Various hubs
Bikes: many
Quoted: 1466 Post(s)
Liked 1,432 Times
Various hubs
Still thinning the herd, now trying to get my hubs down to a reasonable number. Here's what I have. Links are into Google Photos. All prices are OBO, net to me and include shipping CONUS. Happy to provide some quantity discounts. Note that the Avocet hub is the only one with a skewer. Let me know if you can't see the photos or want more.
- Suzue high flange front hub, 36H, 100mm OLD, $25. (This is the same hub I listed a couple days ago.)
- Avocet rear hub with matching skewer, 36H, 128mm OLD, $25.
Campagnolo Tipo high flange hub set, 36H, 117mm OLD, English threading (I think), $50. Note the narrow rear spacing. It seems clear someone subbed the drive side locknut and spacer. You will need to swap in the correct bits to make it right.- Galli low flange front hub, 36H, 100mm OLD, $25.
- Campagnolo Nuovo(?) Tipo low flange hub set, 36H, 120mm OLD, Italian threading, $50.
Fuji Fan
- Campagnolo Tipo high flange hub set, 36H, 117mm OLD, English threading (I think), $50. Note the narrow rear spacing. It seems clear someone subbed the drive side locknut and spacer. You will need to swap in the correct bits to make it right.
Bikes: many
Liked 1,432 Times
I don't believe so. There's about 12mm exposed outside the lock nuts between both sides. One could fix the width dilemma and still have several mm to spare.
Quoted: 843 Post(s)
Liked 2,215 Times
I’d like to buy the Tipo HF hub set if still available. PM incoming…
-Randy
'72 Cilo Pacer '72 Peugeot PX10 '73 Speedwell Ti '74 Nishiki Competition '74 Peugeot UE-8 '86 Look Equipe 753 '86 Look KG86 '89 Parkpre Team Road '90 Parkpre Team MTB '90 Merlin Ti
Avatar photo courtesy of jeffveloart.com, contact: contact: jeffnil8 (at) gmail.com.
-Randy
Fuji Fan
Bikes: many
Liked 1,432 Times
It's off to its new owner, but I measured the rest axle before boxing it up. My calipers said 129mm. That seems about right if your frame has 4mm forged dropouts. Maybe 127-128 would have been better? 🤷♂️
