Campy Ultra Narrow chains and connect links, etc
I find nothing about my bike so confusing as Campy chain compatibility, so perhaps you can help me out.
I run full Campy on two bikes, both 10 speed that use ultra-narrow chains. As of yet, I don't own the Campy chain tool, but I can see it in my future.
My bike shop (a good one) has told me that there is no "missing link" that will work with the 5.9mm width of the Campy chains. Both IRD and Wipperman seem only to work on the older 6.1mm width.
I have heard that SRAM chains will work with a Campy set-up, but I have also heard that they will NOT work and things will explode on me.
In any case, I have two brand new Campy chains that I want to install. My only option here is to shell out for the chain tool, correct?
EDIT: I installed one chain very, very carefully with a regular chain tool and it seems OK. Did I just made a $60 mistake by installing it without the tool? This is why I was hoping for a missing link of some sort ...
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 26 Times
Liked 7 Times
The Campy tool is best but you don't have to use it if you are very careful and follow the Campy instructions. Whatever tool you use must have a skinny drive pin to avoid damaging the links. It is also important to keep the drive pin centered on the link pin. Most tools have replaceable drive pins. I use a Shimano 10-speed chain tool on my Campy 5.9 10-speed chain.
I understand that the 11-speed chain is another animal.
Al
Al
If he doesn't chime in, could ya? I have suspected that my LBS is perhaps more interested in trying to get me to pay them to put my chain on than in selling me what will enable me to do the work myself, but this issue does seem complicated. I also do a lot of long distance rides, and want the solution that will have the lowest odds of me finding my chain in two pieces (at the connect point) several hundred kilometers from home.
Pretty much any 10 speed chain should work on a Campy 10 speed drivetrain. I've used KMC DX10, DX10SC, old school (non-ultra-narrow) Campy Record C10's, and the newer Ultra Narrow stuff. I have also heard of people using Shimano chains with good results. The Campy chains tend to last longer, but IMHO this is more a matter of materials and construction than any compatibility issues.
As for master links, I've used the Wipperman Shimano-specific (6.05mm, I think) link on the ultra narrow Campy chains with good results. KMC now makes inexpensive Campy 5.9-compatible master links as well. (See here.)
Excellent! Thanks. I was looking for the Superlink IV, but it was out of stock so I grabbed one of these instead. Let's hope it works out. I'm committed to Campy chains at least for one more season (since I own them already) but might look into another brand of chain for next year. Thanks again.
The special KMC link, a SRAM 10 powerloc or Forster superlink model 4 will all fit. The only difference is SRAM and Campy are .1-.15mm narrower across the inner plates, so links that fit the other brands will be a sloppy fit. The ideal side clearance is in the .1-.2mm range.
And, just because I'm new / dumb at this, by using this link I can now use any 10 speed chain tool to install the link, correct?
[QUOTE=trigger;10362066]Thanks! I went with the KMC as it was both readily available and made to fit Campy (5.9mm). What do you hear about it's reliability / longevity?
And, just because I'm new / dumb at this, by using this link I can now use any 10 speed chain tool to install the link, correct?[/QUOTE]
Incorrect. No chain tool is needed. Remove a set of outer plates from your chain, exposing inner plates on both ends.
The KMC link plates and pins just lock together. It'll be obvious when you get one in your hand.
Quoted: 2026 Post(s)
Liked 1,096 Times
For future reference, Wippermann's 10-speed chains work very well on Campy drivetrains. I've been using them for 12,000 miles on an otherwise all-Chorus 10-speed bike and they run quietly, shift extremely well and are durable. Their Conex master link is easy to install and remove.
Bikes: Waterford 2200
I was informed that Campy doesn't make the Ultra Narrow Record 10sp chain any more, you now have to use Chorus chains on Record.
Make mine a double!
Make mine a double!
Actually, there should no new Chorus 10 chains either, since both models are now 11 speed. What you should see is a Veloce/Centaur model. The quality and longevity will be the same as Record, but the outer plates have no holes in them and the pins are also solid, not hollow like Record.
https://www.campagnolo.com/jsp/en/gro...VE_catid_1.jsp
I've always used Centaur chains, so it's no issue for me. It does make me think that Campy is really going to try to push us all into 11 speed whether we really want it or not, but I'm going to ignore that for now.
