Pedal sealed bearings
Old 09-02-19, 02:13 PM
Troul
Troul's Avatar
Liked 2,938 Times in 1,902 Posts
Has anyone sourced cartridge bearings for pedals?
I have a pair of pedals that contain one cartridge bearing per pedal & one of the peds has a bad bearing. I know I could just buy a new pair of pedals, but I like the pedals, they just have poor quality bearings & it's not hard to push out the bearing assembly. If it's not too much cost, buying some new cartridges would be easy to install.
From the bearing it has "7989" etched on it. Its center hole appears to be 1/4" I.D.
I am tempted to convert it to a brass journal bearing, if I can find the size.
-Oh Hey!
Troul is offline
Old 09-02-19, 02:37 PM
Moe Zhoost
Half way there
Moe Zhoost's Avatar
Quoted: 985 Post(s)
Liked 879 Times in 526 Posts
Get a caliper and measure its dimensions: ID, OD, and width. You should then be able to use those parameters, as well as the type of bearing, to find a match. For the ID, it's probably more accurate to measure the diameter of the spindle than the bearing itself.
Manufacturers typically design their stuff around what bearings are available. This means that the bearings you need are used in a host of other applications so they should be easy to find.
Also, if you don't have a digital caliper, you need to run out and get one. The cheap import ones work well and are reasonably accurate. Harbor Freight has them at a bargain price and with a 20% off coupon, it's even better.
Good luck.
Moe Zhoost is offline
Old 09-02-19, 02:47 PM
AnkleWork
Bikes: old clunker
Quoted: 684 Post(s)
Liked 105 Times in 83 Posts
That would be best.
AnkleWork is offline
Old 09-02-19, 05:32 PM
davidad
Quoted: 582 Post(s)
Liked 171 Times in 138 Posts
That's not a valid number. There should be a number on the seal or shield.
Maybe something like this? https://www.enduroforkseals.com/prod...3/R4LLBC3.html
davidad is offline
Old 09-02-19, 06:58 PM
HillRider
Quoted: 2026 Post(s)
Liked 1,095 Times in 741 Posts
If you take one of the old bearings to an industrial supply house (e.g McMaster-Carr, Grainger, etc.) they can probably match them to new bearings. As noted, manufacturers almost always use a stock bearing size.
HillRider is offline
Old 09-02-19, 07:53 PM
TimothyH
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times in 469 Posts
Enduro has some PDF files showing bearing kits and part numbers which can probably be sourced. Stainless, ABEC3, ABEC5...
https://www.endurobearings.com/support/catalogs/
They also list a couple of pedal kits for Look, Speedplay, Time...
https://www.endurobearings.com/wp-co...kitcatalog.pdf
-Tim-
TimothyH is offline
Old 09-02-19, 08:05 PM
Mad Honk
Quoted: 1297 Post(s)
Liked 1,886 Times in 1,133 Posts
I have a local bearing dealer that is great to work with. Look around or find an old copy of the book "Yellow Pages" and search for one in your area. I took a used bearing out of a set of Bulls Eye jockey wheels into them and they brought out two new ones from their existing stock on hand. Ordering from them is just a few days turn around, and they have almost every size available that I have needed. I am going to use them to replace all of the bearings for my Superbe pedals that were damaged in a fire. I can get them locally for $8, or pay $19 on Flea Bay. Smiles, MH
Mad Honk is offline
Old 09-02-19, 08:14 PM
dedhed
SE Wis
dedhed's Avatar
Quoted: 2739 Post(s)
Liked 3,381 Times in 2,046 Posts
https://www.motionindustries.com/miL...jsp?LANGUAGE=0
dedhed is online now
Old 09-03-19, 08:50 AM
Troul
Troul's Avatar
Might go there to see what my options are. I did take a few minutes to see what kind of pedals are out there thesedays that might be better than what I have & appeal to me. I like the composite material type, so my options seem to be still limited, but Xpedo, Raceface, & Crankbrothers show some composite pedals that use double & triple bearing per pedal that look good.
-Oh Hey!
Troul is offline
patricio.montes
Bicycle Mechanics
25
02-08-19 09:38 AM
Andiroo99
Bicycle Mechanics
14
07-23-17 07:38 PM
Tandem Tom
Bicycle Mechanics
4
10-06-15 08:27 AM
c_dinsmore
Bicycle Mechanics
4
02-23-10 04:16 AM
