Drop bar ends or aero bars?
Bikes: Saracen DirtTrax 2000, ancient Mongoose road bike
Hey, I currently have a mountain bike and, as my budget won't allow me to buy a road bike yet, I'm trying to make it into a jack-of-all-trades. So, I was wondering whether I should buy some aero bars or drop bar ends. For example, something like brakes...I'd still like to have some straight brake levers for the bit of mountain biking that I do, but if I get drop bars, I'd like to have brake levers on those, too. I've seen several of those old brake levers with extensions(or whatever they are-safety levers?) for sale online, are those a good option if I go with drop bars?
What are the pros and cons of drop bars vs. aero bars?
I've been somewhat leaning towards drop bars, just because I'm familiar with them. I hope I'm not being repetitive and asking a question that's already been answered somewhere. And I'm NOT trying to spark a debate. Mainly the question is, are drop bars or aero bars better for adding to a hybrid/jack-of-all-trades bike?
Graeme Obree used a 'Superman posture' on the Bike .. to give the Hour record a Go, on the track..
https://www.wolfgang-menn.de/pics/obree7.jpg
your hands make the aero entry into the airstream .. but you have to bend way over low also ..
https://cdn.media.cyclingnews.com/pho...perman_600.jpg
same topics are repeated endlessly, you are not the first .. if you do find where the same topic was asked before
and continue on it,
the moniker 'Zombie thread' is thrown about. there is no right way.
dual control pieces are made for triathlon cycle , but They are expensive, but those people
want to win by shopping . if they can ..
and continue on it,
Quoted: 4560 Post(s)
Liked 2,802 Times
I just drape my forearms across the ergo grips on my hybrid's bars. Helps get a lower profile into headwinds and uphills. Works well enough I'm gonna pony up for the pricey Ergon grips that lock into place. My current grips are comfortable but the friction fit won't hold and I hafta twist them back to the desired position a couple of times every ride.
Personally I wouldn't get the Ergon GP2 or similar grips with bar end extensions. That looks like a disaster waiting to happen for a bike that will be ridden on trails where brush or overhangs can snag. Those might be okay for a bike that will be ridden only on the road. I just want the GP1, locking version of my current grips.
Quoted: 1324 Post(s)
Liked 927 Times
i've use aero bars and I've converted to genuine dropbars not drop bar ends. I've also use normal bar ends that were long but mounted them between the shifters and the stem on a straight bar. That gives something to hang onto and lets you assume a somewhat aero position.
If I were to use dropbar bar ends I would be leery about putting brake levers on them because I'd be concerned about torque when baking hard. That's why I went with genuine dropbars on some of my MTB conversions.
Bar ends mounted inboard of the shifters and brake levers on a straight bar.
MTB On The Trail 01b by Miele Man, on Flickr
Cheers
Cheers
Quoted: 1364 Post(s)
Liked 1,678 Times
I did both bar ends and aero bar when all I had was a MTB based commuter. I needed multiple hand positions and added bar ends inboard on my wide handle bars. Then I added an aerobar.
You can see it here:
https://www.bikeforums.net/general-cy...l#post18249346
For The Fun of It
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2135 Post(s)
Liked 1,647 Times
I use drop bar ends on two flat bar road bikes I have and they work great. You'll find your MTB bars too wide for the drops though, and you'll need to cut some off the end of the bars.
Liked 927 Times
You can always do what Sheldon Brown did and mount BOTH a dropbar and above it a straight bar.
Sheldon Brown's 1974 Brown Bicycle
About 1/2+ down the page for the image.
Cheers
Cheers
Cheers
Cheers
Quoted: 189 Post(s)
Bikes: 199? Landshark Roadshark, 198? Mondonico Diamond, 1987 Panasonic DX-5000, 1987 Bianchi Limited, Univega... Chrome..., 1989 Schwinn Woodlands, Motobecane USA Record, Raleigh Tokul 2
Quoted: 1131 Post(s)
You're going to spend more money replacing the bars/brakes/shifters than you would just buying a cheap old craigslist road bike. Not to mention the time saving with not having to switch out brakes/shifters/housings/cables/stems. Converting a bike (regularly) from drop to flat or from flat to drop bars is not a trivial process.
Bikes: 2012 Salsa Casseroll, 2009 Kona Blast
Quoted: 1031 Post(s)
Liked 208 Times
Are you considering completely replacing the handlebar? If so I would replace the flat bar with a drop road bike handlebar. I own an "inexpensive" pair of aero bars, and not only do they make it impossible to mount any cool stuff on the handlebars, they are constantly coming out of adjustment. So I would say go with the drop bars.
If changing handlebars is a thought, maybe try some butterfly trekking bars, or something like the Velo Orange Casey Crazy Bar.
Quoted: 185 Post(s)
Liked 36 Times
That would cost more money than the project would be worth. Op might be able to find a used road bike for a little more than such a project might cost.
Figure 8 bend trekking/butterfly bars offer many advantages of drop bars in their bend shape.
But you get to keep all your straight bar controls , cables as is .
cost minimal.. $25 ish .. plus 2 rolls of padded tape ..
https://www.nashbar.com/bikes/Product...ZNeRoC3qbw_wcB
Thanks guys for all the suggestions!
