Compressionless brake cable housing for derailleur too?
Quoted: 8 Post(s)
Liked 9 Times
if you can live with blue this is a great bargain.https://www.amazon.com/dp/B01N3007DM...ding=UTF8&th=1
Likes For Duuuuuude99:
Bikes: Cannondale tandems: '92 Road, '97 Mtn. Mongoose 10.9 Ti, Kelly Deluxe, Tommaso Chorus, Cdale MT2000, Schwinn Deluxe Cruiser, Torker Unicycle, among others.
Quoted: 279 Post(s)
Liked 207 Times
I ordered Jagwire compressionless brake housing when doing a complete overhaul of my most recent tandem. Let's just say I am NOT impressed. The performance improvement between my standard SRAM brake housing and the Jagwire is marginal, if even that. It works, no doubt, but the rear brake is pretty squishy, which compares similarly to my other road tandem. Running Ultegra STI with Avid v-brakes via Rollamajigs. Old tandem running 105 STI with old Deore XT cantilever brakes. Both are similar in the rear brake's squishiness.
I took extra time setting things up for best brake performance by routing my cables to reduce length, but while still preserving good arcs and interface at the cable stops and noodle. I'm also a stickler about cutting the ends well and then bench-grinding them flat & perpendicular (while at the same time NOT melting the liner). And using appropriate synthetic lube on the cables. In other words, I've taken about every step to ensure excellent brake performance. But one concession: I'm using cable quick-disconnects, so they are imparting some additional cable stretch into the system.
"Compressionless" isn't really what it says it is - EVERY housing will compress under brake cable tension forces. It's impossible to avoid ANY compression in they system. Ferrules will move slightly, angles are never 100% perfect at the housing/cable stop interfaces. You just do everything possible to reduce it.
That said, I'm perfectly happy with brake performance. Especially given overhauling the Arai drum brake resulted in FAR better performance than I expected. I can almost lock up the rear wheel with the drum alone. But standard brake performance pales in comparison to a rear hydraulic brakes!
One side note: it's fine to use "compressionless" brake housing for shift cables, but generally NOT a good idea to use typical shift housing for brakes. It isn't designed for the higher compressional loads of braking and can catastrophically fail when you need your brakes most!
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times
Quoted: 3515 Post(s)
Liked 2,929 Times
I think it’s important to remember there seem to be two types of compressionless housing: housing that almost looks like regular housing which features wires that run the length of the housing, wrapped in Kevlar, and covered with colored vinyl.
The other kind is made up of “links” or “beads” as mentioned above.
I’ve never used the link type and don’t intend to.
Definitely heed the advice not to use compressionless derailleur cable housing for brakes. The increased pressure used in braking will burst non-Kevlar-reinforced housing—not good.
Likes For smd4:
Quoted: 805 Post(s)
Liked 2,988 Times
Wheelman
Bikes: 1982 Holdsworth Avanti (531), 1961 Holdsworth Cyclone
Quoted: 298 Post(s)
Liked 676 Times
Compressionless 4mm shifter cable came in with SiS in about '85/'86.
Before that I believe shifter cable outer was the same as brake cable outer.
When I first overhauled my 1982 Holdsworth Avanti a couple of years back I replaced all the cables with the "obviously much better" modern stuff - Shimano Dura-Ace/Ultegra level.
The shifter cables started pushing through at the rear stay cable stop, looked around for ferrules then realised the stop was made for 5mm outer.
Replaced the shifter cable outer with a piece of the brake cable outer and no ferrule, problem solved.
It's been working fine for the last 1500 miles.
So my point is: some bikes do not want modern shifter cable.
Quoted: 4423 Post(s)
Liked 1,569 Times
