Cheap 8sp freewheels on sale
Quoted: 1106 Post(s)
Liked 1,328 Times
Sportchek.ca has Falcon FX-LX80 13-28 8 speed freewheels for ten dollars - "Final Sale"
Only one local store has any left.
I ordered two for pickup to see what they're like.
Quoted: 3810 Post(s)
Liked 6,692 Times
Do they come with extra axles for the ones you’ll break running that 8-speed freewheel? There’s a good reason why cassette hubs replaced freewheel hubs as # of gears increased.
Quoted: 4722 Post(s)
Liked 3,036 Times
I've never used Falcon for replacement freewheels. They were common on department store bicycles and I've seen too many problems with them, including everything from pawl issues to split cogs. So, unless they've raised their standards recently, I'd avoid them.
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Like the others, I've never seen the need for an 8-speed freewheel. If I'm running friction, then 5, 6 or 7 speeds are perfectly fine, being not a "heavy" rider. If I'm starting with an 8-speed shifter, then I'll find a freehub rear wheel for the build.
Likes For Phil_gretz:
feros ferio
Quoted: 1392 Post(s)
Liked 1,324 Times
Interesting. Are they are actually stronger than Campag.? (I broke a 126mm Campag. rear axle on a 6-speed rig.)
Quoted: 964 Post(s)
Liked 1,451 Times
I normally see solid axles as being a good solution, but even the CrMo ones tend to bend when used with 7 and 8 speed freewheels. It's much better than breaking, that's for sure!
I once turned someone an axle out of scrap Inconel 718 on the Hardinge HLV lathe. She had broken a hollow axle running a 7 or 8 speed freewheel, and could not find a solid axle for sale. I machined it with a step that seats against the cone, like those old Raleigh axles, on the right side. I don't know if it helped things, but it certainly didn't hurt, as I radiused the step to avoid a stress-riser. Hard to fathom why solid axles don't come this way. It's the only solid axle I have ever seen that hasn't bent in use with a 7 or 8 speed freewheel, but I think it weighs more than my entire American Classic rear hub.
Likes For scarlson:
Quoted: 930 Post(s)
Liked 1,291 Times
They are stronger than cheap hub axles but no stronger than Campy and other high end hub axles. They still break, even with only 6- and 7-speed, which use 126 mm OLD. When you go to 8-speed, you are widening the OLD to 130 mm, which is a bridge too far. Those are not going to work unless you're a 98 lb weakling riding on roads as smooth as a baby's bottom.
South Carolina Ed
Bikes: Holdsworth custom, Macario Pro, Ciocc San Cristobal, Viner Nemo, Cyfac Le Mythique, Giant TCR, Tommasso Mondial, Cyfac Etoile
Quoted: 344 Post(s)
Liked 291 Times
