Weak brakes on a brand-new bike?
Happily Addicted
Bikes: '16 Trek Domane SLR 7 Disc
Quoted: 21 Post(s)
Picked up my new '11 Spec. Allez Comp w/Apex on Friday evening-- 58 miles over the last two days and loving the bicycle overall. The one thing that doesn't feel right is the braking. The brakes are adjusted right (very short "throw" on the levers until the brakes contact the surface) but they don't feel very strong.
Specialized ships the bike with Tektro brakes and pads. When I was test-riding other bikes, I felt that a set of new Ultegra brakes felt the most impressive-- those connected instantly and felt powerful. The brakes on my new bike feel weak-- they take a long time to engage and never feel really strong. I noticed it quite obviously when coming to stop lights on my ride today.
Will new pads make a difference, or should I look for some SRAM brakes that might be a bit stronger? I'd rather not get a whole new set of brakes, but I'm not happy with the way these feel. If it's just about pads, I'll happily get some new pads and use these brake calipers.
Thanks!
Thanks!
CAADdict
Bikes: 2009 Cannondale CAAD9-?
Liked 5 Times
Solution: SwissStop Brake Pads
https://www.swissstop.ch/Road.aspx
I have OEM Tektros too.
I just upgraded to these (save 140 grams [1/4 pound])
for $160. shipped and they come with SwissStop Pads.
https://www.planet-x-usa.com/pCNC%20U...ht-Brakes.aspx
Any set of Shimano brakes from 105-up will drastically improve your braking.
Bikes: Volagi, daVinci Joint Venture
I'm not familiar with Tektro brakes, but us tandem folk really need effective brakes and Salmon or Black/Salmon Koolstops are very well thought of. Swiss Stop are also highly regarded. First thing I might try is cleaning the rim; I wonder if the rim could have some sort of film affecting stopping. It's hard to imagine a single with modern calipers having a stopping problem.
Happily Addicted
Quoted: 21 Post(s)
Awesome. So I can just get the pads themselves (here's a link I found: https://www.competitivecyclist.com/pr...62.1767.0.html) and swap them myself, or is that something I should have the shop do for me? Or do I want the ones that come with holders already? I'm probably going to skip upgrading the brake calipers themselves if I can get better braking with new pads.
CAADdict
Liked 5 Times
That way, you can haul arse on that bike with confidence.
You might be able to use replacement pads or might need the holders too.
Either way, it's the best $20.-$30. you can spend on your bike right now.
Happily Addicted
Quoted: 21 Post(s)
Pay your local shop the $10. they'd charge to put them in for you and adjust them until you learn.
Bike ≠ Car ≠ Ped.
Bikes: Cannondale CAAD 10, Cannondale Synapse
My "Dale" Synapse had mediocre brakes when I bought it. I installed a new set of Scott Mathauser pads from the vintage parts box, and now have brakes that rival the discs on my Kona Dew Drop.
Bikes: 1983 Gureciotti/full SR 2002 Casati Record 10 speed 1995 Colnago C40 2007 Sram Rival 2006 Isaac Sram Force 2000 DEAN Ti DA 10 speed 1987 Schwinn Prologue Funny Bike 2001 Pinarello DA 9 speed 2008 Element6 Record 10speed Origin8 Lutegra10speed
Bikes: 2011 Cannondale CAAD10
My CAAD9-5 had pretty crappy stock brakes. I put a lot of miles on them and then switched out the pads to Kool Stops. Made a big (although not what I would call monumental) difference.
I guess what I'm saying is that with my Tektro brakes and Kool Stop pads I've never had the need for more stopping power.
The Tektro R750 comes with Kool Stop pads. I would consider all other brake pads used for Tektro brakes as being bad. But at the cost of Tektro brakes - replace the pads and you will have a good pair of brakes.
