2002 Specialized Hardrock Comp A1 FS any good???
I just got me this bike...here are the specs....
I am looking to upgrade some of the Cheapy components...problem is...I am new to biking and need some advice on what to upgrade. Are these components pretty good????
Technical Specifications
FRAME Aggro A1, Premium Aluminum TIG welded, rack eyelets, replaceable der. hanger, and disc mounts
FRONT FORK Rock Shox Judy TT, with preload adjusters, 80mm travel
HEADSET Ritchey, 1-1/8", threadless
STEM Specialized alloy, 15 degree rise, black
HANDLEBARS Specialized alloy, 30mm rise, 6 degree sweep, black
TAPE / GRIPS Specialized Double Density, kraton
FRONT BRAKE Forged alloy, linear pull, w/MC pads and linear spring
REAR BRAKE Forged alloy, linear pull, w/MC pads and linear spring
BRAKE LEVERS Shimano ST-MC-20, black, Alivio
FRONT DERAILLEUR Shimano FD-330, 34.9 clamp, bottom pulll, Acera
REAR DERAILLEUR Shimano RD-MC20SGS, Alivio
SHIFT LEVERS Shimano ST-MC-20 Black, Alivio
CASSETTE Shimano HG, 11x30, 8-speed
CHAIN Shimano IG-31, 8-speed
CRANKSET Specialized Forearm Comp, w/black arms
CHAINRINGS 42x32x22, Super Shifter III, w/ black outer ring
BOTTOM BRACKET Shimano LP-28, square taper, 68 x 110, sealed cartridge bearing
PEDALS Specialized, twin sided, composite, toe-clip adaptable, with reflector
RIMS Alex DM-20, 32h, 26", alloy, double wall, w/machined side walls, black
FRONT HUB Formula FM-21, 32h, alloy, Q/R
REAR HUB Shimano RM-40, 32h, black, QR
SPOKES 14GA, stainless, black, w/brass nipples
FRONT TIRE Specialized Rockster, 26"x2.10", black skinwall
REAR TIRE Specialized Rockster, 26"x2.10", black skinwall
TUBES Specialized, schrader valve
SADDLE Specialized Sport MTB w/Body Geometry technology (OEM)
SEAT POST Specialized alloy, 30.9x350mm
SEAT BINDER Specialized alloy clamp, alloy quick release
NOTES Chain stay cover, reflectors, owners manual
Uhhhh.....I guess this bike is not that good. No replies!!!
I will give this thing a little more time.......then if I have to....start answering my own questions!!!
This is a great starter bike....good frame. As far as the components I cannot answer that for you since I do not know ANYTHING about them.
LOOKS GOOD TO ME THOUGH!!!
Bikes: Lots
anap, relax dude, it's during the day and most of us have jobs we are pretending to be doing instead of hanging out on the forums.
Yes it's a good bike. I wouldn't change a thing until you break it! Upgrade as stuff wears out or breaks.
If you've got money burning a hole, upgrade the front suspension, then wheels, then.....who knows!
L8R
L8R
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, "WOW, What a Ride!" - unknown
"Your Bike Sucks" - Sky Yaeger
Bikes: Lots
Naked woman,.....maybe!
But as impatient as you are, you'd be HIGH maintenance, and I'd have to pass!
L8R
L8R
Bikes: Nakamura 9000 FS
heyyyyyyyy.... any chance you bought it from a guy in Newfoundland?
i think you bought the bike that i was going to..then didnt
I got it off EBAY actually from someone in Philly....
