Dealing with blow outs on tour - possible repairs?
Bikes: Surly Disk Trucker, 2014 w/Brooks Flyer Special saddle, Tubus racks - Duo front/Logo Evo rear, 2019 Dahon Mariner D8, Both bikes share Ortlieb Packer Plus series panniers, Garmin Edge 1000
Quoted: 405 Post(s)
Liked 115 Times
First off, I am not talking simple "flat tires".
What I am referring to are two types of "blow outs":
1. Bead separating from rim bead seat
2. Blown side wall where tire tears away from bead
Oddly enough, I had #1 happen just today (well, yesterday... its after midnight now). I did a shake-down ride before my trip coming up - loaded - and noticed a bulge in the tire. Mind you, I had just rotated the tires and the rear tire is the one that bulged (was the front for a while). I had an issue with a bit of a "thump" in that tire on the front and found what appeared to be the bead not having been seated properly. I ended up rotating the tires, but in both cases when I remounted the tires I massaged the side walls to ensure the bead seated better.
The above having been said - when I got back from my shake down ride I was a bit surprised to see the bulge after taking care in how I mounted the tire.
I took the tire back off the rim, completely, and inspected the tire. It is all in tact - there is no separation of the bead or other abnormalities in the tire itself. So I re-mounted the tire. This time I did notice the tube near the valve stem was interfering with the bead seating. So I massaged that a bit differently and tried to get the valve stem part of the tube back up inside the tire more on that side.
From a previous thread a poster mentioned to "seat" the bead by using 2x max pressure. My tires are rated to 85psi and I was going to do 140psi. I never made it there. I hit 100PSI and KABANG! I did have safety glasses and ear muffs on just in case things went "boom" and they sure did.
On inspection - the tire did not give out. The bead came out of the rim and the pressure inside blew the tube apart in a long slice at the separation joint.
So I again took the tire back off the rim and inspected it. There is some "scraping" of the bead where the rubber is abraded off of the bead, but there is no separation of the bead anywhere.
One thing that baffles me is why, after massaging the side walls to seat the bead, that the bead would come out of the seat like that? I could understand if the bead was up inside the rim too far on one side, causing excess tire sidewall and bead to show on the other side, but that does not appear to be the case.
So I put a new tube in and remounted the tire. This time I was also careful of the tube near the valve stem and interference with the tire. I got the tire on and massaged the side wall as I did the past few times. Everything looks OK. I pumped it to 85psi (max rated) and test rode it. Everything seems just fine.
However, I am not very confident in that tire.
Tomorrow I am going to pick up another tire so I have a spare.
As for the subject of the thread - are there any ways to deal with blow-outs to, at the very least, be able to limp until a proper repair/replacement can be made?
In the case of #1 - where the tire is not damaged, but the tube gets a slice in it - is there a way to use, say, a strip of an old tube as a long "patch" - installed the same way as a small hole patch with scuffing and glue? Maybe a strip of Duct tape?
In the case of #2 - if the side wall separates from the tire is there any way to reinforce that area to hold any respectable pressure to ride on? Maybe creatively placed duct tape along the tube to keep it from stretching through the blow out zone?
On a bit of a tangent - what are everyones thoughts on rolling up a wire bead tire in tighter circles that the regular OD of the tire? I know kinking the beads as would happen when folding is bad - but if it is condensed in a tighter circle will that work? Or are there problems in doing that, also?
Quoted: 1073 Post(s)
Liked 999 Times
You can try patching a slit tube, easiest is to replace it with the one of 2-3 spares you should always carry. But using an old tube as the patch is fine, just have to really clean the powder off it.
Tire separating from the bead, best is to boot it, keep it under inflated, ride slow and potentially walk down the hills; there's no long term safe way to deal with this.
You can safely loop a wire bead tire, 3 loops is the most I've seen and done but if you're worried carry a folding spare, weighs less and packs a lot smaller.
Quoted: 405 Post(s)
Liked 115 Times
What is "looping" a wire bead tire?
