pretty thick, coarse sidewall plys.
Try some Conti Ultrasports or Panaracer Paselas if you want more performance. Also, make sure the tube is small and thin. It's fine to use a 700c innertube. If you got innertubes for 23-28mm tires they might roll easier.
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,928 Times
if you are inquiring about upgrading the wheelset to 700c from 27 that can be tricky. you will most likely need new longreach brakes. 700c wheels are just small enough that they will often not work frames made for 27" wheels without new brakes
Sugar "Kane" Kowalczyk
Bicycle Repair Man !!!
Buy the 27 inch Marathons... barring accidents those rims will last as long as the Marathons and then you can think about the 700c upgrade.
Hmmm. Didn't I say it was possible? It's also possible to jump in front of a bus. I guess I should have spelled out that you can't do it without serious consequences stemming from too-tight fit.
Quoted: 7350 Post(s)
Liked 2,475 Times
I don't see the point in changing your rims. I'm riding 27" rims and don't plan to change to 700c. I recommend the Panaracer Pasela (non-Tourguard) tire, at $20 on the web. Very nice for commuting. They're not heavy duty. The sidewalls are quite thin, which make it feel light and quick. If you need heavier duty, perhaps the Marathons will be better.
Kid A
Liked 5 Times
To OP: Yeah, I've done it without any problems. Just make sure your road brakes have the extra 4mm of pad movement to reach to the new rims...which is seldom a problem if you're using the old brakes.
That said, I've never had issue with 27" wheels and finding tires.
Kid A
Liked 5 Times
Maybe so - most of the weinmann brakes I've used seem to have pads mounted just about in the middle on a 27"...which usually gives enough for 700c.
YMMV.
YMMV.
Quoted: 3376 Post(s)
Liked 5,521 Times
Bikes: Masi, Giant TCR, Eisentraut (retired), Jamis Aurora Elite, Zullo, Cannondale, 84 & 93 Stumpjumpers, Waterford, Tern D8, Bianchi, Gunner Roadie, Serotta, Serotta Duette, was gifted a Diamond Back
Quoted: 305 Post(s)
Liked 2,038 Times
Older than dirt
Bikes: Too darn many.. latest count is 11
Actually, you only need 4mm in travel on the pads in the slots to make 700's work. More often than not that is available. You're making it out like it's magic or complicated and it's far from it.
I'd be more concerned that the rear dropout spacing is correct and not the older 120mm versus the newer 130mm.
Quoted: 140 Post(s)
Liked 163 Times
My mileage has indeed varied, that's why I posted what I did. There are old brakes out there that aren't Weinmann's, or maybe Weinmann's you haven't worked on, or maybe frame/forks you haven't worked on, etc, etc.
It's a good practice on this forum to open your mind to the fact that if you haven't worked on a wide range of stuff in regard to a certain issue, you really aren't qualified to make blanket statements based on your personal experience. Report your experience, being specific, but don't make blanket statements like "it's seldom a problem" if, as in this case for example, you've only converted a few old bikes with a certain brake.
Quoted: 1858 Post(s)
Liked 664 Times
What tire do you want to use? These are pretty good ones, in addition to the heavier Marathons or Armadillos.
Liked 664 Times
Right now I have:
Right now I have:
Kid A
Liked 5 Times
I post on here in a similar way to how I speak to real people out there face-to-face. This forum isn't a way for me to polish my thesis composition skills or make myself seem more intelligent.
I used the words "maybe so" and "seldom"....what the hell is your problem?
Quoted: 140 Post(s)
Liked 163 Times
Dude, get a life.
Palmer
Quoted: 1671 Post(s)
Liked 1,825 Times
Shouldn't have to order 27s - millions of bikes out there that use them! Should be able to find them at your LBS, small town hardware and autoparts stores, suburban big boxes, etc.
Available 27s should be fine, and surprisingly, more commonly available in rural American touring destinations.
tcs
tcs
I don't understand why everyone wants to convert to 700'cs when their 27's are in good shape.
Old Tech doesn't equate to bad. I'd take a high end pair of 27's over a cheap intro level set of 700'cs anytime and that doesn't require screwing with your brake setup. Most of my road bikes are 27's, only one is 700c, I've never had problems finding tires for any of them. Hell I've even found 27's at the local department store.
Bianchi Goddess
Liked 2,928 Times
