my threaded headset gets loose
30mi/day commuter
Quoted: 5 Post(s)
i am about to take apart my threaded headset which is always getting loose.
I tighten it and it loosens, its very annoying.
What should I keep my eye out for? what can cause this?
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,923 Times
stripped threads
Sugar "Kane" Kowalczyk
Retro Grouch
Bikes: Yes
There are several different kinds of headsets, each with their own set of problems. Do you have a photo or a 1000 words to tells what headset is giving you fits?
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12768 Post(s)
Liked 7,683 Times
Make sure you're tightening the cone against the locknut well. I've had a couple over the years that just refuse to stay locked even when it seemed I really had 'em cinched. I used blue Loctite, but a Gorilla Headlock would be even better, I'd imagine:
https://abundantadventures.com/quads.html#HEADLOCK
Tangent question:
What's the preferred set of tools for knurled top cone style Headsets? I've been getting by with pipe wrench + headset wrench, but curious what others do.
Tangent question:
Quoted: 5781 Post(s)
Liked 2,576 Times
+1,
The most common cause of headsets that get loose quickly is the top nut bottoming on the steerer, and a washer underneath to solve it.
Headsets without keyed washers (forks without keyways) are also hard to keep adjusted and tend to loosen very slowly over time. This is harder to fix if the fork doesn't have a keyway, and might call for locktite in the locknut threads.
FB
Chain-L site
FB
Chain-L site
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times
why would you use a pipe wrench? that stuff gouges, badly too.
use an adjustable with a headset wrench.
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
Bikes: 87 Bridgestone 550 (Shocking Electric Metallic Pink)
I have the same type of "Old School" headset, it is ROUND and knurled. You can not put a wrench on ROUND. I use a pair of Channel-locks with a rag or scrap of inner tube on the chrome to protect it.
Retro Grouch
Bikes: Yes
These require that the top toothed washer that sits on the knurled toothed top cone, has a tab that fits into the grooved steerer, so it will not turn when you tighten the top nut; Channel Locks are usually the tool of choice, but check if the washer tab has stripped out; if so you will need a bit for force to hold the knurled top cone when tightening..
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
I hand file the keyway into the forks I build. It doesn't have to extend all the way to the end of the threads; but just far enough to hold the toothed washer.
Quoted: 90 Post(s)
Liked 137 Times
Glenn
Certified Bike Brat
Quoted: 5 Post(s)
Liked 6 Times
You might also want to check the alignment of the cups. The steering head may not have been faced properly, or the cups seated properly. A vernier across the cups should give some indication even without a measurement. The dumbest thing I tripped across was cups that were installed in a headtube without facing the headtube or even grinding the internal weld ridge in the headtube. The bearings seemed smooth enough, but I doubt the cups were either round or straight so pressure on the bearings couldn't possibly be uniform. Since I was installing a new race - it wasn't a big deal to just do what should have been done the first time.
Darth Lefty
Bicycle Mechanics
15
06-23-16 06:01 PM
illdthedj
Singlespeed & Fixed Gear
15
10-29-10 03:54 PM