Liked 999 Times
Booting is putting something inside the tire to keep the tube from pushing through. Often people keep a 5 dollar bill the seat pack. Good for coffee and an energy bar when needed and when folded in half strong enough to not rip or tear when stuck between a tire, with a large hole or tear, and the tube.
Wire bead tires will be ruined if you fold them. But if you put your hands at two ends and give a gentle twist you can create 2 or 3 loops that fold against each other. 3 is the max I've seen with 700c and thin 26". A Kevlar tire of course comes folded in a small box and makes a better backup
Quoted: 1188 Post(s)
Liked 1,154 Times
You know the 85psi Max on the tire is the actual max pressure allowed by the manufacturer? For seating the bead only, in most cases... If a tire won't seat at "Max" pressure, use some lube.
I suspect the tire is stuffed if it was previously thumping, there are some snapped cords inside the casing, especially now after being over inflated. I have a brand new Schwalbe Supermoto X that simply won't seat properly, the casing is distorted, and I will replace it.
2-Wheeled Fool
Bikes: Surly Ogre, Brompton
Quoted: 1385 Post(s)
Liked 677 Times
Quoted: 405 Post(s)
Liked 115 Times
If the bead can be stretched without signs of breaking - that may be a factor to consider.
In any event, I think I got most of my answering from the replies thus far.
I always have a sewing kit with me - it is part of my first aid kit. For thread I generally use the inner strands of 550 cord. There is the standard 7x nylon strands and there is another kind of 550 cord that has multiple types of strands inside with smaller thread. I don't know what the tensile strength is. Spectra or Dyneema fishing line might be good stuff also.
KC, read your post quickly, but first of all, its never necessary to pump higher than max rating to "seat" a tire, there is no need and all you need to do is to make sure the tire is positioned properly and inflate tire normally, and just keeping an eye out to make sure you havent pinched the tube or that the tire wasnt centered properly on the rim.
forget this overinflation idea, its not needed.
I wouldnt trust this tire, if it was doing weird stuff before, and you over inflated it, it just aint worth it.
also, I wouldnt worry too much about cutting a tire or whatever. Sure, it can happen, but if you are riding on pavement, and you have a normal ability to look where you are riding and not run over obvious stuff or run your bike up against sharp objects, a sidewall damage that serious is pretty easy to avoid. If you are really concerned, take a spare tire, but if your tires are in great shape (always a good idea for a trip) its certainly not a necessity.
As a professional driver, you know the most important thing is being aware of what you are riding or driving over at all times, not smacking into sharp edged potholes or whatever because you arent paying attention.
the whole "booting" a tire with an American dollar bill does work great if needed, just be aware that the chances of damaging a tire like this is pretty darn low (touch wood!) but having very good quality tires from the get go to me is the most important, and to always be aware of avoiding debris.
If I happen to run over broken glass if I havent noticed it, I'll stop and take a minute to very quickly run my finger over the tire to make sure there isnt any shards stuck in the tire. Just doing this makes a huge difference, as shards can get stuck in, then over time, work their way in further, causing a flat. Totally worth the 1 minute to do this away, waaaaaaaaaaaaay less time and hassle than fixing a flat. I wet my finger, make a line on tire, then work around to make sure nothing is stuck in.
Recently had to fix a flat on my wifes bike because she ran over stuff she didnt notice, a week later a flat. Same green beer bottle glass shards she ran over the week before and at the time I asked if she ran through the bunch of it that I avoided, but she had no idea. Normally I do the tire inspection right away, but obvoiusly something came up, we were with friends, and I forgot. She never used to believe me about why I do this, but this time was a good example.
Quoted: 2578 Post(s)
Liked 1,901 Times
I just posted the other day, to a different thread, that I've successfully limped home twice with a booted tire and lowered tire pressure. I've also had three or four times when I tried a boot and it didn't work.
Based on that history, I agree with the recommendation to carry a spare tire. Get a light, kevlar belted folding tire. If you have to use it, replace it and keep it as your spare ASAP if you're touring more than a few days longer.
While you're prepping, make sure you know how to patch a tube. No matter how many you take (at least within reason), on a long enough tour you may run out of spare tubes and have to patch one.
