What cables to use with 8 speed Campy ergos
Bikes: Vitus 979
Hi all. I have a Vitus which is running a mix of Campy and Shimano in the drive train . Cranks and front derailleur are Campy Athena and it is currently running a Shimano 600 rear derailleur and hub. Shifters are the down tube type and I'm looking to upgrade these to Campy Ergopowers. To do this I have purchased a set of early (I think 1st gen) 8 speed ergos, a chorus 8 speed rear derailleur and new wheelset with Campy 8 speed hub. I'm now looking to buy a new cable set so I can put it all together but I'm a bit confused as to what will and won't work (there seems to be lots of conflicting info on cables out there ). Ideally I'd like to have blue cable housing so aftermarket cables would be preferable. I've seen some posts say Jagwire make campy compatible cables (not sure which ones) but that these are double ended and one end needs to be cut which can cause fraying! Has anyone got experience with this - good, bad otherwise? Any advice would be great! Thanks!
Quoted: 1074 Post(s)
Liked 295 Times
For housing, it's not critical. Normal concerns apply, brake vs shifter housing, diameter etc.
For brake cable Campy use the regular stuff.
For shifters, Campy buttons are a little smaller than standard. Standard shifter cable buttons may seize in Campy shifters.
With good cable shears, cutting a double ended cable is a non-issue. Dremel will also work. MAPP torch.
Buy galvanized and solder the end. Plenty of options and plenty of threads on how to seal a cable end.
Constant tinkerer
Already stated above, but to put some more emphasis on it: make sure you use ONLY Campy style shift cables as the head is smaller. Shimano style cables will get stuck in Campy shifters and be very difficult to remove. Use whatever housing you like.
kojTL1000
Bicycle Mechanics
12
05-07-13 11:09 AM
billallbritten
Bicycle Mechanics
8
06-27-11 03:54 PM
athenstrestle
Bicycle Mechanics
4
01-19-10 06:13 PM
