How come my derailleur is like this?
Bikes: Cannondale Bent 2, Fuji Royale, Mongoose Snare
Quoted: 103 Post(s)
Liked 8 Times
It's in the second to highest gear. Seems kinda high up there no? Haven't ridden it in a while. Was having problems with this derailleur.
Also, anyone know of a video that shows how the adjusting screws work with maybe like a transparent animation? So far I've not been able to figure it out by looking at it or hearing instructions on how to use them. I need something visual that could hopefully show me how the insides of it work.
Likes For juntjoo:
Really Old Senior Member
Is it on a chain ring up front? Other than the smallest?
Put it on BIG:BIG and see how much "slack" is in the chain.
You want 1 to 1-1/2" (2 to 3 "half" links). Anything more contributes to the condition shown in your picture.
Habitual User
Quoted: 4957 Post(s)
Liked 8,103 Times
Your chain is too long.
Likes For Eric F:
The chain could be too long but if that chain has been on there a while it may be that the tension spring in the barrel of the derailleur (inside the part where it attaches to the axle) may have broken. When you move the derailleur down (counter clock-wise), does is spring back on its own? You might also check the stop screw to see if it allows the derailleur to rotate too far to the back.
The skewer may need some attention also. Most folks have the lever on the non-drive side of the bike.
Quoted: 3515 Post(s)
Liked 2,929 Times
Chain looks too long to me.
Likes For smd4:
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
Chain is either too long or it's not on a front chainring.
Likes For Lombard:
Quoted: 2339 Post(s)
Liked 2,833 Times
sure looks there is like a crack in the derailer also
Likes For squirtdad:
Liked 2,929 Times
That *might* be a weird shadow.
Likes For smd4:
Quoted: 18382 Post(s)
Liked 4,515 Times
It is more convenient to have the lever on the left side. However, when I was pulling trailers a lot, I put my levers to the right so they wouldn't interfere with the trailer (after breaking a lever 15 miles from home and the nearby sporting goods store said they could order a new one for me in a couple of weeks).
Quoted: 1143 Post(s)
Liked 1,758 Times
I would put some oil on the chain and all derailleur pivots, it looks very dry. That's where I would start. It could be your bike had a longer caged rd before the one that's on there now. The chain may be have an extra link. If your chain is long you can also set via small to small and remove links until there is no drag at the rd cage.
Mad bike riding scientist
Quoted: 6222 Post(s)
Liked 4,222 Times
I suspect that the chain wasn’t sized when installed. It looks like it was just taken out of the box and installed, especially considering that the bike is in the second smallest gear. Here’s how to size the chain properly.
Stuart Black
Stuart Black
Likes For cyccommute:
Quoted: 4422 Post(s)
Liked 1,569 Times
FWIW: based on the photo, I think the OPs RD may be this one (or another STX/Alvivo RD from the same time frame):
https://velobase.com/ViewComponent.a...108&AbsPos=588
If it's the RD-MC32, here's the EV and SI (SI is common to several STX and Alvivo RDs):
EV: https://si.shimano.com/en/pdfs/ev/RD...MC32-1466B.pdf
SI: https://si.shimano.com/en/pdfs/si/00...001-00-ENG.pdf
Hope these help.
Hope these help.