Carry 2 folding tires for an unsupported tour. There is no reason to rotate your tires. When the rear wears out put the front on the back and a new tire on the front. You want the least amount of problems with the front tire.
Quoted: 2304 Post(s)
Liked 2,741 Times
it sounds like the tire was not new.....but If it were me, and I was going on any big tour, especially areas that may not have a lot of bike shops (think Hiway 2 across norther montana) I would start with new tires and carry a spare. cheap insurance
Likes For squirtdad:
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 669 Post(s)
Liked 725 Times
And both times I was able to take the ruined bill to a bank and get a new bill. As long as you have both serial numbers, you can turn it in.
On what sort of trips have you carried two spares?
Liked 1,154 Times
1: got a link to a reliable source for this "factoid"
2: There are plenty of larger volume tires that would either explode or damage the rim long before they reached twice the sidewall pressure. Good example is the Surly Extra Terrestrial, it doesn't even like being pumped to it's max pressure of 60psi, at which point it would be way above the maximum rated pressure of any rim you'd fit it to, let alone pumped to 120psi..
Likes For Trevtassie:
You got me. I started late and have only done week long unsupported tours. I carry one folding tire, two tubes, a reinforced gasket material boot and a patch kit all of the time. I was giving the OP options, you?
Couple of things,
I knew that I could find some sort of mediocre 26in tire in smalltown, Guatemala or whatever, but figured it was totally worth carrying one spare, to have another great tire if something weird happened.
In the end, didnt need it, carried the same spare for months and months and months at the bottom of my pannier. Didnt even get any flats on those trips and other trips afterwards on the same set of tires.
so thats my reasoning behind my view that two spares is overkill.
Last edited by djb; 10-15-20 at 08:32 PM. Reason: Hope for the best, plan for the worst
Quoted: 6882 Post(s)
Liked 10,873 Times
Liked 999 Times
hey PD, are you talking mountain biking and going through big rock gardens or stuff like that? I dunno, I guess I've lived a sheltered life but (big touch wood here again) I've never damaged a sidewall of a bicycle tire in all my years cycling, so its hard to imagine that you've experienced it 5 or 6 times--but again, mountain biking is something else where the chances of riding up against sharp stuff is way more common.
Bikes: Soma Double Cross Disc (2017), red Hardrock FS (circa 1996)
Quoted: 215 Post(s)
Liked 153 Times
I had a sidewall explosion after a day ride in the downpour on the C&O: https://www.bikeforums.net/bicycle-m...along-rim.html -- scenario #2 . Loud bang! I was very lucky for it to happen right when I reached Cumberland. So I learned the light way what 10 Wheels says: carry a spare tire on a tour.
Not sure if the tire can be temporarily fixed with a duct tape, but the inner tube is a total loss in this case.
Not that this is a guarantee or anything, but I have found that by going over your bike carefully once a week on a trip, to clean, check bolt tightness, and yes to check tires, is just a good idea to help spot weird stuff going on or at least be aware of things like a little sidewall damage.
at my age now, it clearly helps putting on reading glasses.
even not on tour, the general idea of taking time regularly to check everything on your bike does help avoid developing problems, at least to catch them early. I admit I probably don't inspect my tires closely enough, but i try to.
case in point of blowouts--few years ago we organized a two day ride with friends. Second day, the husbands tire goes KAPLOWEE!!! As the resident mechanic, I go to fix it and sure enough, his tire was worn all to heck right down to the cords, so it inevitable to happen.
also didn't have qr and he didn't have either a wrench nor spare tube. Luckily was towards end of second day, but still was a huge waste of time. To him this "just happened" or was "bad luck" but it happened because his tire was worn and he had no idea.
Quoted: 669 Post(s)
Liked 725 Times
Not that this is a guarantee or anything, but I have found that by going over your bike carefully once a week on a trip, to clean, check bolt tightness, and yes to check tires, is just a good idea to help spot weird stuff going on or at least be aware of things like a little sidewall damage....To him this "just happened" or was "bad luck" but it happened because his tire was worn and he had no idea.
Every time I put air in my tires (and now I need reading glasses just to read the darn gauge), I check the wheels for tire wear and bearing play.
