What’s your number one tire lever?
#52
Bikes: Electra Loft 7i, Fuji Crosstown 2.5, Gravity Liberty FB, Schwinn Voyageur
Quoted: 57 Post(s)
Liked 8 Times
Mine are like these: https://www.parktool.com/product/tire-lever-set-tl-1-2
#53
Bikes: TRIMMED DOWN THE HERD
Quoted: 1092 Post(s)
Liked 936 Times
#54
These, if you can find them:
Michelin Tyre Levers | Chain Reaction Cycles
I guaranty you that whatever lever you're using is not as good. Unless it's these. They slip right under, they're no muss/no fuss and they don't break because they don't rely on blunt force trauma.
Plus a VAR tire jack, for tight tires I use 2...
#55
I vote for pedros. I used tot hink they were bombproof but I broke on last week
It was 10 years old though.
#56
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times
For alu and steel rims - dirt cheap and work even with toughest Marathon tyres without braking:
For more expensive rims - Schwalbe (plastic) levers.
#57
A real cyclist doesn't use tire irons. A real cyclist can get a tire off and back on without them and without breaking a sweat.
#58
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,426 Times
#59
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
My favorite is whatever is in my bag rather than lost on the roadside or forgotten at home at the previous repair
#60
Bikes: 2016 Felt Z85 105, 2016 GT Grade Sora
Quoted: 117 Post(s)
I tried reasonaly hard to break a pedros last night mounting a conti GP 4seasons... no such luck. i will say that it was very strong but, for removing the tire, i think i prefer the park tool tire levers. but, i'll say that i much prefer the pedros for getting the tire back on. i'm going to start carrying one of each.
#63
Quoted: 5224 Post(s)
Liked 3,581 Times
just used mine for the 1st time cpl days ago. so, thanks for the recommendation. I used my regular plastic levers for most of the job but used this unit to finish up. I should have viewed this video as a refresher before starting. I have some more tires to swap, so I'll be using it again before too long. hoping to follow the instructions more closely & seeing the full benefits
was just reading the instructions that came with my new Michelin tire & was surprised to see this tip for tire removal: "unclip the beads around the rim and push them down into the rim well" makes sense, but I usually just do that (push beads into well) when installing. gotta try that next time I take a tire off!
#64
Bikes: 2007 Ridley Excalibur, 2003 Orbea Orca, 199? Cannondale Headshock MTB hardtail
Quoted: 520 Post(s)
Liked 10 Times
I also have been using black plastic ones that snap together. Mine have "Trek" on them but wouldn't be surprised to see many others with the same design. Have also used blue plastic Park ones and snapped one in half. Also used to used quick stick but thought that the lever was a bit too thick for the tire bead at times.
#65
Quoted: 7348 Post(s)
Liked 2,464 Times
I see you can now get plastic tire levers with steel cores. That sounds smart.
#66
Jedi Master
I bought these ridiculously priced lyzene levers to get free shipping on an order a while ago. They're small, light and they won't break which is nice. Otherwise they work pretty much the same as the cheap plastic ones.
#67
Quoted: 117 Post(s)
Arizona Dessert
Quoted: 5345 Post(s)
Liked 2,169 Times
I've never used them to put a tire on The last bit I use my palm and rub it in, not so hard if you keep the loose beads in center of rim.
I only use one to get a tire off. A large fat yellow one, Pedro I think.
#69
Disco Infiltrator
Liked 2,105 Times
I still use some metal ones my Dad had in his tool kit. I think they’re stainless. More reliable than plasticbut also more likely to mar
#70
Disco Infiltrator
Liked 2,105 Times
+1
#72
Portland Fred
I find the ends break of plastic coated steel ones. For winter commuting, I carry steel ones which never break but it's too easy to damage the tube -- I don't care about scuffing the rims.
For vaguely normal conditions, I use Park or Pedros, both of which are decent but which sometimes break.
#73
Quick Stick, in the rare case that my fingers are not up to the job. I'm really shocked to see that Quick Stick is not very popular in this thread.
#74
Quoted: 3375 Post(s)
Liked 5,513 Times
#75
I used this for the last flat fix, as I somehow removed my levers from my saddle bag:
