Tyre recommendations for new Cannondale Cujo 2
Hi everyone,
I have just recently bought a 2021 Cannondale Cujo 2 second hand for a very good price as it has hardly been used (£220 - where as new they are £1000+)
I understand it is a mountain bike, but I will be using it alot on the roads - and after first impressions, it is terrible and hard work on the roads with the stock WTB Ranger Comp, 27.5 x 2.8 tyres.
I was thinking about changing the tyres for something more suitable for the road but also something that will perform well offroad and on trials (if this is possible - I am uneducated on the subject). I have seen online people recommend going tubeless - which I want to avoid because I feel as though this could get messy? I have always used inner tubes so when a puncture arises it is easy to change or fix.
My question is then do you have any recommendations for a better tyre and/or can you enlighten me on tubeless riding and how this would benefit me - if at all.
Cheers
Cheers
Clark W. Griswold
Liked 4,553 Times
So that bike is a mountain bike used for off road, great deal on it (assuming it wasn't previously stolen and re-sold) but not a road machine. Riding on the road with it is going to be slower and less efficient. There are some wider road tires and some wider gravel tires but for mountain biking these would not be great.
For trials they typically use a different bike entirely very almost like a BMX bike with no saddle and very powerful disc brakes designed more for a non-moving position rather than slowing down as you don't really pick up speed doing trials but you want something light and easy to jump around with it is a very specialized hobby.
I suspect maybe you meant trails (but I know trials is popular across the pond and don't want to not give all the info) and if mountain biking trails you want good mountain biking tires and not road or gravel tires. If you are trying to do both with one tire then your best bet is to look for something for hardpack trails. Obviously it won't be great on the road and won't be great in looser muddy conditions but it will probably bridge the gap the best.
WTB makes decent tires, for me it would probably be Schwalbe, Continental, Maxxis, Vittoria. Though currently I am running some lovely Michelin tires but they are more of a loose muddy terrain tire.
You might consider keeping this as a mountain bike and getting a hybrid for road and gravel usage because it is hard for one bike to do everything.
Do you think going tubeless would improve my situation with normal mtb tyres?
Clark W. Griswold
Liked 4,553 Times
Tubeless will help with pinch flats and smaller holes and such it won't really change anything for riding on the road. It gives you the option to run lower pressures without issues but on the road you would probably want a little higher pressure than you would off road. I think it is a great thing but to be honest I haven't yet done it to any of my bikes but I have a whole bunch of them and some I may not ride for a while so I don't want to deal with potential sealant leaks from it sitting for a month or maybe more which if used often or kept up on with pressure won't be an issue but I know I will forget to pump or something like that. Though I may end up doing it down the road.
