Best way to get the sticky stuff off a brand-new chain
Quoted: 50 Post(s)
Speaking of chains, I have a brand new KMC road bike chain that's got the requisite layer of sticky-thick coating on it (WTF is that stuff?)
It's literally so adherent and thick that wiping it down with Simple Green doesn't get it off, and even with serious wiping, there's still a noticeable layer of stickiness on the chain that I'm sure will be a dirt magnet.
Anybody got a reliable way to get all this stuff off the chain?
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1350 Post(s)
Liked 1,246 Times
Mineral Spirits
Fred "The Real Fred"
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12791 Post(s)
Liked 7,698 Times
The BEST way? Probably a caustic bath. For those watching at home, I'd probably use mineral spirits or the like. I just run my new chains as-is, then lube after the first rain ride (usually within a week).
Liked 6 Times
Yeah, just lube it with your chain lube of choice, and wipe it down. Repeat until it's de-stickified.
At the bike shop, I'd toss it in an old waterbottle with a few ounces of Finish Line Citrus Degreaser and shake it for a minute, then rinse with hot sudsy water a couple times, then blow it out with the air compressor and re-lube it. But you probably don't have that option.
Quoted: 13 Post(s)
Liked 7 Times
Same here, except if I don't ride in the rain the chain doesn't get very dirty anyway and I lube it with cleaning lube after a few weeks - month or so. The factory lube is really good lube.
Bikes: Colnago C59 Italia Di2
Why on earth would you want to remove the best chain lube there is? Just ride it and lube when it starts to make noise (Like your GF)
Amen to that. Just wipe any surplus with a rag. Once you've lubed it a couple of times with regular chain oil the stickiness will be gone.
Super Moderator
Quoted: 1173 Post(s)
Liked 929 Times
Those degreasers work well for getting that sticky grease stuff off the ball bearings so you can make them nice & shiny.
enthusiast
Bikes: 2010 BMC SL 01 Roadracer, 2012 Davidson Tandem
Quite right. I also like to pull back the boots on the CV joints on my car and use these products to get all the grease off of the axle joints. Finally, you can get the crankcase of your car sparkling clean by replacing your motor oil with Simple Green.
Quoted: 19 Post(s)
Liked 7 Times
I spray on some GT85 (kinda like WD40 plus some teflon lube, its a genuine chainlube product). Last chain I put in a plastic bag with a few squirts then wiped clean, then applied Finish Line
Quoted: 24 Post(s)
Liked 42 Times
This is the dumbest thread ever at BF.
As if the factory applies something to their chains that they want you to work very hard at to remove. I would be embarrassed to have asked this question.
Klickety-Klackety
Bikes: Ones with 2 wheels...
Gluteus Enormus
Bikes: Yes
Mmmmm potatoes
Quoted: 50 Post(s)
In contrast, when I had the bike shop reinstall my 1st and 2nd chains, they had removed all the sticky stuff, and that chain was SO easy to clean, and furthermore, stayed clean with minimal wiping. I live in Norcal, and thus do not ride in adverse conditions, and thus do not need thick all-weather chain lube.
I tried wiping it off with chain lube previously, but I must not have used enough - I thought SimpleGreen should remove it, but I was wrong. I'll have to next time try using liberal chain lube and seeing how it goes.
Underwhelming
Bikes: Lynskey R330 Ti, Dean El Vado Ti, Trek 4300
I'm guessing it's pretty low-tech, and we'd all be surprised at discovering the "recipe."
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times
I think it's cosmoline to keep stored chains from rusting. Some chains don't have it on them, the ones I have seen without it were higher end chains that had plating or someting else to keep the chains from rusting. It's not very important anyway.
pan y agua
Quoted: 1451 Post(s)
Liked 731 Times
I saw on Sheldon Brown's website that the manufacturer lube is allegedly the best one, but I speak from direct experience with my prior two chains that I bought and self-installed (KMC) that they were so sticky that they picked up dirt and grease instantly - to the point that I couldn't get the dirt out even with a chain cleaner and lots of degreaser, even after one ride.
When you degrease the chain to remove the factory lube, you're taking lube out of the inner workings of the chain, and shortening, rather than prolonging, the chain's life.
If you feel compelled, you can wipe "excess" factory lube off the outside of the chain, but you definitely don't want to degrease it.
You could get lost and die.
You could hit a tree and die.
Medicinal Cyclist
Bikes: 2003 Klein Q Carbon Race; 2009 Giant OCR-1
