Z Allen Wrench
Z Allen Wrench
I am down to only one of these z wrench tools and I can't find where to buy more. I have looked everywhere I can think of on the net, but haven't been able to locate one. I thought they used to be really common. They are perfect for a bike kit. 4mm on one end and 5mm on the other. Does anyone know where they can be purchased?
Bikes: A Few
Quoted: 156 Post(s)
Liked 63 Times
Not quite the sizes you want, but Amazon has a Sunlite one 5 and 6mm -
Look for "Sunlite 5/6mm Hex Wrench"
Sorry, not enough posts to put the link :~)
Quoted: 6173 Post(s)
Liked 4,790 Times
The only time I see those is when I get them as a tool included with something I have to put together, such as shelves or bed frames. I've got a few of them myself. Never seen them sold retail.
Pedros makes a small Y shaped 4,5,6.
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
Ikea?
$199 might be a little expensive for a combo allen wrench, but it comes with a free dresser, lol!
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Those 5/6 Allens used to come with '80s Raleighs.
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
You could try asking your local box stores that offer free assembly of furniture. They may have those wrenches just laying around.
Quoted: 1572 Post(s)
Liked 643 Times
That's what I was going to say: IKEA. Not a bad idea to pack one in my on-bike repair kit. Less bulky than the multi tool that I'm using now and 4mm and 5mm covers most things.
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
Not exactly what you wanted (the ends are a little long) but its a 4/5mm hex key:
https://www.aliexpress.com/item/m16-...478007315.html
I never finish anyth
Bikes: 2008 Merckx LXM, 2003 Giant XTC mtb, 2001 Lemond Alpe d'Huez, 1997 Lemond Zurich, 1989 Cannondale ST, 1988 Masi Nuovo Strada, 1983 Pinarello Turismo
Quoted: 294 Post(s)
Liked 137 Times
Not likely that you'll be able to file them, hex keys are usually hardened. The only way would probably be to grind it, but the downside is that if you grind through the hardening, you would expose the much softer metal underneath.
Dale, NL4T
Dale, NL4T
That is true, but i figure the freebie tools from ikea or that come in a bike box for assembly aren't exactly high quality super hard tools to begin with. They only need to hold up to 5 to 7 nm anyway right?
Liked 2,942 Times
snap-on use to sell them iirc.
-Oh Hey!
-Oh Hey!
Liked 341 Times
Allen keys are around 57 Rockwell. You could file it, but you'd likely dull the file a bit. Not sure that making a 4 dollar allen key is worth ruining a 15 dollar file.
And allen keys are case-hardened. That is, the hardness is on the surface (put there either by a carburizing or other agent, or by selective heat-treatment - for example using induction hardening). This leaves a tough core. BTW, hard to do on smaller hex keys - which is why I've broken a lot of 1 and 2mm and 1/16" keys. If you grind off the surface, the hardened surface (which is also stronger, btw) is gone.
Better to find the thing already made, and properly hardened.
Quoted: 980 Post(s)
Liked 580 Times
I saw these "Fix-It Sticks" at InterBike and got a set. They're not quite as simple as "Z" wrenches, but they are able to be fitted with whatever ends you need. https://www.backcountry.com/fix-it-sticks-original-tool-with-bracket?CMP_SKU=FXS0004&MER=0406&skid=FXS0004-MOUSET-S456MMHETOS25W&mr:trackingCode=75EAA5F3-94E5-E711-8102-005056944E17&mr:referralID=NA&mr:device=c&mr:adType=plaonline&CMP_ID=PLA_GOc001&utm_source=Google&ut m_medium=PLA&k_clickid=bee84daa-d9a4-47b9-9212-5db4375813d2&rmatt=tsid:1042790|cid:213416677|agid:49514702840|tidla-367674611733|crid:224495893170|nw:g|rnd:7203427541437759134|dvc:c|adp:1o3|mt:|loc:9021463&gclid=Cj0K CQiA5aTUBRC2ARIsAPoPJk8YNL_SVyDNZSAqVsE94t_wUPnmZLEUNMjOvcB-aRzgb011x0OWUc8aAokREALw_wcB
Steve
Steve
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
