View Poll Results: When do you toss a tube?
After one patch - every gram matters!
42
21.88%
After two - they just start to look funny.
25
13.02%
After three - you have to draw the line somewhere.
28
14.58%
As soon as a patch has to overlap another patch.
55
28.65%
Never! My patches have patches!
42
21.88%
Voters: 192. You may not vote on this poll
How many patches before you toss your tubes?
Endurance junkie
Bikes: '93 GT Pantera, '03 Fuji Marseille, '05 Klein Attitude, Dahon Impulse, Bike Friday Family Triple
Just put a third patch on a tube today.
I tend to use them as long as I think they are reliable, but realized others might not do the same.
When do you toss / donate / stop using a tube?
NOTE! My wording was somewhat unclear - it should really be how many FLATS before you toss a tube - the first therefore becomes tossing a tube after 1 flat.
"Patches? We don't need no steeenking PATCHES!!!"
Senoir Membre
Bikes: Centurion Le Mans, Bianchi Sport, Trek 3500
0 for me. They are cheap, and I only get a flat once every 10 months or so. Whether that is attributable to this method is a different story.
No patches. I chuck the tube after the first flat. they cost like 4 bucks so why bother with patching
Likes For DOS:
In the right lane
cycles per second
Bikes: Early 1980's Ishiwata 022 steel sport/touring, 1986 Vitus 979, 1988 DiamondBack Apex, 1997 Softride PowerWing 700, 2001 Trek OCLV 110
Quoted: 44 Post(s)
Liked 71 Times
I generally keep patching and using a tube until it gets some damage that cannot be patched.
Rustbelt Rider
Quoted: 261 Post(s)
Liked 372 Times
Well... patching reduces waste.
When someone flats on a group-ride, I generally will "dispose" of the old tube for them. Can go for a long time without buying tubes like that.
+1
+1
I've done the same when I see someone about to toss an old tube. For whatever anal-retentive reason, I don't run patched tubes on my own bikes but I work on enough bikes for friends and family that I find a use for those patched tubes.
Bikes: Priority 600, Priority Continuum, Devinci Dexter
Quoted: 685 Post(s)
Liked 55 Times
Can't say I really have a limit as to number. My neighbor just flatted for the third time in about a month. His tube was new a month ago. The patches are in different locations. A patch in one spot is not going to make the tube more likely to fail in another, so might as well keep on riding it.
Now if a tube is a few years old, then I'm more inclined to toss it.
sigh... just put a fourth patch on my tube yesterday. The first three were caused in as many days by a worn out tire that has been replaced since.
I usually patch my tubes until the valve tears, and then i cut them to make new patches
Bikes: c'dale six13, bobjackson
for me 0, i buy performance tubes on sale for like $3 and usually get 6 at a time. not worth patching anymore.
Primate
Bikes: Concorde Columbus SL, Rocky Mountain Edge, Sparta stadfiets
Liked 5 Times
I do it more now than as a kid.
Back then, a flat tube was an excuse to make a new skateboard-jumping-assist strap.
Bikes: 2009 Mercier Galaxy (custom build), 2008 Argon 18 Mercury
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,174 Times
Quoted: 7348 Post(s)
Liked 2,465 Times
Number of patches doesn't matter. If the tube isn't patchable, it gets replaced. I think I've gone as high as 15 patches, but that's rare.
Quoted: 303 Post(s)
Liked 136 Times
10 yrs ago in the modern era, I put holed tubes on a peg in the basement and happily put new
tubes on flatted wheels. Then one day, about 4yrs later I saw there were 17 tubes hanging
there and new tubes, formerly $1.50-$2 were $3-4 and even more for my long stem requiring
wheels. I started patching, using a bunged wheel to test the repaired tubes. This was helped
by a buy of 20 patch kits from Performance for $10 or ~$0.12/patch. An 8oz can of glue from
Wmart lasts about 5yrs before getting too thick. Then I found Rima patches in 100 packs for
about $16 from AEBike and patch away. Rimas come in 15 and 20mm sizes there which handles
most chores. Tubes now get tossed mostly for valve tear outs and the 17 tubes are nearly gone.
A few survive in the short stem wheels, but recent acquisitions have necessitated buying up a load
of 45 and 60mm stem tubes.
Great State of Varmint
Liked 15 Times
Might as well make a tube out of patches and be done with it!
Seriously though, three has been my limit. If I get more flats - then I want to analyze what is responsible for this. Bad route? Lots of broken-glass? Etc.
headtube.
You have to find the puncture when changing the tube so that you can remove any offending thorn, michelin wire or glass shard from the tire; that's a lot of the work of patching already so you might as well mark the hole in the tube when you find it. The rest of the work of patching is mostly waiting for glue to dry and is best done in batches. I throw punctured tubes in a corner and when there are enough of them I patch them all at once. If you save up a good sized batch it is definitely worth your time at $3/tube.
I have patches that overlap on a couple of tubes and they hold up fine. Tubes get discarded when there's some un-patchable damage.
One old tube lives in the kitchen drawer and helps grip the lids on stubborn jars.
When long distance touring, carry a spare tube; if you get a puncture patch it and put your spare tube in. While you ride on, the glue on the patched tube will dry and will be ready to go in for the next puncture.
